[CDO] QuickStartTest with Spring/Teneo/Hibernate stack [message #634040] |
Wed, 20 October 2010 07:10  |
Hi all,
we are trying to set up CDO for use in a JavaEE application on the server side and RCP as client. Therefore we have adjusted the org.eclipse.emf.cdo.examples.spring example to use Teneo/Hibernate in a standalone environment, where we took the initialization from org.eclipse.emf.cdo.examples.hibernate.server.
So far the server starts up, CDO tables are created in the database etc. But now we are stuck with the client, where we take the QuickStartTest from org.eclipse.emf.cdo.examples.hibernate.client. When we understand correctly this we should not need any modifications to this code. However, we run in a problem when creating the resource.
final CDOSession session = openSession();
final CDOTransaction transaction = session.openTransaction();
// get/create a resource
CDOResource resource = transaction.getOrCreateResource("/res1"); //$NON-NLS-1$
The last line fails, since there is no root resource. The session object is ready, we have a transaction.
In CDOViewImpl#getRootResource() there is the following line:
CDOID rootResourceID = session.getRepositoryInfo().getRootResourceID();
As result we get the CDOIDNullImpl instance.
On the server side after initialization we get a dump from the Repository on the console (we use Repository$Default and run activate() on it before use). This dump also says that the rootResourceId is null.
Does anyone know what has to be initialized/changed to get this setup working? Any hints appreciated.
~Karsten
Re: [CDO] QuickStartTest with Spring/Teneo/Hibernate stack [message #634048 is a reply to message #634040] |
Wed, 20 October 2010 07:36   |
Hi Karsten,
the root resource is created on the server side of CDO.
The code responsible for this is
org.eclipse.emf.cdo.internal.server.Repository.initRootResou rce()
which is called in Repository.doActivate().
Could you set a breakpoint there and have a look what's going on?
Stefan
On 20.10.2010 13:10, Karsten Thoms wrote:
> Hi all,
> //$NON-NLS-1$
> ~Karsten
Re: [CDO] QuickStartTest with Spring/Teneo/Hibernate stack [message #634134 is a reply to message #634118] |
Wed, 20 October 2010 11:16  |
Hi Karsten,
Great that you found this..., I was travellling so I did not see your post earlier, enter a bugzilla and I will take
care of it asap.
gr. Martin
On 10/20/2010 04:54 PM, Karsten Thoms wrote:
> OK, we are through. We stumbled over one issue in
> TeneoHibernateMappingProvider:
> In method generateMapping() the EcorePackage and EresourcePackage are
> removed by reference from the list of packages that should be generated:
> // translate the list of EPackages to an array
> final List<EPackage> epacks =
> getHibernateStore().getPackageHandler().getEPackages();
> // remove the ecore and resource package
> epacks.remove(EcorePackage.eINSTANCE);
> epacks.remove(EresourcePackage.eINSTANCE);
> But the PackageHandler retrieves other instances. These both packages
> must be removed by comparing their eNS_URI. Otherwise these packages are
> not removed from 'epacks' and with restarting the server it fails with a
> DuplicateMappingException.
> I think I will open a bug for that soon.
> Thanks again for listening!
> ~Karsten
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.06032 seconds
