Home » Modeling » Papyrus » Help needed on how to translate diagram and diagram elements.
Help needed on how to translate diagram and diagram elements. [message #628754] Thu, 23 September 2010 19:53 Go to next message
We need to translate Papyrus diagram elements into Brazilian Portuguese. My question is which is the easiest way to do that? Just translating the UML.ecore model will do the work?
Thanks.
Re: Help needed on how to translate diagram and diagram elements. [message #628826 is a reply to message #628754] Fri, 24 September 2010 06:26 Go to previous message
You should find all messages which you need to translate in "messages.properties" files in each Papyrus plugin.
Have a look at the eclipse internationalization process to know how to invoke your translated file instead of the original english file.
http://www.eclipse.org/articles/Article-Internationalization /how2I18n.html
If some user messages are hard coded in java files instead of being internationalized in these files, this is a bug.
If you see such langage specific strings, you may raise a bug, by preference regrouping all of them in a same bug (or in plugin separated bugs)
Previous Topic:Change Shape of Collaboration in UML2 Composite Diagram
Next Topic:Monitor/log changes made to a UML model
Current Time: Sat Jul 19 08:46:04 EDT 2025
Powered by FUDForum. Page generated in 0.05720 seconds
