modify the semantic model in the table viewer [message #634036] |
Wed, 20 October 2010 06:53  |
I am sorry if I am asking in the wrong newsgroup.
I have created a GMF editor, which contains some edges. The edge owns a list of variable elements. Those variables do not have views, they can be created in the semantic model, the model is saved together with the graphical models in the shared file.
I have created a table viewer window upon double-click on the edge for editing the variable list. The AdapterFactoryContentProvider is attached to the tableviewer. It works very well for displaying the variables.
Then, I would like to modify (editing, add, remove) the variables via the table viewer.
in my ICellModifier() of my viewer, in the modify() method, I did something like:
TransactionalEditingDomain ed = TransactionUtil.getEditingDomain(variable);
Command command = SetCommand.create(ed, variable, CommonPackage.Literals.NAMED_COMPONENT__NAME, value.toString());
boolean isExecutable= command.canExecute();
ed.getCommandStack().execute(command );
The isExecutable is always false. And the execution gives an Cannot activate read/write transaction in read-only transaction context Exception.
Please help me with this problem, Is it correct to modify the semantic model this way? How can I modify the semantic model in the table viewer.
-Wei
Re: modify the semantic model in the table viewer [message #634133 is a reply to message #634036] |
Wed, 20 October 2010 11:15   |
Wei,
Comments below.
ayia wrote:
> variables.
> the table viewer.
> something like: ----------
You've traced this with the debugger to see why it's returning false?
> Exception.
> -Wei
Re: modify the semantic model in the table viewer [message #634695 is a reply to message #634558] |
Fri, 22 October 2010 13:56  |
Wei,
Perhaps you should post to the display thread to do this while you're
not in the middle of opening something.
ayia wrote:
> Hi Ed,
> I have tried to trace it. The canExecute gives true. but during
> execution it throws exception.
> java.lang.IllegalStateException: Cannot activate read/write
> at org.eclipse.emf.transaction.impl.TransactionalEditingDomainI
> mpl.acquire(TransactionalEditingDomainImpl.java:576)
> mpl.activate(TransactionalEditingDomainImpl.java:508)
> at org.eclipse.emf.transaction.impl.TransactionImpl.start(Trans
> actionImpl.java:204)
> at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.cre
> ateTransaction(WorkspaceCommandStackImpl.java:380)
> at org.eclipse.emf.workspace.EMFCommandOperation.createTransact
> ion(EMFCommandOperation.java:215)
> at org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr
> actEMFOperation.java:147)
> at org.eclipse.core.commands.operations.DefaultOperationHistory
> .execute(DefaultOperationHistory.java:511)
> at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doE
> xecute(WorkspaceCommandStackImpl.java:208)
> at org.eclipse.emf.transaction.impl.AbstractTransactionalComman
> dStack.execute(AbstractTransactionalCommandStack.java:165)
> dStack.execute(AbstractTransactionalCommandStack.java:219)
> at system.diagram.edit.parts.dialog.TableEditorComposite$3.modi
> fy(TableEditorComposite.java:185)
> I did some search in the forum, I guess the problem might be that my
> tabeviewer is opened in the getOpenCommand of an OpenEditPolicy, where
> I can not modify the semantic model. Is there some alternative ways?
> Thank you.
> Wei
FUDForum. Page generated in 0.04084 seconds
