Home » Archived » BPMN Modeler » Generating bpmn file in a server runtime environment
Generating bpmn file in a server runtime environment [message #629658] Wed, 29 September 2010 03:31
Hi forum,
I need to save the semantic information of a workflow diagram generated by a web application in the same format as used in the bpmn file. I suppose it can be done easily with the BPMN generation API, except for the fact that the API is targeted to run with eclipse. Do you have any advice on how to migrate it to a server runtime environment, other than going through the source code and rewriting all the references to eclipse infrastructure?
Thanks very much
Hoang
Previous Topic:Open a BPMN Diagram Editor via Code
Next Topic:Parse a .bpmn-File
Current Time: Sun Jul 20 15:22:17 EDT 2025
Powered by FUDForum. Page generated in 0.03246 seconds
