Home » Modeling » EMF » generate "wrapper" classes from annotated java
generate "wrapper" classes from annotated java [message #630217] Fri, 01 October 2010 04:12 Go to next message
Is it possible to generate ecore model that contains only "wrapper" classes from annotated java interfaces?
E.g.,
public interface PurchaseOrder {
should result in the folowing ecore class
<eClassifiers xsi:type="ecore:EClass" name="PurchaseOrder" instanceClassName="mypackage.xyz.PurchaseOrder" abstract="true" interface="true"/>
I can specify
@model interface="true" abstract="true"
but is it also possible to specify the instanceClassName ?
Stanislav
Re: generate "wrapper" classes from annotated java [message #630302 is a reply to message #630217] Fri, 01 October 2010 09:41 Go to previous messageGo to next message
Stanislav,
Comments below.
Stanislav wrote:
Yes.
> E.g.,
> interface="true"/>
> I can specify
You don't want the interface to be generated by the model though.
Once it's generated, that information is included in the generated model
but I gather you don't want that, though not sure why.
You'll have to include annotations directly in the XyzPackage to define
just wrapper EClasses:
* @model instanceClass="mypackage.xyz.PurchaseOrder"
> Regards,
> Stanislav
Re: generate "wrapper" classes from annotated java [message #630382 is a reply to message #630302] Fri, 01 October 2010 15:28 Go to previous messageGo to next message
Hi Ed and thanks for your quick response.
I tried your suggestion but it did not work for me. Apparently I'm doing something wrong. Let me explain what I did.
1. I have a bunch of interfaces that I would like to wrap in EMF classes, e.g.,
package mypackage;
public interface Person {}
package mypackage;
public interface Man extends Person {}
2. I followed your suggestion, created a class MyPackage.java and put some annotations in it
package mypackage;
* @model kind="package"
* @model instanceClass="mypackage.Person"
* @model instanceClass="mypackage.Man
public class InterfacesPackage {}
3. I created a genmodel and imported the annotated java classes.
4. What I got was an ecore model that only contains one packege mypackage.
What is the right way to annotate MyPackage? In addition, do I need to annotate the interfaces as well, e.g.
package mypackage;
* @model interface="true" abstract="true"
Your help is very much appreciated.
Stanislav
[Updated on: Fri, 01 October 2010 15:54] by Moderator
Re: generate "wrapper" classes from annotated java [message #630437 is a reply to message #630382] Sat, 02 October 2010 09:26 Go to previous messageGo to next message
Ok, I think I figured it out.
package mypackage;
public interface MyPackagePackage {
public EClass getPerson();
* @model instanceClass="mypackage.Man" superTypes="mypackage.Person"
public EClass getMan();
Now I get an ecore model with wrapper EMF classes. Unfortunately, it seems that the Java importer does not use the annotation superTypes="mypackage.Person". That is, the attribute of ESuper Types of the class Man is not set to Person. Is this a bug of a feature ?
Stanislav
Re: generate "wrapper" classes from annotated java [message #630446 is a reply to message #630437] Sat, 02 October 2010 11:54 Go to previous messageGo to next message
Stanislav,
That annotation isn't supported, but would be nice thing to have. You
might want to open an enhancement request.
Ed
> package mypackage;
> Cheers,
> Stanislav
Re: generate "wrapper" classes from annotated java [message #630475 is a reply to message #630446] Sun, 03 October 2010 02:10 Go to previous message
Thanks Ed,
I'll open an enhancement request.
Stanislav
Previous Topic:[CDO] Is there any example for offline mode ?
Next Topic:What is the best practice to keep the generated and handmade code in separate files ?
Current Time: Sun Jul 20 18:57:35 EDT 2025
Powered by FUDForum. Page generated in 0.03837 seconds
