Home » Modeling » UML2 » Unable to add required property 'event' in ExecutionOccurrenceSpecification
Unable to add required property 'event' in ExecutionOccurrenceSpecification [message #478324] Thu, 23 April 2009 15:47 Go to next message
Originally posted by: florianwendland.freenet.de
Hey all,
i've found a bug, when i played a bit with interactions. The Validator
(and even the spec) recommend, that an ExecutionOccurrenceSpecification
had to declare a required property 'Event', which is possibly an
Receive/SendOperationEvent. So i've set it, and this causes an
IllegalArgumentException. Here is the relevant trace:
java.lang.IllegalArgumentException:
org.eclipse.uml2.uml.internal.impl.ReceiveOperationEventImpl @6a9b28
(name: RecvEvt9, visibility: <unset>)
at
org.eclipse.uml2.uml.internal.impl.ExecutionOccurrenceSpecif icationImpl.setEvent(ExecutionOccurrenceSpecificationImpl.ja va:177)
at
org.eclipse.uml2.uml.internal.impl.ExecutionOccurrenceSpecif icationImpl.eSet(ExecutionOccurrenceSpecificationImpl.java:3 08)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1071)
at org.eclipse.emf.edit.command.SetCommand.doExecute(SetCommand .java:721)
at
org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe cute(AbstractOverrideableCommand.java:131)
at
org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:84)
at
org.eclipse.emf.edit.provider.ItemPropertyDescriptor.setProp ertyValue(ItemPropertyDescriptor.java:1427)
at
org.eclipse.uml2.uml.editor.presentation.UMLEditor$UMLProper tySource.setPropertyValue(UMLEditor.java:1917)
at
org.eclipse.ui.views.properties.PropertySheetEntry.valueChan ged(PropertySheetEntry.java:782)
at
org.eclipse.ui.views.properties.PropertySheetEntry.setValue( PropertySheetEntry.java:723)
at
org.eclipse.ui.views.properties.PropertySheetEntry.applyEdit orValue(PropertySheetEntry.java:146)
at
org.eclipse.ui.views.properties.PropertySheetEntry$1.applyEd itorValue(PropertySheetEntry.java:103)
at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:3 33
HTH
Marc-Florian
Re: Unable to add required property 'event' in ExecutionOccurrenceSpecification [message #478325 is a reply to message #478324] Thu, 23 April 2009 16:53 Go to previous messageGo to next message
The spec mentions .. "... to be restricted to an execution event". I'm
guessing that the event you are trying to set on the
ExecutionOccurrenceSpecification is not an ExecutionEvent.
- James.
"Marc-Florian Wendland" <florianwendland@freenet.de> wrote in message
news:gsqgdk$9u5$1@build.eclipse.org...
> Hey all,
> org.eclipse.uml2.uml.internal.impl.ReceiveOperationEventImpl @6a9b28 (name:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> HTH
> Marc-Florian
Re: Unable to add required property 'event' in ExecutionOccurrenceSpecification [message #478327 is a reply to message #478325] Thu, 23 April 2009 17:53 Go to previous message
Well, that's true. I thought, that the event, to which an
ExecutionOccurrenceSpecification (EOS) points to, is the Event
(CallEvent, SendEvent, MessageEvent etc.) that starts the execution or
stops it....
So, what is an ExecutionEvent (EE)? It starts and stops an
ExecutionSpecification (ES), but this is exact the same meaning of EOS.
So, when i want to express, that an ES starts by retrieving a message
via MessageOccurrenceSpecification (MOS), i have no chance to combine
the MOS with an EOS. But this should be possible, because an EOS points
out, that an ES starts. Therefore, it should be possible to reference
not only EE but any kind of Event like MessageEvents.
By creating a structure like this:
MOS_1 {event:SendOperationEvent, m1:Message}
Message{name:m1}
MOS_2 {eventA:ReceiveOperationEvent, m1:Message}
EOS_1 {event->MOS_2, execution:ExectionSpecification}
ES {name:execution, start->EOS_1, finis->EOS_2}
EOS_2 {event->MOS4, execution:ExectionSpecification}
MOS_4 {eventA:SendOperationEvent, m2:Message}
Message{name:m2}
MOS_1 {event:ReceiveOperationEvent, m2:Message}
one could get any corelated information of the trace. But may be, i
missinterpret the meaning of ExecutionEven.
Marc-Florian
> - James.
>> Hey all,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> HTH
>> Marc-Florian
Re: Unable to add required property 'event' in ExecutionOccurrenceSpecification [message #627514 is a reply to message #478324] Thu, 23 April 2009 16:53 Go to previous message
- James.
> Hey all,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> HTH
> Marc-Florian
Re: Unable to add required property 'event' in ExecutionOccurrenceSpecification [message #627516 is a reply to message #478325] Thu, 23 April 2009 17:53 Go to previous message
stops it....
Message{name:m1}
Message{name:m2}
Marc-Florian
> - James.
>> Hey all,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> HTH
>> Marc-Florian
Previous Topic:XSD -> EMF -> UML
Next Topic:Export to UML from ECore fails, different this time
Current Time: Sat Jul 19 15:44:31 EDT 2025
Powered by FUDForum. Page generated in 0.08666 seconds
