Uniqueness not enforced by Validate [message #559905] |
Mon, 20 September 2010 06:30  |
Hi, I'm hoping that some-one can suggest something that I may be doing wrong, or if what I am trying is not supported. I have a schema that looks as follows:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns="http://example.com/Unique" targetNamespace="http://example.com/Unique">
<xs:complexType name="customerOrderType">
<xs:attribute name="CustomerID" type="xs:string"/>
</xs:complexType>
<xs:element name="ordersByCustomer">
<xs:complexType>
<xs:sequence>
<xs:element name="customerOrders" type="customerOrderType" minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
<xs:unique name="oneCustomerOrdersforEachCustomerID">
<xs:selector xpath="customerOrders"/>
<xs:field xpath="@CustomerID"/>
</xs:unique>
</xs:element>
</xs:schema>
If I then populate it as follows:
<unique:ordersByCustomer xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:unique="http://example.com/Unique">
<customerOrders xsi:type="unique:customerOrderType" CustomerID="ID1"/>
</unique:ordersByCustomer>
and then call
Diagnostician.INSTANCE.validate(object);
And the vaidation does not fail as I would expect, as the CustomerID is not unique. (This will fail validation in XMLSpy).
Re: Uniqueness not enforced by Validate [message #631255 is a reply to message #631236] |
Wed, 06 October 2010 13:11  |
--------------040806050805040902020100
Rob,
Comments below.
Rob wrote:
> Hi Ed,
> Thanks again for your help, however I'm a little confused. Are you
> saying that EMF does not support this case where the unique constraint
> is put on an attribute within an ComplexType that is then used as an
> element.
Yes, the mapping from XML Schema to Ecore ignores things identify
constraints, like xsd:unique.
> I can't see exactly what I'm doing that isn't a valid case. I was
> under the belief that the validation rule was to prevent users
> defining this case.
> So in the XML/XSD world someone could write a chunk of XML (Obviously
> much larger and more complicated than my little example) and then
> validate it against the schema to ensure that they hadn't broken any
> uniqueness rules.
> So in the EMF world, be able to define multiple objects, and then
> validate it to ensure that they again haven't broken any uniqueness
> rules.
Ecore has no corresponding concept. Certainly it enforces ID uniqueness
but not XML Schema identify constraints.
> I would be extremely greatful if you could elaborate, I did take a
> look at EObjectValidator.validate_UniqueID (and ran with the debugger)
> however this does nothing as the object is returning an ID of null, so
> got going into the code, so isn't actually checking it's contents. As
> I haven't editted the ecore, and just generated it from import I was
> not expecting any probelms.
Things like XML Schema complex type restrictions aren't supported
either. *All *the simple type constraints are.
> Thanks
> Rob
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Rob,<br>
<br>
Comments below.<br>
<br>
<br>
Rob wrote:
<blockquote cite="mid:i8i784$3v4$1@news.eclipse.org" type="cite">Hi Ed,
<br>
<br>
element.
<br>
</blockquote>
constraints, like xsd:unique.<br>
<blockquote cite="mid:i8i784$3v4$1@news.eclipse.org" type="cite"><br>
under the belief that the validation rule was to prevent users defining
this case.
<br>
<br>
uniqueness rules.
<br>
<br>
rules.
<br>
</blockquote>
uniqueness but not XML Schema identify constraints.<br>
I would be extremely greatful if you could elaborate, I did take a look
<br>
</blockquote>
either. <b>All </b>the simple type constraints are.<br>
<br>
<br>
Rob
<br>
<br>
</blockquote>
</body>
</html>
--------------040806050805040902020100--
FUDForum. Page generated in 0.24633 seconds
