How to run the UML code generator? [message #477969] |
Fri, 14 November 2008 07:53  |
Hi all,
If I want to change the UML code generator, what is the best way to
proceed? I have several projects in my workspace (org.eclipse.uml2.uml,
org.eclipse.uml2.codegen.ecore, org.eclipse.uml2.codegen.ecore.ui) and I
do not know which one to change if I want to add some additional code to
e.g. all getters of some specific UML element. Also, how can I re-run the
code generator then?
Thank you so much for your help!
Re: How to run the UML code generator? [message #477971 is a reply to message #477969] |
Fri, 14 November 2008 10:18  |
Hi Iris,
The tutorial
http://www.eclipse.org/modeling/mdt/uml2/docs/tutorials/Ecli pseCon2008_Tutorial_Creating_Robust_Scalable_DSL_with_UML.ht ml
might shed some light on this.
There is also a cheat-sheet for step by step walk-through .. see the wiki
for more details: http://wiki.eclipse.org/MDT-UML2
It sounds like you want to start modifyng the code generation templates
however. Please have a look at org.eclipse.uml2.codegen.ecore\templates.
* org.eclipse.uml2.uml is where you can find the bulk of the UML2 API. It
contains the generated code.
* The codegen.ecore contains customized codegen templates and genmodel
extensions.
* The codegen.ui contains item providers for the extended genmodel options.
To re-run code generation on uml you can start with the UML.genmodel in the
org.eclipse.uml2.uml\model directory and regenerate from there. All the
models from which the API is generated can be found in that model directory.
- James.
"Iris Groher" <Iris.Groher@gmx.at> wrote in message
news:3224d02ef139c99d17ece0fe8d5e5d67$1@www.eclipse.org...
> Hi all,
Re: How to run the UML code generator? [message #627188 is a reply to message #477969] |
Hi Iris,
The tutorial
extensions.
- James.
> Hi all,
FUDForum. Page generated in 0.04031 seconds
