Home » Modeling » UML2 » Generating Java-classes?
Generating Java-classes? [message #478440] Wed, 20 May 2009 11:37 Go to next message
I want to use the UML-metamodel in order to develop a modeling-tool. So I
generated a UML.genmodel from the uml.ecore . Then I right-clicked the
genmodel and chose "Generate Model Code".
Unfortunatly the generated classes contain one error. That is located in
the generated CombinedFragment.java, where a method was created named
"break", which is obviously a Java-keyword. "break" is the name of an
operation in the CombinedFragment-type in the metamodel.
So my question is, how can I fix it? Or am I going in a wrong direction?
I guess this is a noob-question, because people probably generate the
Java-classes from the model all the time, right?
thank you
Re: Generating Java-classes? [message #478443 is a reply to message #478440] Fri, 22 May 2009 10:02 Go to previous messageGo to next message
Usul,
Actually, it's not very common to need to regenerate the source for UML2
(it's already done for you!), unless you're building your own UML-like
DSL...
The only reason I can think of for a method named "break" to appear in the
generated code (since it doesn't appear in the InteractionOperatorKind
enumeration) would be the constraint (unfortunately named "break") on the
CombinedFragment class. One way to get around this (as UML2 itself does)
would be to specify a prefix via the "Invariant Prefix" option on the UML2
generator model (UML2 itself uses "validate").
Kenn
" Usul" <skobilke@gmx.de> wrote in message
news:f28bcb58a477ab27bc33db064b99dc36$1@www.eclipse.org...
> thank you
Re: Generating Java-classes? [message #478445 is a reply to message #478443] Fri, 22 May 2009 12:59 Go to previous messageGo to next message
Thank you for answering Kenn,
but I still dont understand. I need the Java-classes which represent the
metamodel. Are you saying they already exist? Where can I find them?
What I want to do is to write an eclipse-plugin which can create
uml-models. So I need the Java-classes in order to do this:
// create root of model
umlFac = UmlFactory.eINSTANCE;
Model root = umlFac .createModel();
// build model
// save model
ResourceSet resourceSet = new ResourceSetImpl();
IProject project = selectedFolder.getCorrespondingResource().getProject();
IFolder modelFolder = this.getModelFolder(project);
IFile file = modelFolder.getFile("themodel.uml");
String path = file.getLocation().toFile().getAbsolutePath();
URI fileURI = URI.createFileURI(path);
Resource resource = resourceSet.createResource(fileURI);
resource.getContents().add(root );
system.resource.save(Collections.EMPTY_MAP);
Re: Generating Java-classes? [message #478446 is a reply to message #478445] Fri, 22 May 2009 13:45 Go to previous message
Oh, nevermind, I found it: org.eclipse.uml2.uml_3.0.0.v200905041045.jar .
Thanx!
Re: Generating Java-classes? [message #627621 is a reply to message #478440] Fri, 22 May 2009 10:02 Go to previous message
Usul,
DSL...
Kenn
> thank you
Re: Generating Java-classes? [message #627623 is a reply to message #478443] Fri, 22 May 2009 12:59 Go to previous message
// build model
// save model
Re: Generating Java-classes? [message #627624 is a reply to message #478445] Fri, 22 May 2009 13:45 Go to previous message
Thanx!
Previous Topic:Preserving uuid to xmi:id mapping converting uml2 to eCore
Next Topic:Preserving uuid to xmi:id mapping converting uml2 to eCore
Current Time: Sun Jul 20 14:15:53 EDT 2025
Powered by FUDForum. Page generated in 0.55504 seconds
