Home » Archived » Test and Performance Tools Platform (TPTP) » I have found the execution log problem for AGR!
I have found the execution log problem for AGR! [message #63079] Fri, 31 March 2006 04:59 Go to next message
I use the AGR to record the actions
And then I quick run my case.
After that I run it in standard mode.
It seems OK!
And my suites go to the end
At last, I check the execution file!
It stoped in one step and the invocation have only a start symbol.
Re: I have found the execution log problem for AGR! [message #63405 is a reply to message #63079] Sat, 01 April 2006 12:23 Go to previous messageGo to next message
What is the build you are using?
Are you using the standalone Agent Controller(AC) or the Integrated Agent
Controller(IAC) that comes with the workbench?
Lastly, what is your operating system?
Can you switch between AC and IAC to see if you notice any change in the
behavior.
"simoom" <hugulas@gmail.com> wrote in message
news:e0iubg$1ac$1@utils.eclipse.org...
> It seems OK!
Re: I have found the execution log problem for AGR! [message #63495 is a reply to message #63405] Sun, 02 April 2006 23:25 Go to previous messageGo to next message
both tptp4.2 and tptp 4.1.0.1 sdk
And my os is windows xp
"Ali Mehregani" <amehrega@ca.ibm.com> д
Re: I have found the execution log problem for AGR! [message #63517 is a reply to message #63405] Mon, 03 April 2006 05:20 Go to previous messageGo to next message
And I have tried AC.No changes!
And the RC log increased when I run the test suite in standard mode
Re: I have found the execution log problem for AGR! [message #63538 is a reply to message #63405] Mon, 03 April 2006 05:46 Go to previous message
I have tried the local direct connection
It works well now!
Thank u very much!
Previous Topic:Runtime options for AGR
Next Topic:GLA: Is it extensible ?
Current Time: Sun Jul 20 12:49:10 EDT 2025
Powered by FUDForum. Page generated in 0.04332 seconds
