Home » Modeling » EMF » EObject EGet Problem(Returns NULL based on the cardinality of the EReference object)
EObject EGet Problem [message #637620] Sun, 07 November 2010 20:06 Go to next message
Dear All,
I have a very small problem. Hopefully someone can help me out.
Consider the following ecore model (Kindly use the ecore model editor to view the model). The package consists of 4 classes, BookStore, Book, Editor and Publisher.
<?xml version="1.0" encoding="ASCII"?>
<ecore:EPackage xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="BookStorePackage"
    nsURI="http:///com.ibm.dynamic.example.bookstore.ecore" nsPrefix="bookStore">
  <eClassifiers xsi:type="ecore:EClass" name="BookStore">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="owner" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
        defaultValueLiteral="Arun Prakash"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="location" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
        defaultValueLiteral="Berlin"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="Book" upperBound="-1" eType="#//Book"
        containment="true"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Book">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
        defaultValueLiteral="God of Small Things"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="isbn" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"
        defaultValueLiteral="1234"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="Editor" upperBound="-1"
        eType="#//Editor" containment="true"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="Publisher" upperBound="-1"
        eType="#//Publisher" containment="true"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Editor">
        defaultValueLiteral="Ewa Slomska"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="place" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
        defaultValueLiteral="Gdynia"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Publisher">
        defaultValueLiteral="Slomska Publications"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="country" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
  </eClassifiers>
</ecore:EPackage>
Bookstore has 2 attributes and 1 reference (refers to Book Eclass)
Book has 2 attributes and 2 references (refers to Editor and Publisher)
Editor and Publisher have 2 and 3 attributes respectively.
All the references have the following properties (0..*), i.e.
Lower Bound = 0
Upper Bound = -1
Now for this ecore model, I dynamically create model objects by starting with the root model class, namely Bookstore class, in a recursive manner, as shown below
	private void modelHandler()
		// Get all EClasses in the package.
		EList<EObject> eObjects = ePackage.eContents();
		int numEObjects = eObjects.size();
                // I somehow use this function to get the root model class
		EClass rootModelEClass = getRootModelEClass(numEObjects, eObjects);
		// Created RootModel EClass Object.
		EObject rootModelEObject = eFactory.create(rootModelEClass);
		filler(rootModelEClass, rootModelEObject);
		saveAsGMEModel(rootModelEObject);
	private void filler(EClass rootModelEClass, EObject rootModelEObject)
		log.debug("rootModelEClass :" + rootModelEClass.getName());
		// Get all the EReferences of the EClass
		EList<EReference> eReferences = rootModelEClass.getEReferences();
		int numEReferences = eReferences.size();
		log.debug("numEReferences :" + numEReferences);
		for (int j = 0; j < numEReferences; j++)
			EReference eReference = eReferences.get(j);
			log.debug("eReference Name :" + eReference.getName());
			log.debug("eReference Type :" + eReference.getEType().toString());
			EClass eClass = (EClass) eReference.getEType();
			EObject eObject = eFactory.create(eClass);
			filler(eClass, eObject);
			if (rootModelEObject.eGet(eReference) == null)
				System.out.println("something is wrong here");
			else
				((List) rootModelEObject.eGet(eReference)).add(eObject);
The above code works perfectly fine for the above Ecore model. The check if (rootModelEObject.eGet(eReference) == null) returns false.
Now in the case of the same model, with a minor modification, namely with respect to the properties of the references .. i.e., the references of the Book EClass, namely Editor: Editor and Publisher: Publisher have their cardinality set to 1, i.e.,
Lower Bound = 1
Upper Bound = 1
<ecore:EPackage xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="BookStorePackage" nsURI="http:///com.ibm.dynamic.example.bookstore.ecore" nsPrefix="bookStore">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="owner" defaultValueLiteral="Arun Prakash">
      <eType xsi:type="ecore:EDataType" href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
    </eStructuralFeatures>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="location" defaultValueLiteral="Berlin">
    <eStructuralFeatures xsi:type="ecore:EReference" name="Book" upperBound="-1" eType="//Book" containment="true"/>
  </eClassifiers>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" defaultValueLiteral="God of Small Things">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="isbn" defaultValueLiteral="1234">
      <eType xsi:type="ecore:EDataType" href="http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="Editor" lowerBound="1" eType="//Editor" containment="true"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="Publisher" lowerBound="1" eType="//Publisher" containment="true"/>
  </eClassifiers>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" defaultValueLiteral="Ewa Slomska">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="place" defaultValueLiteral="Gdynia">
  </eClassifiers>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" defaultValueLiteral="Slomska Publications">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="country">
  </eClassifiers>
</ecore:EPackage>
In this case, the check if (rootModelEObject.eGet(eReference) == null) returns true.
I am baffled as to why this happens? For the moment as a workaround I have kept the cardinalities to (0..*) in my model. However, this is not the correct model. The correct model requires the cardinalities to be set to (1..1).
Hopefully someone could answer my problem.
Thanks & Regards
Arun
Re: EObject EGet Problem [message #637675 is a reply to message #637620] Mon, 08 November 2010 04:30 Go to previous messageGo to next message
Arun,
Comments below.
Arun wrote:
> Dear All,
> </eClassifiers>
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> Lower Bound = 0
> Upper Bound = -1
This isn't just the contained classes, but in fact all contained
objects, including annotations and subpackages.
> eObjects);
Why not use an iterator?
You should be expecting this to be null for single valued features. You
should be using eSet to set single valued features.
> else
> Lower Bound = 1
> Upper Bound = 1
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> returns true.
A single valued feature without a value will clearly return null. What
else could it possibly return.
> in my model.
A multi-valued feature will always return a list; it will be empty until
you put something in it.
Did you use the debugger to step through the eGet calls to see what's
happening? That should make it pretty clear.
> Thanks & Regards
> Arun
Re: EObject EGet Problem [message #637916 is a reply to message #637675] Tue, 09 November 2010 05:49 Go to previous messageGo to next message
Ed,
Thanks for the quick reply. I did use the debugger ... but I didnt know how single value features are handled . Nevertheless, I will read through your response in detail once more and hopefully will be able to fix the issue. Thanks again.
On a different note, I was wondering how to refer to a DataType located in a different resource in a DataType. Let me explain. As I am new to ecore, I dont even know the term used for defining this. is it cross-document references? Anyway, consider the following original scenario/model.
<ecore:EPackage xmi:version="2.0"
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="owner" eType="#//CustomString"
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="location" eType="#//CustomString"
  </eClassifiers>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="#//CustomString"
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="isbn" eType="#//CustomInt"
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="Status" eType="ecore:EEnum Util.ecore#//Status"
        defaultValueLiteral="review"/>
  </eClassifiers>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="place" eType="#//CustomString"
  </eClassifiers>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="country" eType="#//CustomString"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EDataType" name="CustomInt" instanceClassName="int"/>
  <eClassifiers xsi:type="ecore:EDataType" name="CustomString" instanceClassName="java.lang.String"/>
  <eClassifiers xsi:type="ecore:EEnum" name="CustomStatus"/>
</ecore:EPackage>
http://img210.imageshack.us/img210/7322/bookstorestatus.png
As you can see, I refer to the Status DataType located in the Util.ecore resource, by simply loading the resource and refering to the correct DataType in the EType property of the Status:Book DataType.
Now what I want to achieve is something like this...
http://img600.imageshack.us/img600/7516/bookstorecustomstatus.png
where, I have a custom datatype defined as CustomStatus. I want this CustomStatus to refer (or what is correct term here) to the Status DataType of the Util.ecore resource. Hope you can understand me.
How do one achieve this, i.e., what should be the value of Instance Type Name property of the CustomStatus datatype? For my CustomString, I used the Instance Type Name as java.lang.String and it works fine. Its unclear to me how to achieve the same result for a user defined DataType.
Finally, it would be great if you could point me to some text that also explains how to achieve this programatically?
Thanks again for your previous reply.
Arun
Re: EObject EGet Problem [message #638268 is a reply to message #637916] Wed, 10 November 2010 09:44 Go to previous messageGo to next message
Arun,
Comments below.
Arun wrote:
> Ed,
It should be clear that the generated getter is called and it returns
the value of a field which is initially null.
> scenario/model.
> </eClassifiers>
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
Data types don't work that way. Define a new EDataType that does what
you want.
> DataType.
It should have the same instance type name as the generated user defined
data type. (Only EEnums actually generate a new result in the Java code,
so that's the only case where you have to set the name that's generated.)
The EMF book will have to suffice.
> Regards
> Arun
Re: EObject EGet Problem [message #638563 is a reply to message #637620] Thu, 11 November 2010 11:07 Go to previous message
Thanks Ed,
I fixed it.
Previous Topic:How to avoid childAction in TreeView?
Next Topic:EMF Generic Search
Current Time: Sat Jul 19 09:42:47 EDT 2025
Powered by FUDForum. Page generated in 0.05977 seconds
