Home » Archived » Test and Performance Tools Platform (TPTP) » New to TPTP & Eclipse - Problem
New to TPTP & Eclipse - Problem [message #636204] Fri, 29 October 2010 12:01 Go to next message
I got the TPTP from "Install New Software". I then downloaded the GUI recorder and placed it in the dropin folder. I did new Automated GUI test case and it was fine. The problem occurred when I clicked the red button for "new gui test case". The problem then showed up and said " unhandled loop exception.
I am in dire need of help. thx in advance.
The stack trace is below:
eclipse.buildId=M20100909-0800
java.version=1.6.0_21
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
Error
Thu Oct 28 23:45:25 EDT 2010
Unhandled event loop exception
java.lang.IllegalArgumentException: Index out of bounds
at org.eclipse.swt.SWT.error(SWT.java:4064)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.SWT.error(SWT.java:3969)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Combo.getItem(Combo.java:675)
at org.eclipse.tptp.test.auto.gui.internal.dialogs.AutoGUIInput CollectorDialog.createPerscmbox(AutoGUIInputCollectorDialog. java:178)
at org.eclipse.tptp.test.auto.gui.internal.dialogs.AutoGUIInput CollectorDialog.createMetaDataComposite(AutoGUIInputCollecto rDialog.java:125)
at org.eclipse.tptp.test.auto.gui.internal.dialogs.AutoGUIInput CollectorDialog.openDialog(AutoGUIInputCollectorDialog.java: 300)
at org.eclipse.tptp.test.auto.gui.internal.actions.AutoGUIRecor dAction.run(AutoGUIRecordAction.java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Re: New to TPTP & Eclipse - Problem [message #638025 is a reply to message #636204] Tue, 09 November 2010 11:28 Go to previous message
Hi Sher,
In TPTP 4.5, the AGR was moved from a Technology Preview component to an As-Is component. As-Is components are primarily provided for prior users but imply no support (for example, defects, news group, and mailing lists).
Previous Topic:unhandled event loop exception and tptp
Next Topic:problems with running a simple tptp
Current Time: Sat Jul 19 08:18:24 EDT 2025
Powered by FUDForum. Page generated in 0.03974 seconds
