Home » Eclipse Projects » GEF » Stange behaviour on resolution change
Stange behaviour on resolution change [message #632753] Thu, 14 October 2010 03:30 Go to next message
If I change resolution (control panel -> Display properties-> settings) of my system while my application is running, the layout of components get changed.
Initial screen:
http://i56.tinypic.com/1o6sus.jpg
After changing the resolution of my system:
http://i51.tinypic.com/bjbypw.jpg
I have written following code to demostrate my problem. The border selection in new thread is for showing the problem. In real app border is set by mouse click.
Following code is used to create the contents of my view
public void createPartControl (Composite parent)
		FigureCanvas main = new FigureCanvas(parent);
		main.setBackground(ColorConstants.lightBlue);
		main.setLayout(new FormLayout());
		Composite compositeModules = new Composite(main, SWT.NONE);
		compositeModules.setBackground(Display.getDefault().getSystemColor(SWT.COLOR_DARK_GRAY));
		GridLayout layout = new GridLayout();
		layout.numColumns = 2;
		layout.makeColumnsEqualWidth = true;
		layout.horizontalSpacing = 1;
		layout.verticalSpacing = 1;
		layout.marginWidth = 1;
		layout.marginHeight = 1;
		compositeModules.setLayout(layout);
		for (int i = 0; i < 2; i++)
			for (int j = 0; j < 2; j++)
				final ModuleCanvas moduleCanvas = new ModuleCanvas(compositeModules);
				GridData gridData = new GridData(SWT.CENTER);
				gridData.heightHint = 90;
				gridData.widthHint = 160;
				gridData.grabExcessHorizontalSpace = false;
				gridData.grabExcessVerticalSpace = false;
				moduleCanvas.setLayoutData(gridData);
				if (i == 0 && j == 0)
					new Thread()
						public void run ()
							try
								sleep(10000);
							catch (InterruptedException e)
								e.printStackTrace();
							Display.getDefault().asyncExec(new Runnable()
								public void run ()
									moduleCanvas.setBorder();
					}.start();
		compositeModules.pack();
public class ModuleCanvas
	extends FigureCanvas
	private LineBorder mLineBorder = new LineBorder();
	public ModuleCanvas(Composite parent)
		super(parent);
		mLineBorder.setWidth(10);
		mLineBorder.setColor(ColorConstants.blue);
		Figure f = new Figure()
			public void paint (Graphics graphics)
				super.paint(graphics);
				int width = this.getSize().width;
				int height = this.getSize().height;
				graphics.setBackgroundColor(ColorConstants.black);
				graphics.setForegroundColor(ColorConstants.gray);
				graphics.fillRectangle(0, 0, width, height);
				graphics.drawString("A01", 5, 5); // position
		f.setOpaque(true);
		f.setBackgroundColor(ColorConstants.white);
		this.setContents(f);
	public void setBorder ()
		this.setBorder(mLineBorder);
Can you please tell me what is wrong with the code? or how can i fix this?
Thanks in advance
Anubhav
Re: Stange behaviour on resolution change [message #632772 is a reply to message #632753] Thu, 14 October 2010 04:57 Go to previous messageGo to next message
why do u need a thread with 10sec delay for setting the border???
that said if i remove it the problem comes even in normal scanario...
So i think the problem is not with resolution change...
Re: Stange behaviour on resolution change [message #632784 is a reply to message #632772] Thu, 14 October 2010 05:18 Go to previous messageGo to next message
Thread with delay was to just reproduce the problem. With resolution change I can easily reproduce the problem. there may be some other cases also
Re: Stange behaviour on resolution change [message #632787 is a reply to message #632784] Thu, 14 October 2010 05:23 Go to previous message
try this...
     * This is a callback that will allow us to create the viewer and initialize it.
    public void createPartControl(Composite parent)
        org.eclipse.swt.layout.GridLayout layout = new org.eclipse.swt.layout.GridLayout();
                org.eclipse.swt.layout.GridData gridData = new org.eclipse.swt.layout.GridData(
                        SWT.CENTER);
                    // new Thread()
                    // @Override
                    // public void run()
                    // try
                    // sleep(10000);
                    // catch (InterruptedException e)
                    // // TODO Auto-generated catch block
                    // e.printStackTrace();
                    // Display.getDefault().asyncExec(new Runnable()
                    // @Override
                    // }.start();
                    // moduleCanvas.setBorder();
        // compositeModules.pack();
    public class ModuleCanvas extends FigureCanvas
            super(parent);
            Figure f = new RectangleFigure()
                public void paint(Graphics graphics)
            f.setBackgroundColor(ColorConstants.black);
            f.setOpaque(true);
            // f.setBackgroundColor(ColorConstants.white);
since it is happenen any way without thread,it will happen with thread for resolution change... Smile
[Updated on: Thu, 14 October 2010 05:27] by Moderator
Previous Topic:Different Routing for different type of connections
Next Topic:add new tab to the palette tool
Current Time: Sun Jul 20 08:14:11 EDT 2025
Powered by FUDForum. Page generated in 0.03630 seconds
