Home » Eclipse Projects » Rich Client Platform (RCP) » WorkbenchWindowAdvisor question
WorkbenchWindowAdvisor question [message #635086] Mon, 25 October 2010 11:27 Go to next message
Hi all,
I have a question regarding the WorkbenchWindowAdvisor. I currently have an application that has a WorkbenchWindowAdvisor that creates a Menu. The items that appear on the menu are determined by plugins that use an extension point defined in the application. When a menu item is clicked, the plugin that defined that menu element opens a new workbench window with a new perspective. My issue is that every new workbench window opened contains the menu of the main application, and I don't want it to. Is there a way from within the called plugin to override the behavior of the main app's WorkbenchWindowAdvisor? Perhaps define a new WorkbenchWindowAdvisor for that specific workbench window? How would I go about doing this, since PlatformUI.getWorkbench().openWorkbenchWindow does not take an advisor like createAndRunWorkbench does?
Thanks!
Jim
Re: WorkbenchWindowAdvisor question [message #635129 is a reply to message #635086] Mon, 25 October 2010 12:55 Go to previous messageGo to next message
The place to do it would be in your
org.eclipse.ui.application.WorkbenchAdvisor.createWorkbenchW indowAdvisor(IWorkbenchWindowConfigurer)
You can create a different Advisor for the second window.
You'll have to dig through the information available at that point to
see if you can tell you're on the second window, or your special window.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: WorkbenchWindowAdvisor question [message #635138 is a reply to message #635129] Mon, 25 October 2010 13:45 Go to previous messageGo to next message
Paul,
Thank you very much, that is exactly what I was looking for!
-- Jim
Re: WorkbenchWindowAdvisor question [message #635154 is a reply to message #635086] Mon, 25 October 2010 15:12 Go to previous message
As I wade in to this further, I am having a hard time figuring out the best approach to relay what the window type is to the WorkbenchAdvisor. Is there some way to pass a uniqueID to the Advisor based upon the WorkbenchWindow it is trying to create? Can the IWorkBenchWindowConfigurer be modified by the plugin to include an identifier in its setData? I know I can figure out some way to notify the advisor, but I am looking for a solid approach - I don't want to hack it Smile
Thanks!
Jim
Previous Topic:Implement an Alert View
Next Topic:License of an Eclipse RCP application?
Current Time: Sat Jul 19 05:32:09 EDT 2025
Powered by FUDForum. Page generated in 0.23861 seconds
