Home » Archived » B3 » UnsupportedOperationException with 3 repositories
UnsupportedOperationException with 3 repositories [message #630112] Thu, 30 September 2010 12:31 Go to next message
I'm still trying to mirror the eclipse helios update sites with the b3
aggregator.
Until now I was able to mirror the one repository on
http://download.eclipse.org/releases/helios/
Now I use a contribution with 3 mapped repositories:
- http://download.eclipse.org/releases/helios/
- http://download.eclipse.org/eclipse/updates/3.6/
- http://download.eclipse.org/technology/epp/packages/helios/
trying to run CLEAN_BUILD I only get this error:
Loading all repositories
Starting generation of composite repository Adding child meta-data
repository http://download.eclipse.org/releases/helios Adding child
meta-data repository http://download.eclipse.org/eclipse/updates/3.6
Adding child meta-data repository
http://download.eclipse.org/technology/epp/packages/helios Done. Took 0
seconds Starting generation of verification feature
Done. Took 0 seconds Starting generation of categories Build failed!
Exception was java.lang.UnsupportedOperationException:
java.lang.UnsupportedOperationException Finished: FAILURE
Where is my mistake?
Lars
Re: UnsupportedOperationException with 3 repositories [message #630164 is a reply to message #630112] Thu, 30 September 2010 16:45 Go to previous messageGo to next message
this does not look like your mistake :-)
Could you please enter a bugzilla issue and attach your b3aggr file so that both of us would work with exactly the same thing?
In addition to this, let me know which version of b3 aggregator you are using. Thanks.
I will look into that in the beginning of next week (I can't make it by the end of this week, sorry).
Filip
Dne 30.9.2010 18:31, Lars Fischer napsal(a):
> Hello,
> I'm still trying to mirror the eclipse helios update sites with the b3 aggregator.
> Until now I was able to mirror the one repository on http://download.eclipse.org/releases/helios/
> Starting generation of composite repository Adding child meta-data repository http://download.eclipse.org/releases/helios Adding child meta-data repository http://download.eclipse.org/eclipse/updates/3.6 Adding child meta-data repository http://download.eclipse.org/technology/epp/packages/helios Done. Took 0 seconds Starting generation of verification feature
> Done. Took 0 seconds Starting generation of categories Build failed! Exception was java.lang.UnsupportedOperationException: java.lang.UnsupportedOperationException Finished: FAILURE
> Regards,
> Lars
Re: UnsupportedOperationException with 3 repositories [message #630220 is a reply to message #630164] Fri, 01 October 2010 04:14 Go to previous messageGo to next message
Hello Filip,
Puh... ;)
> using. Thanks.
I filed a new issue at https://bugs.eclipse.org/bugs/show_bug.cgi?id=326742
Next week would be soon enough. Thank you very much!
Lars
Re: UnsupportedOperationException with 3 repositories [message #632104 is a reply to message #630220] Mon, 11 October 2010 10:36 Go to previous messageGo to next message
Hello Filip,
I apologize for asking again.
>> using. Thanks.
Is there something else, what I could provide to you?
Lars
Re: UnsupportedOperationException with 3 repositories [message #632170 is a reply to message #632104] Mon, 11 October 2010 17:09 Go to previous messageGo to next message
I think I have all I need, I just need to find some time. Hopefully tomorrow.
Filip
Dne 11.10.2010 16:36, Lars Fischer napsal(a):
> Hello Filip,
>>> using. Thanks.
> Regards,
> Lars
Re: UnsupportedOperationException with 3 repositories [message #632505 is a reply to message #632104] Wed, 13 October 2010 05:04 Go to previous messageGo to next message
Hello Lars,
I have found & fixed the bug. However, we have problems setting up a hudson build for updating the site on the new Eclipse build server. Stay tuned, I hope we'll fix it within a few days.
Filip
On 11.10.2010 16:36, Lars Fischer wrote:
> Hello Filip,
>>> using. Thanks.
> Regards,
> Lars
Re: UnsupportedOperationException with 3 repositories [message #632515 is a reply to message #632505] Wed, 13 October 2010 05:37 Go to previous messageGo to next message
No problem, I will watch this group.
Lars
Re: UnsupportedOperationException with 3 repositories [message #640504 is a reply to message #632515] Mon, 22 November 2010 06:25 Go to previous messageGo to next message
Are there any news about a new build?
Lars
Re: UnsupportedOperationException with 3 repositories [message #640521 is a reply to message #640504] Mon, 22 November 2010 07:24 Go to previous messageGo to next message
Yes, we are already able to build it. The latest build is supposed to be published later today to the 3.6 update site, and we will also modify the build for 3.7milestones (currently there is a new build but it is actually based on 3.6 and we want to change it to 3.7).
I'll let you know when it all gets stable (hopefully later today).
Filip
Dne 22.11.2010 12:25, Lars Fischer napsal(a):
> Regards,
> Lars
Re: UnsupportedOperationException with 3 repositories [message #641083 is a reply to message #640521] Wed, 24 November 2010 03:36 Go to previous messageGo to next message
The new build for 3.6 is now available. Please try it out to see if it fixes your problem.
Filip
Dne 22.11.2010 13:24, Filip Hrbek napsal(a):
> Filip
>> Regards,
>> Lars
Re: UnsupportedOperationException with 3 repositories [message #641120 is a reply to message #641083] Wed, 24 November 2010 05:10 Go to previous messageGo to next message
I was not able to install the new 3.6 build (0.1.0.r01408) from the
update site (http://download.eclipse.org/modeling/emft/b3/updates-3.6)
into my Eclipse 3.6.1:
Your original request has been modified.
"b3 Aggregator Editor (Incubation)" is already installed, so an
update will be performed instead.
Cannot complete the install because of a conflicting dependency.
Software being installed: b3 Aggregator Editor (Incubation)
0.1.0.r01408 (org.eclipse.b3.aggregator.editor.feature.feature.group
0.1.0.r01408)
Software currently installed: Eclipse for RCP and RAP Developers
1.3.0.20100617-0521 (epp.package.rcp 1.3.0.20100617-0521)
Only one of the following can be installed at once:
Core Resource Management 3.6.0.v20100526-0737
(org.eclipse.core.resources 3.6.0.v20100526-0737)
Core Resource Management 3.6.0.R36x_v20100825-0600
(org.eclipse.core.resources 3.6.0.R36x_v20100825-0600)
Cannot satisfy dependency:
From: Eclipse for RCP and RAP Developers 1.3.0.20100617-0521
To: org.eclipse.epp.package.rcp.feature.feature.group
[1.3.0.20100617-0521]
From: b3 Aggregator Editor (Incubation) 0.1.0.r01408
(org.eclipse.b3.aggregator.editor.feature.feature.group 0.1.0.r01408)
To: org.eclipse.b3.aggregator.engine.feature.feature.group
[0.1.0.r01408]
From: b3 Aggregator Engine (Incubation) 0.1.0.r01408
(org.eclipse.b3.aggregator.engine.feature.feature.group 0.1.0.r01408)
To: org.eclipse.core.resources [3.6.0.R36x_v20100825-0600]
(org.eclipse.epp.package.rcp.feature.feature.group 1.3.0.20100617-0521)
To: org.eclipse.platform.feature.group
[3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY]
(org.eclipse.platform.feature.group
3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY)
To: org.eclipse.core.resources [3.6.0.v20100526-0737]
Lars
Re: UnsupportedOperationException with 3 repositories [message #641145 is a reply to message #641120] Wed, 24 November 2010 07:15 Go to previous messageGo to next message
The aggregator build is set up to include proper version of org.eclipse.core.resources (3.6.0.R36x_v20100825-0600) which would normally be considered as older than 3.6.0.v20100526-0737 but in fact it is not (see bug 327234). This could be fixed by upgrading epp.package.rcp if it is already available with the dependency modified to the newer org.eclipse.core.resources bundle. I am afraid that I can't help more at the moment :-(
Filip
Dne 24.11.2010 11:10, Lars Fischer napsal(a):
>> fixes your problem.
> "b3 Aggregator Editor (Incubation)" is already installed, so an update
> 0.1.0.r01408)
> [0.1.0.r01408]
> From: EPP RCP/RAP Feature 1.3.0.20100617-0521
> From: Eclipse Platform
> Regards,
> Lars
Re: UnsupportedOperationException with 3 repositories [message #641178 is a reply to message #641145] Wed, 24 November 2010 08:08 Go to previous messageGo to next message
Hi Lars,
The new aggregator will install into a new untainted Eclipse 3.6.1. This only happens when an old aggregator was first
installed into your 3.6.1 since p2 considers the o.e.core.resources bundle has been updated due to the qualifier debacle.
Thomas Hallgren
> Filip
>>> fixes your problem.
>> 0.1.0.r01408)
>> [0.1.0.r01408]
>> Regards,
>> Lars
Re: UnsupportedOperationException with 3 repositories [message #641197 is a reply to message #641178] Wed, 24 November 2010 09:19 Go to previous messageGo to next message
Hello Thomas,
> only happens when an old aggregator was first installed into your 3.6.1
I tried to first uninstall the old aggregator, but there is still an
error. Trying to use a clean Eclipse 3.6.1 may take some time.
Does this error also belong to Bug 327234?
0.1.0.r01408)
Update site repository adapter bundle (Incubation)
1.0.201.R36x_v20100823 (org.eclipse.equinox.p2.updatesite
1.0.201.R36x_v20100823)
1.0.200.v20100503 (org.eclipse.equinox.p2.updatesite 1.0.200.v20100503)
Eclipse Platform 3.6.0.v201006080911 (org.eclipse.platform
3.6.0.v201006080911)
Eclipse Platform 3.6.1.v201009090800 (org.eclipse.platform
3.6.1.v201009090800)
To: org.eclipse.platform.ide 0.0.0
[0.1.0.r01408]
To: org.eclipse.equinox.p2.updatesite [1.0.201.R36x_v20100823]
2.0.0.v20100503-897HFZ-FdHjO2NQo0sD_Nt
(org.eclipse.equinox.p2.user.ui.feature.group
2.0.0.v20100503-897HFZ-FdHjO2NQo0sD_Nt)
To: org.eclipse.equinox.p2.updatesite [1.0.200.v20100503]
To: org.eclipse.platform [3.6.0.v201006080911]
3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L
3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L)
To: org.eclipse.platform [3.6.1.v201009090800]
(org.eclipse.platform.ide 3.6.0.I20100608-0911)
To: org.eclipse.equinox.p2.user.ui.feature.group
[2.0.0.v20100503-897HFZ-FdHjO2NQo0sD_Nt]
(org.eclipse.platform.ide 3.6.1.M20100909-0800)
[3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L]
Lars
Re: UnsupportedOperationException with 3 repositories [message #641230 is a reply to message #641197] Wed, 24 November 2010 10:19 Go to previous message
Some update tries later: now its running fine.
Lars
Previous Topic:Cannot install b3 Aggregator into 3.7 M3.
Next Topic:Do you have any interest in a opensource feature to preconfigure distributions
Current Time: Sat Jul 19 10:01:01 EDT 2025
Powered by FUDForum. Page generated in 0.15186 seconds
