Home » Eclipse Projects » Eclipse Platform » Security Applet Alert in Eclipse
Security Applet Alert in Eclipse [message #527648] Thu, 15 April 2010 18:32 Go to next message
I am using the java decompiler, JD-Eclipse in Eclipse.
The plugin is working properly but I have a lot of security alert like this one :
http://img10.hostingpics.net/pics/621989applet_alert.png
I tried to change the java.policy file like this :
grant {
	permission java.security.AllPermission;
Do you have any idea how I could get rid of this alert ?
Thanks for your help,
Sylvain.
Re: Security Applet Alert in Eclipse [message #527765 is a reply to message #527648] Fri, 16 April 2010 08:13 Go to previous messageGo to next message
> this one :
And the security alert is?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Security Applet Alert in Eclipse [message #527912 is a reply to message #527648] Fri, 16 April 2010 17:43 Go to previous messageGo to next message
You do not see the screenshot ?
It basically says this :
"The applet is attempting to access the "exists" state attributes of file <local jar file>"
The different states attributes could be : exists, isDirectory, isFile, ...
Re: Security Applet Alert in Eclipse [message #528537 is a reply to message #527648] Tue, 20 April 2010 16:37 Go to previous messageGo to next message
Any idea ?
Re: Security Applet Alert in Eclipse [message #541610 is a reply to message #527648] Mon, 21 June 2010 14:41 Go to previous messageGo to next message
I figured it out.
The issue was the proxy and the anti-virus product we are using at work. The anti virus altered the jar file to add some protection ( http://fr.trendmicro.com/fr/products/enterprise/interscan-we b-security-suite/).
Re: Security Applet Alert in Eclipse [message #633820 is a reply to message #541610] Tue, 19 October 2010 10:11 Go to previous messageGo to next message
Hi there,
we' re experiencing the same problem...do you remember what changes have you done?
Re: Security Applet Alert in Eclipse [message #633823 is a reply to message #633820] Tue, 19 October 2010 10:14 Go to previous messageGo to next message
I didn't change the proxy configuration (i am not in charge of it anyway).
I basically zipped at home the file needed and sent them to me.
Re: Security Applet Alert in Eclipse [message #633825 is a reply to message #633823] Tue, 19 October 2010 10:29 Go to previous messageGo to next message
Hi Sylvain,
what do you mean you have received a file...and from whom? The antivirus software house?
Re: Security Applet Alert in Eclipse [message #633828 is a reply to message #633825] Tue, 19 October 2010 10:33 Go to previous messageGo to next message
i downloaded from my home internet connection (no anti-virus) the jar files, zip them (so the anti-virus won't detect it as jar files and won't add its stuff) and send them to me by email.
Anyway, you IT/ Network team should be able to help you with that.
Re: Security Applet Alert in Eclipse [message #636434 is a reply to message #633828] Mon, 01 November 2010 06:03 Go to previous messageGo to next message
Even I was facing this problem.
You can use the -Djava.awt.headless=true setting while running in command prompt or add this as parameter before running your server. You can see details in the link below.
http://sites.google.com/site/javaerrorsandsolutions/home/mav en---applet-error
Re: Security Applet Alert in Eclipse [message #636441 is a reply to message #633828] Mon, 01 November 2010 06:48 Go to previous message
Even we faced these erorrs.
All you need to do is add the magic words -Djava.awt.headless=true in the command which is used to run the server. For example, if you were using mvn -P[properties file name] -f [path of pom.xml file] -Djetty.port=9001 jetty:run then to prevent the applet alert change the command as below
mvn -P[properties file name] -f [path of pom.xml file] -Djetty.port=9001 -Djava.awt.headless=true jetty:run.
For more details visit the link below.
Previous Topic:Misplaced view toolbar
Next Topic:eclipse helios crashing and crashing
Current Time: Sat Jul 19 20:05:53 EDT 2025
Powered by FUDForum. Page generated in 0.03899 seconds
