Home » Modeling » EMF » Uniqueness not enforced by Validate(When using validate it does not check for required uniqueness)
Uniqueness not enforced by Validate [message #559905] Mon, 20 September 2010 06:30 Go to next message
Hi, I'm hoping that some-one can suggest something that I may be doing wrong, or if what I am trying is not supported. I have a schema that looks as follows:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns="http://example.com/Unique" targetNamespace="http://example.com/Unique">
    <xs:complexType name="customerOrderType">
        <xs:attribute name="CustomerID" type="xs:string"/>
    </xs:complexType>
    <xs:element name="ordersByCustomer">
        <xs:complexType>
            <xs:sequence>
                <xs:element name="customerOrders" type="customerOrderType" minOccurs="0" maxOccurs="unbounded"/>
            </xs:sequence>
        </xs:complexType>
        <xs:unique name="oneCustomerOrdersforEachCustomerID">
            <xs:selector xpath="customerOrders"/>
            <xs:field xpath="@CustomerID"/>
        </xs:unique>
    </xs:element>
</xs:schema>
If I then populate it as follows:
<unique:ordersByCustomer xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:unique="http://example.com/Unique">
    <customerOrders xsi:type="unique:customerOrderType" CustomerID="ID1"/>
</unique:ordersByCustomer>
and then call
Diagnostician.INSTANCE.validate(object);
And the vaidation does not fail as I would expect, as the CustomerID is not unique. (This will fail validation in XMLSpy).
Re: Uniqueness not enforced by Validate [message #560006 is a reply to message #559905] Mon, 20 September 2010 13:04 Go to previous messageGo to next message
In the ecore model there is an ID boolean attribute. I tested setting that to true on an integer attribute in the model, and validate does detect a collision if I set two integer values the same in that case.
Here is the excerpt from the ecore model for the field. I'm testing with the emf that comes with Helios
<eStructuralFeatures xsi:type="ecore:EAttribute" name="key" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"
iD="true"/>
I changed it to a String attribute, and it also detected the collision, so I think you just need to enable that boolean attribute, ID, in the ecore model.
<eStructuralFeatures xsi:type="ecore:EAttribute" name="key" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
iD="true"/>
Re: Uniqueness not enforced by Validate [message #560106 is a reply to message #559905] Tue, 21 September 2010 04:49 Go to previous messageGo to next message
I'm using version 2.4.2
After importing the XSD, the eCore shows:
    <eStructuralFeatures xsi:type="ecore:EReference" name="ordersByCustomer" upperBound="-2" eType="//OrdersByCustomerType" volatile="true" transient="true" derived="true" containment="true" resolveProxies="false">
      <eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
        <details key="kind" value="element"/>
        <details key="name" value="ordersByCustomer"/>
        <details key="namespace" value="##targetNamespace"/>
      </eAnnotations>
    </eStructuralFeatures>
If you use the graphical properties tab, it shows Unique=true
However it does not seem to enforce this on a validate.
Re: Uniqueness not enforced by Validate [message #629449 is a reply to message #559905] Tue, 28 September 2010 06:41 Go to previous messageGo to next message
Does anyone have any more thoughts on this? Is this a bug in EMF?
Thank you
Rob
Re: Uniqueness not enforced by Validate [message #629632 is a reply to message #629449] Tue, 28 September 2010 23:41 Go to previous messageGo to next message
Rob,
I'm not sure the context of your question. It should be virtually
impossible to have duplicates if they aren't allowed because the lists
check while adding so we don't check for it as part of validation...
Rob wrote:
> Thank you
> Rob
Re: Uniqueness not enforced by Validate [message #629686 is a reply to message #629632] Wed, 29 September 2010 05:07 Go to previous messageGo to next message
Hi Ed, thanks for taking the time to reply.
I do not seem to be getting any restrictions when creating or adding a list, for example if I use the previously defined schema and then the following code:
OrdersByCustomerType createOrdersByCustomerType = UniqueFactory.eINSTANCE.createOrdersByCustomerType();
EList<CustomerOrderType> customerOrders = createOrdersByCustomerType.getCustomerOrders();
CustomerOrderType custOrderType1 = UniqueFactory.eINSTANCE.createCustomerOrderType();
custOrderType1.setCustomerID("ID1");
CustomerOrderType custOrderType2 = UniqueFactory.eINSTANCE.createCustomerOrderType();
custOrderType2.setCustomerID("ID1");
customerOrders.add(custOrderType1);
customerOrders.add(custOrderType2);
There is no probelm constructing the data with the duplicate ID, and I can also validate it without a problem.
Diagnostician.INSTANCE.validate(createOrdersByCustomerType);
I was expecting something some-where to stop me, either with the construction or ideally with the validation.
Thank, Rob
Re: Uniqueness not enforced by Validate [message #629774 is a reply to message #629686] Wed, 29 September 2010 10:17 Go to previous messageGo to next message
Rob,
Comments below.
> following code:
You're talking about uniqueness of IDs rather than uniqueness of
instances, i.e., the same object more than once in the list.
If you look at EObjectValidator.validate_UniqueID you'll see it's done
only checked the context of a resource.
> Thank, Rob
Re: Uniqueness not enforced by Validate [message #631236 is a reply to message #559905] Wed, 06 October 2010 12:16 Go to previous messageGo to next message
Hi Ed,
Thanks again for your help, however I'm a little confused. Are you saying that EMF does not support this case where the unique constraint is put on an attribute within an ComplexType that is then used as an element.
I can't see exactly what I'm doing that isn't a valid case. I was under the belief that the validation rule was to prevent users defining this case.
So in the XML/XSD world someone could write a chunk of XML (Obviously much larger and more complicated than my little example) and then validate it against the schema to ensure that they hadn't broken any uniqueness rules.
So in the EMF world, be able to define multiple objects, and then validate it to ensure that they again haven't broken any uniqueness rules.
I would be extremely greatful if you could elaborate, I did take a look at EObjectValidator.validate_UniqueID (and ran with the debugger) however this does nothing as the object is returning an ID of null, so got going into the code, so isn't actually checking it's contents. As I haven't editted the ecore, and just generated it from import I was not expecting any probelms.
Rob
Re: Uniqueness not enforced by Validate [message #631255 is a reply to message #631236] Wed, 06 October 2010 13:11 Go to previous message
--------------040806050805040902020100
Rob,
Comments below.
Rob wrote:
> Hi Ed,
> element.
Yes, the mapping from XML Schema to Ecore ignores things identify
constraints, like xsd:unique.
> defining this case.
> uniqueness rules.
> rules.
Ecore has no corresponding concept. Certainly it enforces ID uniqueness
but not XML Schema identify constraints.
Things like XML Schema complex type restrictions aren't supported
either. *All *the simple type constraints are.
> Thanks
> Rob
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Rob,<br>
<br>
Comments below.<br>
<br>
<br>
Rob wrote:
<blockquote cite="mid:i8i784$3v4$1@news.eclipse.org" type="cite">Hi Ed,
<br>
<br>
element.
<br>
</blockquote>
constraints, like xsd:unique.<br>
<blockquote cite="mid:i8i784$3v4$1@news.eclipse.org" type="cite"><br>
this case.
<br>
<br>
uniqueness rules.
<br>
<br>
rules.
<br>
</blockquote>
uniqueness but not XML Schema identify constraints.<br>
<br>
</blockquote>
either.  <b>All </b>the simple type constraints are.<br>
<br>
<br>
Rob
<br>
<br>
</blockquote>
</body>
</html>
--------------040806050805040902020100--
Previous Topic:Why i cannot see the icons from a metamodel instance at eclipse with EMF
Next Topic:[CDO] Is it possible to implement ReadAccess and WriteAccess handlers in one class?
Current Time: Sun Jul 20 19:31:18 EDT 2025
Powered by FUDForum. Page generated in 0.04986 seconds
