Home » Archived » M2M (model-to-model transformation) » [QVTo] Use of extended metamodels in transformations
[QVTo] Use of extended metamodels in transformations [message #635686] Wed, 27 October 2010 13:32 Go to next message
Hi all,
my problem is related to extended metamodels. Let's suppose that I
have defined a metamodel by extending another existing one. When I open
the extended metamodel, the ecore editor shows a structure similar to
the following one:
platform:/resource/extended.ecore
|-- extended (package)
|--- ClassA
containedElements: ClassB (0..*) reference
platform:/resource/base.ecore
|-- base (package)
|--- ClassB
You can also see that ClassA contains 0 or more elements of kind ClassB.
The header of the transformation is the following one:
transformation Source2Extended(in inModel:source, out outModel:
extended);
modeltype source uses 'http://Source.ecore';
modeltype extended uses 'http://Extended.ecore';
that is, the extended metamodel is the output of the transformation.
My problem is that although metamodels are recognized by QVT, I cannot
navigate to ClassB. It seems as if the base package has disappear.
Can anyone give me a hint on how to access to the elements in the base
package?
Thanks in advance,
Toñi
Re: [QVTo] Use of extended metamodels in transformations [message #636296 is a reply to message #635686] Sat, 30 October 2010 09:46 Go to previous message
I solved the question by adding a modeltype sentence similar to the
following one:
modeltype base uses 'http://base.ecore';
El 27/10/2010 19:32, Toñi Reina Quintero escribió:
> Hi all,
> my problem is related to extended metamodels. Let's suppose that I have
> defined a metamodel by extending another existing one. When I open the
> extended metamodel, the ecore editor shows a structure similar to the
> following one:
> |--- ClassA
> |-- base (package)
> |--- ClassB
> transformation Source2Extended(in inModel:source, out outModel: extended);
> package?
> Thanks in advance,
> Toñi
Previous Topic:[ATL] How use UML Primtives Types in Target Model
Next Topic:[ATL] metamodel element direct copy source to target
Current Time: Sat Jul 19 10:00:36 EDT 2025
Powered by FUDForum. Page generated in 0.03988 seconds
