Maven - incremental deployment for Glassfish or JBoss [message #629092] |
Mon, 27 September 2010 03:51 |
I have developed a eclipse plugin to support incremental deployment for
Maven multi-module JEE Projects.
The problem to me was that the WTP integration did not support hot or
incremental deployment from multi-module maven projects.
In the past my ear pom.xml did include a ant-plugin configuration like this
to copy the final ear build into my glassfish autodeploy folder:
<plugin>
<artifactId>maven-antrun-plugin</artifactId>
<executions>
<execution>
<phase>pre-integration-test</phase>
<configuration>
<tasks>
the Property 'autodeploy' needs to be configured in the
settings.xml file the property should point to the autodeploy
folder from app server
<echo message="About to copy EAR to autodeploydirectory..." />
<echo> EAR:
${project.build.directory}/${project.build.finalName}.ear
autodeploy directory: ${autodeploy} </echo>
<copy
file="${project.build.directory}/${project.build.finalName}.ear"
todir="${autodeploy}" />
<echo message="Copied EAR to autodeploy directory." />
</tasks>
</configuration>
<goals>
<goal>run</goal>
</goals>
</execution>
</executions>
</plugin>
This all works but Glassfish also supports incremental deployment. So any
changes to a .xhtml, .jsf Page can be deployed incremental when the changes
from the Eclipse IDE are reflected into the glassfish applications/
directory where all deployed JEE modules and applications are present.
So this is what my pugin did. You can specifiy the target folder for a JEE
module and you got a incremental deployment.
http://code.google.com/p/manik-hot-deploy/
As a result using this plugin I only need to make a mvn:install when a full
redeploy is suitable .
But maybe this is helpful to other maven developers.
Thanks for any feedback.
FUDForum. Page generated in 0.02103 seconds
