Home » Modeling » EMF » How to draw a SWT composite in a GEF container shape and diagram
How to draw a SWT composite in a GEF container shape and diagram [message #635966] Thu, 28 October 2010 14:47 Go to next message
I would like to display an swt composite on a GEF container shape. Is is possible?
I have a complex widget that was done in Swing and I would like to use the AWT/SWING/SWT
Bridge to display this widget inside a container shape of a EMF diagram.
My idea is to use the EMF framework to move and resize my Swing widget.
However, the AWT/SWT Bridge requires a SWT composite to integrate its jframe inside swt.
How could I achieve this? Is there any example?
Vincent L.
Re: How to draw a SWT composite in a GEF container shape and diagram [message #636003 is a reply to message #635966] Thu, 28 October 2010 17:46 Go to previous messageGo to next message
Vincent,
I don't see that this is an EMF question. It sounds like you should
use the SWT or GEF newsgroup.
Vincent L. wrote:
> is possible?
> the AWT/SWING/SWT
> jframe inside swt.
> Thanks
> Regards,
> Vincent L.
Re: How to draw a SWT composite in a GEF container shape and diagram [message #636131 is a reply to message #636003] Fri, 29 October 2010 08:35 Go to previous message
Sorry Ed,
It's my mistake...
Vincent
Previous Topic:Zip & encrypt resource
Next Topic:How to Extend Ecore Model with Extension XML Schema
Current Time: Sat Jul 19 13:08:49 EDT 2025
Powered by FUDForum. Page generated in 0.03680 seconds
