Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Difficulties with variables
[Acceleo] Difficulties with variables [message #633900] Tue, 19 October 2010 14:11 Go to next message
I am pretty new to Acceleo, but after some initial difficulties I have been able to use it quite successfully so far.
However, the fact that all variables in Acceleo are final, i.e. cannot be modified after they are declared, is giving me quite a hard time. I understand that part of my problem is that I am new to OCL as well, but I hope you will be able to help. Despite I looked quite thoroughly through Acceleo and OCL documentation and MTL specification, I couldn't find anything similar to this.
Even something as simple as a counter is not so simple in Acceleo; I have tried what is described here:
http://www.eclipse.org/forums/index.php?t=msg&&th=19 986&goto=64949
but I couldn't get it working. Even the suggested solution of using the let statement inside the for loop does not seem to have the side effect of incrementing the general variable. Moreover, I don't see how this could work, given that variables are final.
Now, on to my specific problem. Let's say I have a Collection and I need to do something with each member of the Collection and store the result in a different variable in order to reuse it later. E.g. let's say I have a UML model of a Java class, with the list of getters and setters. I want to store the names of all the operations in a different variable Set(String). I have been able to retrieve all the setters, for example like this:
setters : Set(Operation) = (c.getOperations()->select(name.startsWith('set')));
but now how do I assign their names to a Set(String)?
A slightly more complicated thing would be if I also need to check some condition on the names. Or, if I need to compute something that depends on the value of each variable: a counter or something similar would be of use here, but values of variables cannot be modified...
Any ideas?
Thank you!
[Updated on: Tue, 19 October 2010 16:58] by Moderator
Re: [Acceleo] Difficulties with variables [message #633978 is a reply to message #633900] Wed, 20 October 2010 03:03 Go to previous messageGo to next message
Hi Simone,
If you want to collect all their names, you can do this:
c.getOperations()->select(name.startsWith('set'))->collect(oper | oper.name)
or
c.getOperations()->select(name.startsWith('set')).name
(both are the same since ".name" is here applied on a collection)
If you need a counter, you can iterate on your collection with a for and inside of that for you have access to a counter with a variable named "i".
Finally, I would advise you to use a query for something like "c.getOperations()->select(name.startsWith('set')).name" because a query would store the result in a cache and if you call it again with the same parameters we won't have to compute the result again. This query would looks like this:
[query public collectNameOfSetters(c : Class) : Set(String) = c.getOperations()->select(name.startsWith('set')).name/]
You could also store all your utility queries in a utility module in order to be able to easily access your queries from all your modules. You can see an example here: http://www.eclipse.org/forums/index.php?t=msg&goto=54763 2&S=54f46cd8651eb190524163fe9c3c70ca#msg_547632
Stephane Begaudeau, Obeo
Re: [Acceleo] Difficulties with variables [message #634642 is a reply to message #633978] Fri, 22 October 2010 10:39 Go to previous messageGo to next message
Hi Stephane,
first of all, thank for your quick reply. I couldn't test this until today. So, I had tried what you say before, i.e.:
or
and it works.
However, I finally found my problem: there seem to be something wrong when I try to assign the result of that function to a Set(String), through a "let" statement or an initialization statement.
In the case of the let statement, I don't get any compile-time or run-time error but the code inside the let statement is never executed:
[let attributes : Set(String) = c.getOperations()->select(name.startsWith('set')).name]
This statement is never entered.
[for (s : String | attributes)]
[s/]
[/for]
[/let]
In the case of the initialization statement:
[template public generatePropertySourceWoAttributeNames(c : Class){
getters : Set(Operation) = (c.getOperations()->select(name.startsWith('get') or name.startsWith('is')));
attributes : Set(String) = c.getOperations()->select(name.startsWith('get')).name;
[s/]
[/for]
I get an error on "attributes": "Init expression type does not conform to type of variable (attributes)."
However, a for loop on "getters" or "setters" above works perfectly.
Finally, putting the code in a query as you suggested works, unless I try to assign the result of the query to a Set(String) variable. It seems to be some issue with the Set(String) type, or the way the attribute is collected. I am a little unclear of why this happens, could you please explain? I am quite sure I am missing something.
Thank you.
[Updated on: Fri, 22 October 2010 11:38] by Moderator
Re: [Acceleo] Difficulties with variables [message #634953 is a reply to message #633900] Mon, 25 October 2010 04:21 Go to previous messageGo to next message
I'm sorry I've made a small mistake, c.getOperations()->select(name.startsWith('set'))->collect(oper | oper.name) or c.getOperations()->select(name.startsWith('set')).name would not return a set, here is why:
myCollection->collect(...) returns a collection with the same type as myCollection, here myCollection is the return type of the select, and the return type of the select is like the type of the collection on which the select is applied. And here the return type of c.getOperations()->select(name.startsWith('set'))->collect(oper | oper.name) is the type of c.getOperations(), which should be a Sequence.
Re: [Acceleo] Difficulties with variables [message #1694949 is a reply to message #634953] Sun, 10 May 2015 11:33 Go to previous messageGo to next message
How do I know if an operation is not 'get' and 'set'?
I know I can verify that begins with 'get' or 'set', but this can not represent 'get' or 'set' of an attribute.
Re: [Acceleo] Difficulties with variables [message #1694950 is a reply to message #634953] Sun, 10 May 2015 11:42 Go to previous messageGo to next message
c.getOperations () -> select (name.startsWith ('set')) only checks whether the operation begins with 'set' but how to know if this really represents a 'set' of an attribute?
Re: [Acceleo] Difficulties with variables [message #1695064 is a reply to message #1694949] Mon, 11 May 2015 13:47 Go to previous messageGo to next message
Your questions sound like classic newbie Java/model misunderstandings.
If you want a sensible answer you would do better to express your true
problem.
Answering your actual questions will almost certainly give you the wrong
answer to the wrong question.
Ed Willink
On 11/05/2015 14:05, Rafael Dantas wrote:
Re: [Acceleo] Difficulties with variables [message #1695073 is a reply to message #1695064] Mon, 11 May 2015 15:40 Go to previous messageGo to next message
Yes. I am new to java / model. Sorry if I was unclear.
Also I asked a question at the wrong topic. I saw the examples mentioned above and made my question here.
I need to know if there is any method other than 'get' or 'set'. I believe that not just whether begins with 'get' or 'set'. Think of the scenario, I have a simple class named Employee, which has the name attribute, getName and setName besides these have getSalary. Checking the memento generation m2t is getSalary is not a get an attribute?
Re: [Acceleo] Difficulties with variables [message #1695078 is a reply to message #1695073] Mon, 11 May 2015 16:34 Go to previous message
No. Your model has an Employee class and an Employee::name attribute.
Your generated Java API has setName/getName methods.
Ed Willink
Previous Topic:[XPAND]Unkown type while accessing multiple models
Next Topic:xpand to xtend2 type system migration
Current Time: Sun Jul 20 15:06:01 EDT 2025
Powered by FUDForum. Page generated in 0.04187 seconds
