Home » Modeling » EMF » Creating SelectEntry for Attributes of a Class
Creating SelectEntry for Attributes of a Class [message #636420] Mon, 01 November 2010 03:51 Go to next message
Hi All,
I was trying to retrieve all values stored for a class using Query2. I used the following code :-
ResourceSet rs = new ResourceSetImpl();
		QueryContext queryContext = getQueryContext(rs);
		QueryProcessor queryProcessor = QueryProcessorFactory.getDefault().createQueryProcessor(IndexFactory.getInstance());
		SelectEntry select = new SelectAlias("obj");
		FromType from = new FromType(/* aliasName */"obj", /* type URI */
		eClassURI, /* withoutsubtypes */false);
		Query query = new Query(new SelectEntry[] { select }, new FromEntry[] { from });
		ResultSet resultSet = queryProcessor.execute(query, queryContext);
		return resultSet;
The above snippet represents a query:-
Search:
from eClass /* Variable */ as obj select obj
But here the SelectEntry is only for the class and not for its attributes.
I want to create a SelectEntry for the attributes. I have the attributes retrieved but i have no idea about the format to be used to use those attributes in the code. How can i create a java code like the above for a query which is something like this :-
Search:
from eClass /* Variable */ as obj select obj.attribute1, obj.attribute2
[Updated on: Mon, 01 November 2010 03:54] by Moderator
Re: Creating SelectEntry for Attributes of a Class [message #636425 is a reply to message #636420] Mon, 01 November 2010 04:45 Go to previous messageGo to next message
Hi Animesh,
You can specify attributes like this.
SelectAttrs selectMeName = new SelectAttrs("mm", new String[] { "name", "attrInt1" });
SelectEntry[] selectEntries = new SelectEntry[] { selectMeName };
Where mm is alias and the String array having all the attributes.
Check the SelectAttrs class.
Hope this helps.
cheers,
Saurav
[Updated on: Mon, 01 November 2010 04:46] by Moderator
Re: Creating SelectEntry for Attributes of a Class [message #636486 is a reply to message #636425] Mon, 01 November 2010 10:55 Go to previous message
Thanx Saurav,
That was exactly what i wanted Smile and its working now Smile
Previous Topic:Problem instantiating model
Next Topic:Modelling XBRL Taxonomy
Current Time: Sat Jul 19 05:30:35 EDT 2025
Powered by FUDForum. Page generated in 0.05061 seconds
