Home » Eclipse Projects » Eclipse Platform » repeated crash in 3.6.1 after 2 min of starting(Current CompileTask is always OpenTypeHistory.internalCheckConsistency(IProgressMonitor))
repeated crash in 3.6.1 after 2 min of starting [message #637669] Mon, 08 November 2010 05:01
Suddenly I get a crash everytime I try to use my project. It does not take more than two minutes since I launch eclipse till it crashes, always with the same stack (see down).
I have tried:
- updating eclipse and all plugins
- updating to jvm 1.6.0.22
- starting with -clean
- replacing eclipse.ini with the default one.
None has worked.
I have other workspaces with the same eclipse that are not suffering form this crash. Does anyone has an idea on how to fix this??
thanks in advance
# A fatal error has been detected by the Java Runtime Environment:
# java.lang.OutOfMemoryError: requested 268435464 bytes for Chunk::new. Out of swap space?
#  Internal Error (allocation.cpp:215), pid=4460, tid=7516
#  Error: Chunk::new
# JRE version: 6.0_22-b04
# Java VM: Java HotSpot(TM) Server VM (17.1-b03 mixed mode windows-x86 )
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
---------------  T H R E A D  ---------------
Current thread (0x416e8800):  JavaThread "CompilerThread0" daemon [_thread_in_native, id=7516, stack(0x42fb0000,0x430b0000)]
Stack: [0x42fb0000,0x430b0000],  sp=0x430ae740,  free space=3f9430ae750k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V  [jvm.dll+0x3328c0]
V  [jvm.dll+0x10333c]
V  [jvm.dll+0x3c5dc]
V  [jvm.dll+0x3c873]
V  [jvm.dll+0x2a4bf9]
V  [jvm.dll+0x2a52b6]
V  [jvm.dll+0x2a6cb5]
V  [jvm.dll+0x2a65cf]
V  [jvm.dll+0xe1a70]
V  [jvm.dll+0xe25d8]
V  [jvm.dll+0xa4811]
V  [jvm.dll+0xe48f9]
V  [jvm.dll+0xe54ef]
V  [jvm.dll+0x312bb4]
V  [jvm.dll+0x28af1c]
C  [MSVCR71.dll+0x9565]
C  [kernel32.dll+0x44911]
C  [ntdll.dll+0x3e4b6]
C  [ntdll.dll+0x3e489]
Current CompileTask:
C2:17021 s!   org.eclipse.jdt.internal.corext.util.OpenTypeHistory.internalCheckConsistency(Lorg/eclipse/core/runtime/IProgressMonitor;)V (267 bytes)
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x441f1800 JavaThread "pool-1-thread-2" [_thread_blocked, id=5172, stack(0x5b300000,0x5b700000)]
  0x458a7c00 JavaThread "MultiThreadedHttpConnectionManager cleanup" daemon [_thread_blocked, id=6776, stack(0x5af00000,0x5b300000)]
  0x458a7800 JavaThread "pool-1-thread-1" [_thread_blocked, id=4232, stack(0x5ab00000,0x5af00000)]
  0x458a6000 JavaThread "Thread-15" daemon [_thread_blocked, id=2604, stack(0x5a700000,0x5ab00000)]
  0x48a9f800 JavaThread "Compiler Processing Task" daemon [_thread_in_vm, id=3548, stack(0x509e0000,0x50de0000)]
  0x48143000 JavaThread "Worker-12" [_thread_blocked, id=4672, stack(0x4fda0000,0x501a0000)]
  0x48a9d400 JavaThread "Worker-11" [_thread_blocked, id=7224, stack(0x4efa0000,0x4f3a0000)]
  0x458f5000 JavaThread "Worker-10" [_thread_blocked, id=3704, stack(0x4eba0000,0x4efa0000)]
  0x458f4c00 JavaThread "Worker-9" [_thread_blocked, id=368, stack(0x4e7a0000,0x4eba0000)]
  0x458f4400 JavaThread "Worker-8" [_thread_blocked, id=6580, stack(0x4e3a0000,0x4e7a0000)]
  0x458f3800 JavaThread "Worker-7" [_thread_blocked, id=6420, stack(0x4dfa0000,0x4e3a0000)]
  0x458f3400 JavaThread "Worker-6" [_thread_blocked, id=2208, stack(0x4dba0000,0x4dfa0000)]
  0x458f2c00 JavaThread "Worker-5" [_thread_blocked, id=7612, stack(0x4d7a0000,0x4dba0000)]
  0x458f2400 JavaThread "Worker-4" [_thread_blocked, id=7960, stack(0x4d3a0000,0x4d7a0000)]
  0x48149000 JavaThread "Worker-3" [_thread_blocked, id=6672, stack(0x4b890000,0x4bc90000)]
  0x48148c00 JavaThread "Worker-2" [_thread_blocked, id=6712, stack(0x4b490000,0x4b890000)]
  0x451e5400 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=7384, stack(0x4c690000,0x4ca90000)]
  0x48149c00 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon [_thread_blocked, id=8132, stack(0x4c290000,0x4c690000)]
  0x48149800 JavaThread "Java indexing" daemon [_thread_blocked, id=3296, stack(0x4be90000,0x4c290000)]
  0x44f7a800 JavaThread "Worker-1" [_thread_blocked, id=5276, stack(0x4b090000,0x4b490000)]
  0x44709000 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=7352, stack(0x4ac90000,0x4b090000)]
  0x49527000 JavaThread "Worker-0" [_thread_blocked, id=6816, stack(0x4a890000,0x4ac90000)]
  0x454d5800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=7428, stack(0x465b0000,0x469b0000)]
  0x445fdc00 JavaThread "Worker-JM" [_thread_blocked, id=3300, stack(0x46db0000,0x471b0000)]
  0x452d2800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=5712, stack(0x469b0000,0x46db0000)]
  0x44cda000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=6424, stack(0x461b0000,0x465b0000)]
  0x4450f800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=7388, stack(0x45db0000,0x461b0000)]
  0x44f45c00 JavaThread "State Data Manager" daemon [_thread_blocked, id=6136, stack(0x459b0000,0x45db0000)]
  0x436e0c00 JavaThread "RMI TCP Accept-0" daemon [_thread_in_native, id=7784, stack(0x43ce0000,0x440e0000)]
  0x416ebc00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=4616, stack(0x431b0000,0x435b0000)]
  0x416e9000 JavaThread "CompilerThread1" daemon [_thread_in_native, id=5744, stack(0x430b0000,0x431b0000)]
=>0x416e8800 JavaThread "CompilerThread0" daemon [_thread_in_native, id=7516, stack(0x42fb0000,0x430b0000)]
  0x416e4c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=7588, stack(0x42bb0000,0x42fb0000)]
  0x416e4000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5156, stack(0x426b0000,0x42ab0000)]
  0x416e3800 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=7968, stack(0x422b0000,0x426b0000)]
  0x416ac400 JavaThread "Finalizer" daemon [_thread_blocked, id=2548, stack(0x41eb0000,0x422b0000)]
  0x416abc00 JavaThread "Reference Handler" daemon [_thread_blocked, id=6584, stack(0x41ab0000,0x41eb0000)]
  0x02b59800 JavaThread "main" [_thread_in_native, id=6404, stack(0x00030000,0x00130000)]
Other Threads:
  0x416a8c00 VMThread [stack: 0x419b0000,0x41ab0000] [id=4544]
  0x43651c00 WatcherThread [stack: 0x440e0000,0x441e0000] [id=6828]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 garbage-first heap   total 131072K, used 105272K [0x06400000, 0x0e400000, 0x26400000)
  region size 1024K, 12 young (12288K), 2 survivors (2048K)
 compacting perm gen  total 131072K, used 67831K [0x26400000, 0x2e400000, 0x3e400000)
   the space 131072K,  51% used [0x26400000, 0x2a63dd50, 0x2a63de00, 0x2e400000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040d000 	D:\dev\eclipse3.6\eclipse.exe
0x773b0000 - 0x774d7000 	C:\Windows\system32\ntdll.dll
0x75a60000 - 0x75b3b000 	C:\Windows\system32\kernel32.dll
0x77310000 - 0x773ad000 	C:\Windows\system32\USER32.dll
0x76960000 - 0x769ab000 	C:\Windows\system32\GDI32.dll
0x771b0000 - 0x77276000 	C:\Windows\system32\ADVAPI32.dll
0x77540000 - 0x77602000 	C:\Windows\system32\RPCRT4.dll
0x73190000 - 0x73215000 	C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.6001.18523_none_886c608850a2f36f\COMCTL32.dll
0x768b0000 - 0x7695a000 	C:\Windows\system32\MSVCRT.dll
0x770c0000 - 0x770de000 	C:\Windows\system32\IMM32.DLL
0x770e0000 - 0x771a8000 	C:\Windows\system32\MSCTF.dll
0x77530000 - 0x77539000 	C:\Windows\system32\LPK.DLL
0x75b50000 - 0x75bcd000 	C:\Windows\system32\USP10.dll
0x72000000 - 0x7200d000 	D:\dev\eclipse3.6\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.1.R36x_v20100810\eclipse_1309.dll
0x74d80000 - 0x74d88000 	C:\Windows\system32\VERSION.dll
0x76f70000 - 0x770b4000 	C:\Windows\system32\ole32.dll
0x6f3f0000 - 0x6f3f8000 	C:\tools\Synergy+\bin\synrgyhk.dll
0x72e80000 - 0x72f23000 	C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_none_5090ab56bcba71c2\MSVCR90.dll
0x76d50000 - 0x76ddd000 	C:\Windows\system32\OLEAUT32.DLL
0x6db70000 - 0x6dfb3000 	C:\jdk1.6.0\jre\bin\server\jvm.dll
0x73a40000 - 0x73a72000 	C:\Windows\system32\WINMM.dll
0x73a00000 - 0x73a39000 	C:\Windows\system32\OLEACC.dll
0x7c340000 - 0x7c396000 	C:\Windows\system32\MSVCR71.dll
0x75890000 - 0x758bc000 	C:\Windows\system32\apphelp.dll
0x6d850000 - 0x6d85c000 	C:\jdk1.6.0\jre\bin\verify.dll
0x6d3d0000 - 0x6d3ef000 	C:\jdk1.6.0\jre\bin\java.dll
0x6d330000 - 0x6d338000 	C:\jdk1.6.0\jre\bin\hpi.dll
0x759c0000 - 0x759c7000 	C:\Windows\system32\PSAPI.DLL
0x6d890000 - 0x6d89f000 	C:\jdk1.6.0\jre\bin\zip.dll
0x6d6b0000 - 0x6d6c3000 	C:\jdk1.6.0\jre\bin\net.dll
0x76d20000 - 0x76d4d000 	C:\Windows\system32\WS2_32.dll
0x75b40000 - 0x75b46000 	C:\Windows\system32\NSI.dll
0x750b0000 - 0x750eb000 	C:\Windows\system32\mswsock.dll
0x75110000 - 0x75115000 	C:\Windows\System32\wship6.dll
0x74c80000 - 0x74c85000 	C:\Windows\System32\wshtcpip.dll
0x743d0000 - 0x743df000 	C:\Windows\system32\NLAapi.dll
0x752e0000 - 0x752f9000 	C:\Windows\system32\IPHLPAPI.DLL
0x752a0000 - 0x752d5000 	C:\Windows\system32\dhcpcsvc.DLL
0x75540000 - 0x7556c000 	C:\Windows\system32\DNSAPI.dll
0x758f0000 - 0x75904000 	C:\Windows\system32\Secur32.dll
0x75340000 - 0x75347000 	C:\Windows\system32\WINNSI.DLL
0x75270000 - 0x75291000 	C:\Windows\system32\dhcpcsvc6.DLL
0x720c0000 - 0x720cf000 	C:\Windows\system32\napinsp.dll
0x72080000 - 0x72092000 	C:\Windows\system32\pnrpnsp.dll
0x720b0000 - 0x720b8000 	C:\Windows\System32\winrnr.dll
0x774e0000 - 0x7752a000 	C:\Windows\system32\WLDAP32.dll
0x729c0000 - 0x729c6000 	C:\Windows\system32\rasadhlp.dll
0x6d600000 - 0x6d609000 	C:\jdk1.6.0\jre\bin\management.dll
0x74e30000 - 0x74e6b000 	C:\Windows\system32\rsaenh.dll
0x75910000 - 0x7592e000 	C:\Windows\system32\USERENV.dll
0x6d6d0000 - 0x6d6d9000 	C:\jdk1.6.0\jre\bin\nio.dll
0x06360000 - 0x063c3000 	D:\dev\eclipse3.6\configuration\org.eclipse.osgi\bundles\226\1\.cp\swt-win32-3655.dll
0x76ca0000 - 0x76d13000 	C:\Windows\system32\comdlg32.dll
0x75bd0000 - 0x75c28000 	C:\Windows\system32\SHLWAPI.dll
0x749c0000 - 0x74b5e000 	C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18523_none_5cdd65e20837faf2\COMCTL32.dll
0x75da0000 - 0x768b0000 	C:\Windows\system32\SHELL32.dll
0x76bb0000 - 0x76c96000 	C:\Windows\system32\WININET.dll
0x769b0000 - 0x769b3000 	C:\Windows\system32\Normaliz.dll
0x75c30000 - 0x75d63000 	C:\Windows\system32\urlmon.dll
0x769c0000 - 0x76ba8000 	C:\Windows\system32\iertutil.dll
0x74930000 - 0x7496f000 	C:\Windows\system32\uxtheme.dll
0x439b0000 - 0x439cd000 	D:\dev\eclipse3.6\configuration\org.eclipse.osgi\bundles\226\1\.cp\swt-gdip-win32-3655.dll
0x74220000 - 0x743cb000 	C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6001.18175_none_9e7bbe54c9c04bca\gdiplus.dll
0x439d0000 - 0x439de000 	D:\dev\eclipse3.6\configuration\org.eclipse.osgi\bundles\58\1\.cp\os\win32\x86\localfile_1_0_0.dll
0x43aa0000 - 0x43aa8000 	D:\dev\eclipse3.6\configuration\org.eclipse.osgi\bundles\63\1\.cp\os\win32\x86\win32refresh.dll
0x77280000 - 0x77304000 	C:\Windows\system32\CLBCatQ.DLL
0x6f400000 - 0x6f430000 	C:\Windows\system32\mlang.dll
0x74090000 - 0x7409f000 	D:\dev\eclipse3.6\configuration\org.eclipse.osgi\bundles\61\1\.cp\jWinHttp-1.0.0.dll
0x72b80000 - 0x72be0000 	C:\Windows\system32\WINHTTP.dll
0x74d70000 - 0x74d75000 	C:\Windows\system32\msimg32.dll
0x6d180000 - 0x6d1c2000 	C:\tools\Virtual Dimension\HookDLL.dll
0x6fbc0000 - 0x6fbc7000 	C:\Windows\system32\mingwm10.dll
0x73900000 - 0x739bb000 	C:\Windows\system32\propsys.dll
0x6eec0000 - 0x6eee2000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libapr-1.dll
0x6ee50000 - 0x6ee59000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libapriconv-1.dll
0x4faa0000 - 0x4fba9000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libeay32.dll
0x71710000 - 0x71717000 	C:\Windows\system32\WSOCK32.dll
0x4d2e0000 - 0x4d316000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\ssleay32.dll
0x6ee60000 - 0x6ee8f000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libaprutil-1.dll
0x73be0000 - 0x73cf5000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\dbghelp.dll
0x43b50000 - 0x43b63000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsasl.dll
0x4f3a0000 - 0x4f44a000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsvn_subr-1.dll
0x71690000 - 0x71695000 	C:\Windows\system32\SHFOLDER.dll
0x753a0000 - 0x75491000 	C:\Windows\system32\CRYPT32.dll
0x75500000 - 0x75512000 	C:\Windows\system32\MSASN1.dll
0x4d320000 - 0x4d336000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsvn_delta-1.dll
0x43b70000 - 0x43b7d000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsvn_diff-1.dll
0x4d340000 - 0x4d375000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsvn_wc-1.dll
0x4f450000 - 0x4f471000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsvn_fs-1.dll
0x4f7a0000 - 0x4f7c2000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsvn_repos-1.dll
0x4f7d0000 - 0x4f84f000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsvn_ra-1.dll
0x4f850000 - 0x4f882000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsvn_client-1.dll
0x4f890000 - 0x4f8ba000 	D:\dev\eclipse3.6\plugins\org.tigris.subversion.clientadapter.javahl.win32_1.6.13\libsvnjavahl-1.dll
0x73d40000 - 0x73da6000 	C:\Windows\system32\MSVCP60.dll
0x73520000 - 0x735d3000 	C:\Windows\system32\WindowsCodecs.dll
0x4fbb0000 - 0x4fbc7000 	C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll
0x4fbe0000 - 0x4fbee000 	D:\dev\TortoiseSVN\bin\TortoiseStub.dll
0x50470000 - 0x50538000 	D:\dev\TortoiseSVN\bin\TortoiseSVN.dll
0x4fc30000 - 0x4fc52000 	D:\dev\TortoiseSVN\bin\libapr_tsvn.dll
0x50270000 - 0x5029e000 	D:\dev\TortoiseSVN\bin\libaprutil_tsvn.dll
0x502b0000 - 0x502c2000 	D:\dev\TortoiseSVN\bin\intl3_tsvn.dll
0x72df0000 - 0x72e7e000 	C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_none_5090ab56bcba71c2\MSVCP90.dll
0x501a0000 - 0x501b7000 	C:\tools\Dropbox\DropboxExt.13.dll
0x7c3a0000 - 0x7c41b000 	C:\tools\Dropbox\MSVCP71.dll
0x705c0000 - 0x70655000 	C:\Windows\System32\cscui.dll
0x71480000 - 0x71489000 	C:\Windows\System32\CSCDLL.dll
0x72310000 - 0x7231b000 	C:\Windows\System32\CSCAPI.dll
VM Arguments:
jvm_args: -Dosgi.requiredJavaVersion=1.6 -Declipse.p2.unsignedPolicy=allow -Xms128m -Xmx512m -Xss4m -XX:PermSize=128m -XX:MaxPermSize=384m -XX:CompileThreshold=5 -XX:MaxGCPauseMillis=10 -XX:MaxHeapFreeRatio=70 -XX:+CMSIncrementalPacing -XX:+UnlockExperimentalVMOptions -XX:+UseG1GC -XX:+UseFastAccessorMethods -Dcom.sun.management.jmxremote
java_command: <unknown>
Launcher Type: generic
Environment Variables:
JAVA_HOME=c:\jdk1.6.0
PATH=C:/jdk1.6.0/jre/bin/server;C:/jdk1.6.0/jre/bin;C:/jdk1.6.0/jre/lib/i386;C:\Program Files\sdb\programs\bin;C:\Program Files\sdb\programs\pgm;C:\dev\SubversionClient1.6;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;c:\jdk1.6.0\bin;C:\cygwin\bin;C:\dev\Microsoft SQL Server\90\Tools\binn\;D:\dev\apache-ant-1.7.1\bin;D:\projects\adam300\adam\mig-master\lib\native;;D:\dev\groovy-1.7.2\bin;D:\dev\TortoiseSVN\bin;d:\dev\Mercurial;C:\Windows\System32\WindowsPowerShell\v1.0\
USERNAME=jm
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows Vista Build 6001 Service Pack 1
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 3404536k(756716k free), swap 7049740k(3435636k free)
vm_info: Java HotSpot(TM) Server VM (17.1-b03) for windows-x86 JRE (1.6.0_22-b04), built on Sep 15 2010 00:49:59 by "java_re" with MS VC++ 7.1 (VS2003)
time: Mon Nov 08 10:47:39 2010
elapsed time: 103 seconds
[Updated on: Mon, 08 November 2010 10:02] by Moderator
Previous Topic:Eclipse Out Of Memory (jvm & ram memory size)
Next Topic:Alternative dependency sets for a common plug-in hierarchy
Current Time: Sat Jul 19 16:46:37 EDT 2025
Powered by FUDForum. Page generated in 0.03557 seconds
