Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Compare into plug-in eclipse(Problems when adding emf compare jars into classpath of a plug(in)
EMF Compare into plug-in eclipse [message #638276] Wed, 10 November 2010 11:52 Go to next message
Dear All,
I have a problem when adding emf compare libraries into the runtime path for plug-in that I created myself.
More precisely, I have this error:
at org.eclipse.emf.compare.match.service.MatchService.getBestMa tchEngine(MatchService.java:449)
at org.eclipse.emf.compare.match.service.MatchService.doMatch(M atchService.java:154)
at change.comparison.CompareChange.compare(CompareChange.j ava:173)
at change.Set.processSelection(Set.java:48)
at change_plugin.views.SampleView.setgam(SampleView.java:573)
at change_plugin.views.SampleView$5.widgetSelected(SampleView.j ava:299)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:45)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:599)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
When setting these libraries into a simple java project everything is OK.
Thaks in advance for your help.
Cordially,
Elizabeta
[Updated on: Wed, 10 November 2010 11:53] by Moderator
Re: EMF Compare into plug-in eclipse [message #639355 is a reply to message #638276] Tue, 16 November 2010 03:36 Go to previous messageGo to next message
--------------050703040706050307030501
Hi Elizabeta,
Please use the EMF newsgroup for questions regarding EMF Compare,
prefixing your post subjects with [Compare].
That said, I see no possible way for this NullPointerException to be
thrown, save for very convoluted means... As it would mean that Eclipse
is indeed running, yet the EMF Compare plugin wouldn't be started.
The only thing I can think of is that you've added the EMF Compare jar
in a plugin's class path ... and try to use it as is. This mean of
adding dependencies to a plugin is only reserved for non-plugin
dependencies, not plugin ones.
You have to use the standard "plugin" way of adding dependencies if you
wish to depend on compare : double click your plugin's MANIFEST.MF file
and, in the manifest editor, select the "dependencies" tab at the
bottom, then "Add" a dependency to "org.eclipse.emf.compare".
Laurent Goubet
Obeo
On 10/11/2010 17:52, Elizabeta wrote:
> Dear All,
> for plug-in that I created myself. More precisely, I have this error:
> at hchange.comparison.CompareChange.compare(CompareSechChange.j ava:173)
> at change.Set.processSelection(Setgam.java:48)
> ner.java:228)
> (Realm.java:288)
> bench.java:488)
> tarter.java:382)
> tarter.java:179)
> ssorImpl.java:45)
> Cordially,
> Elizabeta
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050703040706050307030501--
Re: EMF Compare into plug-in eclipse [message #639613 is a reply to message #639355] Wed, 17 November 2010 03:18 Go to previous message
Thank you very much for the quick reply. The next time I will post the message correctly.
Yes, actually I use EMF Compare in a standalone java library which is part of my plug-in eclipse and then I add the jar in the plug-in classpath. I will try to follow your advice, and let you know as soon as possible if it is ok.
Cordially,
Elizabeta
Previous Topic:EEF and a transactional editing domain.
Next Topic:[TEXO] EMF databinding
Current Time: Sat Jul 19 12:40:18 EDT 2025
Powered by FUDForum. Page generated in 0.08738 seconds
