Problem Starting glassfish server [message #637793] |
Mon, 08 November 2010 16:37  |
I am trying to install glassfish under Eclipse (Helios). Eclipse Downloaded and installed glassfish but when I try start the glassfish server, I get a failure notice "Server GlassFish v3 Prelude at localhost failed to start."
Basic error message "
WARNING: Cannot start JMX connector: JmxConnector config: Port 8686 is not available for the internal rmi registry. "
What am I missing.
server log:
INFO: Started bundle org.glassfish.common.container-common [83]
Nov 8, 2010 4:08:30 PM com.sun.enterprise.v3.admin.adapter.AdminConsoleAdapter setStateMsg
INFO: The Admin Console Web Application has been downloaded.
Nov 8, 2010 4:08:30 PM com.sun.enterprise.v3.server.AppServerStartup run
INFO: GlassFish v3 Prelude startup time : Felix(2345ms) startup services(618ms) total(2963ms)
Nov 8, 2010 4:08:30 PM org.glassfish.admin.mbeanserver.ConnectorStartupService$Conn ectorsStarterThread run
WARNING: Cannot start JMX connector: JmxConnector config: { name = system, Protocol = rmi_jrmp, Address = 0.0.0.0, Port = 8686, AcceptAll = false, AuthRealmName = admin-realm, SecurityEnabled = false}: java.lang.RuntimeException: Port 8686 is not available for the internal rmi registry. This means that a call was made with the same port, without closing earlier registry instance. This has to do with the system jmx connector configuration in admin-service element of the configuration associated with this instance
FUDForum. Page generated in 0.02910 seconds
