Home » Language IDEs » ServerTools (WTP) » Changing the Encoding type value in the peferences doesn't reflect in the active editors (HTML, XML.(From a HTML or XML Editor, go to the Preferences and chaging the Encoding type to ASCII or other values from the default one, doesn't reflect in the Active editors? It has been used only during new fi)
Changing the Encoding type value in the peferences doesn't reflect in the active editors (HTML, XML. [message #559382] Thu, 16 September 2010 09:48 Go to next message
From a HTML or XML Editor, go to the Preferences and changing the Encoding type to ASCII or other values from the default one, doesn't reflect in the Active editors? It has been used only during new file creation. I think the change in Preferences should reflect in the Active editors immediately
Re: Changing the Encoding type value in the peferences doesn't reflect in the active editors (HTML, [message #629429 is a reply to message #559382] Tue, 28 September 2010 05:24 Go to previous message
These preferences are defined only for creation of files as would see the group name "Creating files".
For html files, the encoding can be changed for the file to be loaded after the preference change.
Previous Topic:Maven - incremental deployment for Glassfish or JBoss
Next Topic:Servers Not Listed in Servers View
Current Time: Sun Jul 20 07:03:53 EDT 2025
Powered by FUDForum. Page generated in 0.05450 seconds
