Home » Modeling » EMF » Copy & paste "link" elements in a model
Copy & paste "link" elements in a model [message #637681] Mon, 08 November 2010 05:45 Go to next message
Hello.
I have observed that when I copy and paste a "link" element, insted an element which is a reference to a "physical" element at the model, the paste is not complete in the next sense. If I modify some properties of the recent copied element, that values are not updated in the rest of the references and the "source" element. However, is I save the editor and reopen it, the model is loaded right...
So I wanted to know if I have to execute this kind of copy & paste operations about "link" elements in order to refresh the model state without saving and reopening.
I have observed that the editor execute this operation right like a DND operation, but I was also very interested in getting the same behaviour for the copy & paste.
Have you got any suggestion?
Thanks in advance.
Best regards.
Carlos.
Re: Copy & paste "link" elements in a model [message #637730 is a reply to message #637681] Mon, 08 November 2010 08:23 Go to previous messageGo to next message
Carlos,
Comments below.
Carlos wrote:
> Hello.
Are you saying you're pasting into a non-containment reference? And you
displaying the same object more than once in the tree view?
> Thanks in advance.
> Best regards.
> Carlos.
Re: Copy & paste "link" elements in a model [message #637855 is a reply to message #637730] Tue, 09 November 2010 03:09 Go to previous messageGo to next message
Ed,
yes, that's exactly I wanted to say.
It's like "DND.DROP_LINK" but through copy&paste operation.
When I finish the copy&paste operation, if I modify a property in the element that has been pasted, the value is not updated in all the instances.
How can I get the refresh or something in order to get the recent pasted non-containment reference have the same behaviour that the other instances without reloading the model?.
Thanks in advance.
Carlos.
Re: Copy & paste "link" elements in a model [message #638269 is a reply to message #637855] Wed, 10 November 2010 09:52 Go to previous messageGo to next message
Carlos,
Comments below.
Carlos wrote:
> Ed,
It's a little tricky though right, because copy produces a copy and that
copied object won't be contained by anything. Adding it to a
non-containment reference will leave it as a dangling reference unless
you take some type of action.
> instances.
No doubt it's a copy.
Well, I don't understand this issue of "it works after it's been
reloaded". You mean for drag and drop? You also didn't answer my
question about the same object showing up more than once in the tree. I
asked it for a good reason; my providing helpful information depends on
the answer. I.e., you'll need to ensure that you produce wrappers for
the non-contained children.
> Thanks in advance.
> Carlos.
Re: Copy & paste "link" elements in a model [message #638722 is a reply to message #638269] Fri, 12 November 2010 05:55 Go to previous message
Ed,
Firstable, excuse me because of my previous confusing explanation.
In order to answer your question, the same object showing up more than once in the tree.
The point was that after the copy&paste, when I tried to modify some properties at the dangling reference, obviuosly, that values were not updated in the other references.
When I said "it works after it's been reloaded", I wanted to say that after the copy&paste, I saved, closed and reopened the editor, and the dangling reference, became a "normal" reference.
So that I have done is implementing the behaviour I want over the standard copy & paste in order to allow the user to paste the non-containment references. Now, after the copy&paste, if I modify some property at the recent pasted reference, that value also changes in all the references.
Anyway, thank you very much for your attention.
Best regards.
Carlos.
Previous Topic:EMF Generic Search
Next Topic:EMF Helios Dev Environment
Current Time: Sat Jul 19 22:04:59 EDT 2025
Powered by FUDForum. Page generated in 0.06408 seconds
