Home » Modeling » TMF (Xtext) » [SOLVED] model query with xTend(How can be found an element of a collection in xTend?)
[SOLVED] model query with xTend [message #637104] Thu, 04 November 2010 04:46 Go to next message
I have problems to determine whether a collection contains a certain element.
I use the following grammar (it is shown only partly).
gcsDefinitions: {gcsDefinitions}
	(datatypes+=Datatype)*
	'attributes' (attributes+=Attribute)* 'end'
	'timerAttributes' '{' (timerAttributes+=TimerAttribute)+ '}'
TimerAttribute:
	name=ID;
Timer:
    'timer' name=ID
    ('attributes' (timerAttributes+=[TimerAttribute])*)?
    'timeconfig' (timeConfigPar=[ParTag]
              |timerValue=TimeValue|'stateDefined')
    ('IN' in=[Tag])?
    'end_timer';
The model looks like:
timerAttributes {ton withOutputTag withParameter restartable recalcable}
timer TransitionTime
attributes ton recalcable withOutputTag
timeconfig stateDefined
end_timer
The question is now, how can I check with xPand/xText whether a timer has a particular attribute?
[Updated on: Thu, 04 November 2010 06:07] by Moderator
Re: model query with xTend [message #637108 is a reply to message #637104] Thu, 04 November 2010 05:03 Go to previous messageGo to next message
Something like
Boolean hasAttribute(Timer timer, String name) : timer. timerAttributes.exists( a | a.name == name);
should do the trick (as an Xtend function; the right hand suffices for Xpand).
[Updated on: Thu, 04 November 2010 05:05] by Moderator
Re: model query with xTend [message #637117 is a reply to message #637104] Thu, 04 November 2010 05:29 Go to previous messageGo to next message
Many thanks for your help, it works!
Do you have any suggestions where I can get more information, documentation about the xPand/xTend functionality and syntax?
The 'Getting started' Tutorial I understand, but now I miss more detailed documentation.
Do exist books about this topic?
Do I have to learn more about EMF?
Re: model query with xTend [message #637128 is a reply to message #637117] Thu, 04 November 2010 06:02 Go to previous message
The reference documentation: http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .xpand.doc/help/ch01.html
AFAIK, there are no books on Xpand/Xtend/Xtext (not the dead tree-variant, anyway). It never hurts to learn (more) about EMF and there are books on that, although I've never read one: the reference documentation usually suffices.
Previous Topic:examples of ecore post processing
Next Topic:Linking to overloaded methods - getAllContents shouldn't be called on a global scope during linking
Current Time: Sat Jul 19 11:14:26 EDT 2025
Powered by FUDForum. Page generated in 0.08548 seconds
