Home » Language IDEs » ServerTools (WTP) » Easily viewing schema for a given referenced schema(using WST-XML editor)
Easily viewing schema for a given referenced schema [message #558882] Tue, 14 September 2010 13:49 Go to next message
If I have an XML schema that references another schema trough a xmlns attribute, is it possible for the xml editor to quickly and easily view the referenced schema from the XML catalog? This is similar to say lookup the definition of a class in Java using the F3 shortcut. I have looked everywhere I could but could not find this information.
Mario
Re: Easily viewing schema for a given referenced schema [message #630185 is a reply to message #558882] Thu, 30 September 2010 19:05 Go to previous message
There is some work going on with an XML Content Model View, that will show the underlying content model for an xml document at a given element. Not sure if that is something you are referring too.
Previous Topic:JS Library stubs, JSDoc, and libraries
Next Topic:Help with JavaScript array indentation
Current Time: Sat Jul 19 21:32:31 EDT 2025
Powered by FUDForum. Page generated in 0.04131 seconds
