Problem Using Resource URIs to Import Existing EPackages [message #636470] |
Mon, 01 November 2010 09:54  |
In my grammar, I import an ecore model to type elements of my rules. I have an import statement referring to the Ecore file I want to import in my Grammar like this:
import 'platform:/resource/org.example.dataModel/model/DataModel.ecore' as dmodel
I have configured the generator fragment in my MWE file
// generates Java API for the generated EPackages
fragment = ecore.EcoreGeneratorFragment {
referencedGenModels = "platform:/resource/org.example.dataModel/model/DataModel.genmodel"}
When I generate I do not get any errors in the consol. However, when I create an editor file in the Eclipse run-time instance, I get the error below in the consol, which complains about the non-existance of an IResourceServiceProvider. I have looked into the documentation but it was too difficult for me to follow, as I have a limited Java skills (coming from database administeration background). Would it be possible to help me solve this problem or explain to me how to implement an IResourceServiceProvider?
Note: previousely, I was importing an ecore metamodel using a NsURI and it worked fine without any extra coding, but now I want to use an ecore model rather than the ecore metamodel, and according to documentation, for that purpose, I should use a resource URI instead of a NSURI
Thanks in advance
0 [Worker-1] WARN org.eclipse.xtext.linking.lazy.LazyLinkingResource - resolution of uriFragment 'xtextLink_::0.2.2.2::0::/0' failed.
java.lang.IllegalStateException: No IResourceServiceProvider found in registry for uri platform:/resource/final.test/EmpMgtSys.datamodel
at org.eclipse.xtext.scoping.impl.LoadOnDemandResourceDescriptions.getResourceDescription(LoadOnDemandResourceDescriptions.java:57)
at org.eclipse.xtext.scoping.impl.ImportUriGlobalScopeProvider.createLazyResourceScope(ImportUriGlobalScopeProvider.java:100)
at org.eclipse.xtext.scoping.impl.ImportUriGlobalScopeProvider.getScope(ImportUriGlobalScopeProvider.java:70)
at org.eclipse.xtext.scoping.impl.AbstractGlobalScopeDelegatingScopeProvider.getGlobalScope(AbstractGlobalScopeDelegatingScopeProvider.java:32)
at org.eclipse.xtext.scoping.impl.SimpleLocalScopeProvider.getScope(SimpleLocalScopeProvider.java:61)
at org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.delegateGetScope(AbstractDeclarativeScopeProvider.java:72)
at org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.getScope(AbstractDeclarativeScopeProvider.java:102)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getScope(DefaultLinkingService.java:49)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:103)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:94)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:219)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:202)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:262)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1475)
at org.xtext.myOperations.impl.AddedClassImpl.getAddedClass(AddedClassImpl.java:77)
at org.xtext.myOperations.impl.AddedClassImpl.eGet(AddedClassImpl.java:121)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1013)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1005)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:409)
at org.eclipse.xtext.EcoreUtil2.resolveCrossReferences(EcoreUtil2.java:489)
at org.eclipse.xtext.EcoreUtil2.resolveAll(EcoreUtil2.java:473)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:122)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:60)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:79)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:1)
at org.eclipse.xtext.util.concurrent.IStateAccess$AbstractImpl.readOnly(IStateAccess.java:40)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:70)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(ValidationJob.java:75)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:64)
Re: Problem Using Resource URIs to Import Existing EPackages [message #636550 is a reply to message #636470] |
Mon, 01 November 2010 16:24  |
Xtext uses a IResourceServiceProvider to create ResourceDescriptions out of model files.
Xtext comes with an implementation for .ecore files and generates an implementation for each dsl.
if you use an own ecore based metamodel you have to provide an implementation too.
the easiest way to do is creating a copy & paste implementation starting with the one Xtext provides for ecore.
You find it in the plugins
- org.eclipse.xtext.ecore
- org.eclipse.xtext.ui.ecore
~Christian
[Updated on: Mon, 01 November 2010 16:24] by Moderator
FUDForum. Page generated in 0.04664 seconds
