Using ASTParser outside Eclipse [message #633585] |
Mon, 18 October 2010 09:14  |
Hi, I'm trying to use the JDT-Parser outside the Eclipse context. With the help of the Eclipse forums, I'm able to parse source files and to access them as ASTNodes:
class MinimalParser
ASTParser pars = ASTParser.newParser(AST.JLS3);
CLASS_PATH.add(".");
SOURCE_PATH.add("<path to some source directory>");
SOURCE_FILES.add("<path to a java source file>);
pars.setEnvironment(CLASS_PATH.toArray(new String[0]), SOURCE_PATH.toArray(new String[0]), null, true);
pars.setResolveBindings(true);
pars.setKind(ASTParser.K_COMPILATION_UNIT);
FileASTRequestor req = new FileASTRequestor() {
public void acceptAST(String sourceFilePath, CompilationUnit ast) {
ast.getRoot().accept(new MinimalVisitor());
pars.createASTs(SOURCE_FILES.toArray(new String[0]), null, new String[0], req, null);
class MinimalVisitor extends ASTVisitor {
public boolean visit(MethodDeclaration node) {
IMethodBinding binding = node.resolveBinding();
System.out.println(binding.getJavaElement());
return false;
The ".visit()" method is the point where I run into problems. As far as I can see, the ".getJavaElement()" Method should return an IJavaElement, but I actually get "null". With the Debugger I can point the "problem"(?) to
package org.eclipse.jdt.core.dom;
class MethodBinding
private JavaElement getUnresolvedJavaElement() {
if (!defaultBindingResolver.fromJavaProject) return null;
Obviously the resolver needs a java project when used this way, but as far as I unterstand this should not be necessary according to the description of "ASTParser.setEnvironment(...)". I'm not sure, if this is the right way to get IJavaElements or some type of ITypes or if there is another way, that actually works. Any hints, what I'm doing wrong or how to access ITypes out of Eclipse?
PS: I'm adding the following jars to my classpath to get the code running:
/* included jar files */
org.eclipse.core.contenttype_3.4.100.v20100505-1235.jar
org.eclipse.core.runtime_3.6.0.v20100505.jar
org.eclipse.equinox.common_3.6.0.v20100503.jar
org.eclipse.equinox.preferences_3.3.0.v20100503.jar
org.eclipse.core.jobs_3.5.1.R36x_v20100824.jar
org.eclipse.core.resources_3.6.0.R36x_v20100825-0600.jar
org.eclipse.jdt.core_3.6.1.v_A68_R36x.jar
org.eclipse.osgi_3.6.1.R36x_v20100806.jar
Re: Using ASTParser outside Eclipse [message #634677 is a reply to message #633585] |
Fri, 22 October 2010 13:25  |
IJavaElement are not available when using ASTParser outside of a headless Eclipse since there is no Java model initialized.
So what you are seeing is working as expected. If you want java elements, then you need to work inside a headless Eclipse where the JDT/Core bundle is initialized.
If you believe the documentation needs to be updated to better reflect this, then open a bug report against JDT/Core.
Olivier
[Updated on: Fri, 22 October 2010 13:28] by Moderator
FUDForum. Page generated in 0.03761 seconds
