Home » Eclipse Projects » Eclipse Platform » Changing visibility of the toolbar items in IViewPart
Changing visibility of the toolbar items in IViewPart [message #631547] Thu, 07 October 2010 18:13 Go to next message
I ran into the following problem:
There are several editors (IEditorParts) in the app. There is also an
IViewPart that has a toolbar with several items. The IViewPart provides
supplementary content for some, but not all editors.
When an unsupported editor becomes active, the IViewPart goes empty.
However, its toolbar remains populated. I need to empty it out as well.
I tried the PropertyTester, wired up the plugin.xml, to control the
visibility of the commands, among other things, but no matter what I
tried, the toolbar items' status was updated only when the IViewPart
became active. The problem is that I need the toolbar refreshed as the
editors become active/inactive; the IViewPart may never gain focus.
Is there any solution based on the documented framework features (as
opposed to possible hacks)?
Alex Molochnikov
Kelman Technologies Inc.
Re: Changing visibility of the toolbar items in IViewPart [message #631576 is a reply to message #631547] Fri, 08 October 2010 00:35 Go to previous messageGo to next message
I tried to put the New Wizard command on the Package Explorer and made
it visible only when PackageExplorer or Plugin manifest editor is
active. It works:
<extension
point="org.eclipse.ui.menus">
<menuContribution
allPopups="false"
locationURI="toolbar:org.eclipse.jdt.ui.PackageExplorer">
<command
commandId="org.eclipse.ui.newWizard"
style="push">
<visibleWhen
checkEnabled="false">
<with
variable="activePartId">
<or>
<equals
value="org.eclipse.jdt.ui.PackageExplorer">
</equals>
<equals
value="org.eclipse.pde.ui.manifestEditor">
</equals>
</or>
</with>
</visibleWhen>
</command>
</menuContribution>
</extension>
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Changing visibility of the toolbar items in IViewPart [message #631658 is a reply to message #631547] Fri, 08 October 2010 07:44 Go to previous messageGo to next message
If you are using propertyTesters, remember they are not event driven.
If you need to re-evaluate a property tester because you think it might
have changed, use
org.eclipse.ui.services.IEvaluationService.requestEvaluation (String)
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Changing visibility of the toolbar items in IViewPart [message #631764 is a reply to message #631658] Fri, 08 October 2010 11:41 Go to previous message
Thank you, Paul. I am aware of this. However, my problem is in timing of
the testing. It does not fire until the IViewPart that owns the toolbar
gains focus. Hence there is no change in the toolbar status (items
adder/removed, enabled/disabled) when IEditorParts change their state.
Alex Molochnikov
Paul Webster wrote:
> If you are using propertyTesters, remember they are not event driven. If
> have changed, use
> PW
Previous Topic:Open View via Context Menu
Next Topic:Writing custom visibleWhen rules
Current Time: Sun Jul 20 07:39:56 EDT 2025
Powered by FUDForum. Page generated in 0.04764 seconds
