Home » Modeling » UML2 » Find stereotypes applicable to instances of EClass?
Find stereotypes applicable to instances of EClass? [message #479543] Tue, 11 August 2009 09:57 Go to next message
given an EClass, corresponding to an UML meta-class, and a stereotype, I wonder what is the most elegant way to find out
whether the stereotype is applicable to an instances of this EClass?
Any ideas?
Thanks for helping
Joel
Re: Find stereotypes applicable to instances of EClass? [message #479545 is a reply to message #479543] Tue, 11 August 2009 10:06 Go to previous messageGo to next message
Hey,
what about:
Element element = (Element)UMLFactory.create(eclass);
final boolean isApplicable = element.isStereotypeApplicable(stereo);
Timothy
Joel Greenyer schrieb:
> wonder what is the most elegant way to find out whether the stereotype
> Any ideas?
> Thanks for helping
> Joel
Re: Find stereotypes applicable to instances of EClass? [message #479559 is a reply to message #479545] Tue, 11 August 2009 10:30 Go to previous messageGo to next message
Timothy,
thanks for the quick answer.
Your idea is not bad. However, what happens in case that the EClass is an abstract class?
The next thing that confuses me--but that's probably a whole different problem--is that wrong elements are created when
I hand the EClass to the UMLFactory. E.g. I have the EClass 'Class' and get an instance of 'Signal'. Any idea why that
may be?
Joel
Timothy Marc wrote:
> Hey,
> what about:
> Timothy
>> Hi,
>> I wonder what is the most elegant way to find out whether the
>> Any ideas?
>> Thanks for helping
>> Joel
Re: Find stereotypes applicable to instances of EClass? [message #479595 is a reply to message #479559] Tue, 11 August 2009 12:24 Go to previous messageGo to next message
I solved my problem as follows:
suppose I have EClass eClass and the Stereotype stereotype, then I add all stereotypes applicable to instances of the
EClass to an array list:
* When is a stereotye applicable to instances of eClass?
* 1. when the eClass equals an extended meta-class of the stereotype
* 2. when the eClass is a subclass of the extended meta-class of the stereotype
* <=> the extended meta-class is in the set of superclasses of eClass
ArrayList<Stereotype> applicableStereotypesList = new ArrayList<Stereotype>();
for (Class extendedMetaClass : stereotype.getAllExtendedMetaclasses()) {
EClassifier eExtendedMetaClass = UMLFactory.eINSTANCE.getEPackage().getEClassifier(extendedMe taClass.getName());
// 1.
if (eExtendedMetaClass == eClass){
applicableStereotypesList.add(stereotype);
break;
// 2.
if (eClass.getEAllSuperTypes().contains(eExtendedMetaClass)){
break;
Joel Greenyer wrote:
> Timothy,
> an abstract class?
> problem--is that wrong elements are created when I hand the EClass to
> 'Signal'. Any idea why that may be?
> Thanks
> Joel
> Timothy Marc wrote:
>> Hey,
>> what about:
>> Timothy
>>> Hi,
>>> stereotype, I wonder what is the most elegant way to find out whether
>>> Any ideas?
>>> Thanks for helping
>>> Joel
Re: Find stereotypes applicable to instances of EClass? [message #479627 is a reply to message #479595] Tue, 11 August 2009 14:44 Go to previous messageGo to next message
Hi Joel,
even though it looks quite the same, I post my solution here as well,
because I think such methods should make it into the eclipse UML API:
boolean isApplicableStereotype(EClass eClass, Stereotype stereotype)
for(Property attribute : stereotype.getAllAttributes())
if(attribute.getAssociation() instanceof Extension)
Type type = attribute.getType();
EClassifier eClassifier = UMLPackage.eINSTANCE
.getEClassifier(type.getName());
if(eClassifier instanceof EClass &&
((EClass) eClassifier).isSuperTypeOf(eClass))
return true;
return false;
It assumes the Stereotype is properly defined and is inspired by
ElementOperations.isApplicableStereotype.
Greetings to Paderborn from Kassel,
Christian
Re: Find stereotypes applicable to instances of EClass? [message #479706 is a reply to message #479627] Wed, 12 August 2009 02:55 Go to previous messageGo to next message
Hi Christian,
thanks for the comment. Do you have a reason not to use stereotype.getAllExtendedMetaclasses()?
Indeed I was missing such a method in the UML API.
Greetings from Paderborn to Kassel
Joel
Christian Schneider wrote:
> Hi Joel,
> return true;
> return false;
> Christian
Re: Find stereotypes applicable to instances of EClass? [message #479724 is a reply to message #479706] Wed, 12 August 2009 04:03 Go to previous message
Well, the reason is, that ElementOperations.isApplicableStereotype did
not use it. But looking into the implementation it seems to be
equivalent so using getAllExtendedMetaclasses is even better as it's
shorter.
/Christian
Re: Find stereotypes applicable to instances of EClass? [message #627869 is a reply to message #479543] Tue, 11 August 2009 10:06 Go to previous message
Hey,
what about:
Timothy
> Any ideas?
> Thanks for helping
> Joel
Re: Find stereotypes applicable to instances of EClass? [message #627870 is a reply to message #479545] Tue, 11 August 2009 10:30 Go to previous message
Timothy,
may be?
Joel
Timothy Marc wrote:
> Hey,
> what about:
> Timothy
>> Hi,
>> Any ideas?
>> Thanks for helping
>> Joel
Re: Find stereotypes applicable to instances of EClass? [message #627871 is a reply to message #479559] Tue, 11 August 2009 12:24 Go to previous message
// 1.
break;
// 2.
break;
> Timothy,
> an abstract class?
> Thanks
> Joel
> Timothy Marc wrote:
>> Hey,
>> what about:
>> Timothy
>>> Hi,
>>> Any ideas?
>>> Thanks for helping
>>> Joel
Re: Find stereotypes applicable to instances of EClass? [message #627872 is a reply to message #479595] Tue, 11 August 2009 14:44 Go to previous message
Hi Joel,
return true;
return false;
Christian
Re: Find stereotypes applicable to instances of EClass? [message #627873 is a reply to message #479627] Wed, 12 August 2009 02:55 Go to previous message
Hi Christian,
Joel
> Hi Joel,
> return true;
> return false;
> Christian
Re: Find stereotypes applicable to instances of EClass? [message #627874 is a reply to message #479706] Wed, 12 August 2009 04:03 Go to previous message
shorter.
/Christian
Previous Topic:Find stereotypes applicable to instances of EClass?
Next Topic:[Announce] MDT UML2 3.1.0M1 is available
Current Time: Sun Jul 20 15:39:06 EDT 2025
Powered by FUDForum. Page generated in 0.06235 seconds
