Home » Eclipse Projects » Mylyn » Mylyn Dependency?(Problem regarding dependecy on the mylyn tools)
Mylyn Dependency? [message #637816] Mon, 08 November 2010 19:49
I am developing some plug-ins for eclipse and have gotten to a stage where they are being downloaded using the installation manager. However, when they are installed, eclipse acts as though they are dependent on Mylyn and has the user install Mylyn as well. As far as I can tell, the plug-ins are not dependent on Mylyn. Any ideas on what might be happening/how to resolve this?
relevant details:
Plugin lists as dependencies:
org.eclipse.ui
org.eclipse.core.runtime
org.eclipse.ltk.core.refactoring
org.eclipse.ant.ui
org.eclipse.jdt.ui
as imported packages:
org.eclipse.core.internal.resources
org.eclipse.core.resources
org.eclipse.debug.core
org.eclipse.debug.core.model
org.eclipse.debug.ui
org.eclipse.jdt.core
org.eclipse.internal.compiler.impl
org.eclipse.jdt.internal.core
org.eclipse.jdt.internal.ui.util
org.eclipse.ui
org.eclipse.ui.externaltools.internal.model
org.eclipse.ui.wizards.newresource
When eclipse installs the plugins, it forces install of:
Mylyn Bridge: Eclipse IDE
Mylyn Bridge: Java Development
Mylyn Bridge: Team Support
Mylyn Connector: Bugzilla
Mylyn Task List (Required)
Mylyn Task-Focused Interface (Recommended)
Mylyn WikiText
This was tried on a fresh upacked Eclipse, with a newly created workbench
I am aware there are several internal package references (these are being worked on) however as far as I know this is not causing the indicated problem.
Thanks for any and all help!
Previous Topic:performance problem
Next Topic:is there TaskAttribute Reference list
Current Time: Sat Jul 19 18:23:11 EDT 2025
Powered by FUDForum. Page generated in 0.03321 seconds
