Home » Archived » BIRT » SQL query bulder error(Error when using date_sub)
SQL query bulder error [message #634732] Fri, 22 October 2010 16:52 Go to next message
It must be something I overlooked.
The following where clause is rejected by query builder:
WHERE time < date_sub(now(), interval 10 minute)
It works with native sql( I use mysql).
Re: SQL query bulder error [message #636244 is a reply to message #634732] Fri, 29 October 2010 16:14 Go to previous message
The syntax used, such as "interval 10 minute" seems to be in a db-specific SQL dialect.
The SQB's SQL parser can only handle standard SQL syntax.
To use queries in a SQL dialect syntax, BIRT's SQL textual editor would be a better fit, as it simply pass a SQL query to the connected DBMS for processing.
Linda
Previous Topic:Programmatic manipulation of report designs
Next Topic:How to run report in client eclipse
Current Time: Sat Jul 19 11:43:50 EDT 2025
Powered by FUDForum. Page generated in 0.03982 seconds
