Home » Modeling » EMF » [EMF] FeatureMap with EOpposites
[EMF] FeatureMap with EOpposites [message #629751] |
Wed, 29 September 2010 08:55  |
Hi everybody,
is it possible to model a FeatureMap based on references with opposites?
I annotated the model like proposed in the EMF book, but the generated
code always contains errors, because it generates a normal Elist instead
of a FeatureMap
In the class "Container" i have list of "Node" in the *.ecore:
<eStructuralFeatures xsi:type="ecore:EReference" name="nodes"
upperBound="-1"
eType="#//Node" containment="true" eOpposite="#//Node/parent">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="group"/>
</eAnnotations>
</eStructuralFeatures>
Then i have a "IFDiagram" and "IGDiagram" Classes that extend the
"Container" Class containing this:
<eStructuralFeatures xsi:type="ecore:EReference" name="node"
upperBound="-1" eType="#//Node"
changeable="false" volatile="true" transient="true"
derived="true" containment="true">
<eAnnotations
<details key="group" value="#nodes"/>
</eAnnotations>
and a "Node" class with a reference to the parent "Container" like this:
<eStructuralFeatures xsi:type="ecore:EReference" name="parent"
eType="#//Container"
eOpposite="#//Container/nodes"/>
The getNode() methods of IFDiagram and IGDiagram are correctly
generated, but the getNodes() Method in "Container" has the returntype
EList<Node>, because the reference isn't mapped to a featuremap :/
I know that one could model a multi-value Attribute with FeatureMapEntry
type, but attributes don't support eopposites, i guess?
So what did i made wrong? Or is this simply not possible?
Greets, Mario
Re: [EMF] FeatureMap with EOpposites [message #629788 is a reply to message #629751] |
Wed, 29 September 2010 10:44   |
Mario,
Comments below.
Mario wrote:
> Hi everybody,
> opposites? I annotated the model like proposed in the EMF book, but
> the generated code always contains errors, because it generates a
> normal Elist instead of a FeatureMap
> upperBound="-1"
> <eAnnotations
Doesn't a group need to be a feature map?
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> FeatureMapEntry type, but attributes don't support eopposites, i guess?
No, but the features that delegate into the map can.
It looks wrong to me.
Feature maps themselves can't have opposites. The features that
delegate to them can. Try to write your model as a schema...
> Greets, Mario
Re: [EMF] FeatureMap with EOpposites [message #629845 is a reply to message #629788] |
Wed, 29 September 2010 13:49   |
Hi Ed,
thanks for your answer.
The EMF-Book suggests a Multi-Value Attribute (which works perfectly)
but mentiones (in a little sidenote, though), that this should also work
with a reference.
I just found an online doc
( http://www.eclipse.org/modeling/emf/docs/overviews/FeatureMa p.pdf)
which says:
"[..] (Note: I think that we should change the importer to alternatively
allow the orders feature to be defined in UML as a
third reference to PurchaseOrder as in the previous diagram. I think
that providing the kind=group annotation
would be sufficient information to indicate that it maps to a FeatureMap
implementation) [..]"
My initial question was merely if this feature (annotating reference
with kind=group) realy exists and if yes, why it doesn't work for me :)
> Feature maps themselves can't have opposites. The features that delegate
Would this help? The model is not that small and i'm not the only one
working with it. So i really would like to avoid this step.
Am 09/29/10 16:44, schrieb Ed Merks:
> Mario,
> Comments below.
> Mario wrote:
>> Hi everybody,
>> upperBound="-1"
>> <eAnnotations
>> </eAnnotations>
>> changeable="false" volatile="true" transient="true" derived="true"
>> containment="true">
>> <eAnnotations
>> </eAnnotations>
>> Greets, Mario
Re: [EMF] FeatureMap with EOpposites [message #629854 is a reply to message #629845] |
Wed, 29 September 2010 14:28  |
Mario,
I only suggest a schema because that's the best way to ensure you have a
consistent set of extended meta data annotations...
Taking a step back and trying to figure out what you're hoping to
accomplish, I'm not at all sure your goal. What exactly is the point of
trying to define both a "node" and a "nodes" references?
Mario wrote:
> Hi Ed,
> work with a reference.
> which says:
> alternatively allow the orders feature to be defined in UML as a
> FeatureMap implementation) [..]"
> delegate
>> Mario,
>> Comments below.
>> Mario wrote:
>>> Hi everybody,
>>> upperBound="-1"
>>> <eAnnotations
>>> </eAnnotations>
>>> containment="true">
>>> <eAnnotations
>>> </eAnnotations>
>>> this:
>>> Greets, Mario
Current Time: Sun Jul 20 09:38:38 EDT 2025
Powered by FUDForum. Page generated in 0.65985 seconds
