BPEL files are not validated [message #628794] |
Fri, 24 September 2010 03:53  |
I use Eclipse 3.5 and run the BPEL designer within a runtime workbench (I checked out the sources from CVS). I created some "test cases" in the runtime workbench (BPEL files that violate certain SA rules from the WS-BPEL specification). My own validator (I work on an OCL-based validator that validates model changes ad hoc) recognizes the respective violations and reports the problems, but the built-in validator from the BPEL project does nothing.
I already started the runtime workbench without my validator to check whether it conflicts with the built-in or superposes it, but that seems not to be the case. The built-in validator just does not anything.
I read the BPEL validator page and understand how it should work.
I suppose that this is rather a specific problem with my Eclipse installation than a bug - so what should I look for?
FUDForum. Page generated in 0.06436 seconds
