Home » Eclipse Projects » EclipseLink » Secondary table with join on constant value
Secondary table with join on constant value [message #632035] Mon, 11 October 2010 06:08 Go to next message
Hi!
My object model consists of a Unit, which can have several areas. I'm not interested in the individual areas, but they each have a size and I want Unit to have the attribute totalSize. totalSize may differ from the sum of the sizes of the areas but, luckily, the correct value is stored in the database. The database has two tables, "Unit" and "Area" where the Area table has a compound primary key, consisting of "unit_Id" (the primary key of the Unit table) and "area_number", which resets at 1 for each unit_id. The correct total size for each Unit lies in the Area table with the area_number = 0.
So, with these tables:
Unit
| unit_id |
| 0100325 |
Area
| unit_id | area_number | size |
| 0100325 | 0           | 42   |
| 0100325 | 1           | 21   |
| 0100325 | 2           | 18   |
And this class:
@Entity
public class Unit {
  @Id
  private String unitId;
  private int totalSize;
The totalSize attribute of the Unit object with unitId '0100325' should be 42.
How can this be done? Thanks!
/Matti
[Updated on: Mon, 11 October 2010 07:45] by Moderator
Re: Secondary table with join on constant value [message #632291 is a reply to message #632035] Tue, 12 October 2010 09:24 Go to previous message
One possible solution is to have a Unit class that has a List of sizes, with the first entry being the total size. This can be mapped using an ElementCollection and OrderColumn annotations which are described here:
http://wiki.eclipse.org/EclipseLink/Development/JPA_2.0/new_ collection_mappings
http://wiki.eclipse.org/EclipseLink/Development/JPA_2.0/orde red_lists
Something like:
@ElementCollection
@CollectionTable(name="AREA", joinColumns=@JoinColumn(name="UNIT_ID"))
@Column(name="SIZE")
@OrderColumn(name="AREA_NUMBER")
@OrderCorrection(EXCEPTION)
List<Integer> size;
Best Regards
Chris
[Updated on: Tue, 12 October 2010 09:25] by Moderator
Previous Topic:OneToOne mapping on same table
Next Topic:Is it possible to use to_number function in JPQL
Current Time: Sun Jul 20 08:54:25 EDT 2025
Powered by FUDForum. Page generated in 0.04087 seconds
