Home » Eclipse Projects » Remote Application Platform (RAP) » External Browser
External Browser [message #636014] Thu, 28 October 2010 19:34 Go to next message
I try to open an new browser window to display a PDF from our RAP
application. It works inside my app with the internal brawser but is I use
ExternalBrowser nothing happens
Any help is appriciated
Re: External Browser [message #636056 is a reply to message #636014] Fri, 29 October 2010 04:15 Go to previous messageGo to next message
could you share your code for opening the ExternalBrowser and what
browser do you use (IE, Firefox, Safari...)?
Best,
Ivan
Re: External Browser [message #636094 is a reply to message #636056] Fri, 29 October 2010 05:37 Go to previous messageGo to next message
Hi Ivan,
I use the code below. I am using Google Chrome as brpwser, but the idea is
to support all browsers.
ExternalBrowser.open("NEWWINDOW", "http://127.0.0.1:10082" + url,
ExternalBrowser.STATUS | ExternalBrowser.LOCATION_BAR |
ExternalBrowser.NAVIGATION_BAR);
"Ivan Furnadjiev" <ivan@eclipsesource.com> wrote in message
news:iadvke$dl8$1@news.eclipse.org...
> could you share your code for opening the ExternalBrowser and what browser
> Best,
> Ivan
>> use
Re: External Browser [message #636140 is a reply to message #636094] Fri, 29 October 2010 08:46 Go to previous messageGo to next message
Hi Ivan,
I tried EI then it works, any idea how to make this work with Chrome and
possible others?
Koos
"Koos de Goede" <koosdegoede@hotmail.com> wrote in message
news:iae4dc$muj$1@news.eclipse.org...
> Hi Ivan,
>> Hi,
>> Best,
>> Ivan
>>> use
Re: External Browser [message #636143 is a reply to message #636140] Fri, 29 October 2010 09:12 Go to previous messageGo to next message
I've just tested it in Google Chrome 7.0.517.41 and it works as
expected. Make sure that the new opened window is not blocked by the
Chrome pop-up blocker. Look at right side of the address bar for a
pop-up blocker icon. If it's there enable pop-ups from 127.0.0.1 and
reload the browser window.
HTH,
Ivan
On 10/29/2010 3:46 PM, Koos de Goede wrote:
> Hi Ivan,
> possible others?
> Koos
> "Koos de Goede"<koosdegoede@hotmail.com> wrote in message
>> Hi Ivan,
>> "Ivan Furnadjiev"<ivan@eclipsesource.com> wrote in message
>>> Hi,
>>> Best,
>>> Ivan
>>>> use
Re: External Browser [message #637176 is a reply to message #636143] Thu, 04 November 2010 09:20 Go to previous messageGo to next message
Opening the external browser with a PDF now works on my local system.
However if I run the application on an external Server (Windows Server) also
from whitin Eclipse the external browser does not open.
I use an URL like this:
/balances/test.pdf
The balanes directory has been added using the extensionpoint:
<extension
point="org.eclipse.equinox.http.registry.resources">
<resource
alias="/balances"
base-name="/balances">
</resource>
Any idea why this not work in this case?
Koos
news:iaeh0r$ejg$1@news.eclipse.org...
> I've just tested it in Google Chrome 7.0.517.41 and it works as expected.
> Make sure that the new opened window is not blocked by the Chrome pop-up
> blocker. Look at right side of the address bar for a pop-up blocker icon.
> If it's there enable pop-ups from 127.0.0.1 and reload the browser window.
> HTH,
> Ivan
>> Hi Ivan,
>> possible others?
>> Koos
>>> Hi Ivan,
>>> is
>>>> Hi,
>>>> Best,
>>>> Ivan
>>>>> use
Re: External Browser [message #637189 is a reply to message #637176] Thu, 04 November 2010 10:32 Go to previous message
Koos,
You will need to use an absolute URL with ExternalBrowser. I'm not sure how it works in some cases, maybe there are some tricks going on in the browser. ExternalBrowser is basically the same thing as opening a new browser window yourself and typing in the url, it needs the full url.
Hope that helps,
Cole
Previous Topic:Closing browser or browser-tab after workbench close
Next Topic:RAP Startup Page
Current Time: Sat Jul 19 11:56:55 EDT 2025
Powered by FUDForum. Page generated in 0.05738 seconds
