Home » Eclipse Projects » DTP » SQL Builder to produce "As"-less alias?
SQL Builder to produce "As"-less alias? [message #631526] Thu, 07 October 2010 16:22 Go to next message
I'm using the DTP SQL builder and ran into a problem. If I have an existing sql statement with table alias
Select *
From Employee E
And I edit it in the SQL builder, the keyword AS will be inserted after the edit, so I get
Select *
From Employee AS E
Does the SQL builder has a switch to make AS-less alias?
Thanks!
Re: SQL Builder to produce "As"-less alias? [message #632665 is a reply to message #631526] Wed, 13 October 2010 15:27 Go to previous messageGo to next message
What version of DTP are you using, and what database platform are you
connecting to?
We put in a fix in DTP 1.8.1 so that the SQL Query Builder doesn't
generate the AS keyword for table correlation IDs when connected to an
Oracle database.
> Select * From Employee E
> the edit, so I get
> Select * From Employee AS E
> Thanks!
Re: SQL Builder to produce "As"-less alias? [message #632671 is a reply to message #632665] Wed, 13 October 2010 16:14 Go to previous messageGo to next message
Brian,
I'm using version 1.6.2, and unfortunately I'm not able to upgrade at this moment. Is there a workaround I can opt for?
Yup, Oracle database is what's causing all these.
Great you have a solution in 1.8.1 though.
Re: SQL Builder to produce "As"-less alias? [message #632927 is a reply to message #632671] Thu, 14 October 2010 12:58 Go to previous message
Well, if you are set up to build DTP, you can apply the patch in bug
319927 to the plugin org.eclipse.datatools.sqltools.sqlbuilder. It will
probably apply to the 1.6.2 version without a problem.
I can't think of much else that would fix the problem in 1.6.2.
On 10/13/2010 1:14 PM, chauncey wrote:
> Brian,
Previous Topic:ClassCastException on JDBCView.createSupertableLoader() and JDBCTable.createSupertableLoader()
Next Topic:DTP 1.8.2 - regeneration of Sybase Ecore models and model code
Current Time: Sat Jul 19 22:38:54 EDT 2025
Powered by FUDForum. Page generated in 0.03215 seconds
