Home » Modeling » UML2 » How can I extend UML2?
How can I extend UML2? [message #477953] Mon, 10 November 2008 09:46 Go to next message
Hi all,
I would like to add some additional notification mechanism to UML2. I need
to get notified of read accesses of UML elements (e.g. getName() of a
Class is called). How is that best done? Should I add the code manually to
the UML classes? Or is there any other way around this?
Thank you so much for your help!
Re: How can I extend UML2? [message #477954 is a reply to message #477953] Mon, 10 November 2008 10:06 Go to previous messageGo to next message
Iris,
This sounds similar to https://bugs.eclipse.org/bugs/show_bug.cgi?id=247130.
Iris Groher wrote:
> Hi all,
> need to get notified of read accesses of UML elements (e.g. getName()
> of a Class is called). How is that best done? Should I add the code
> manually to the UML classes? Or is there any other way around this?
Re: How can I extend UML2? [message #477955 is a reply to message #477954] Mon, 10 November 2008 12:45 Go to previous messageGo to next message
Thank you very much Ed! This seems to be exactly what I am looking for.
Could you please give me some hints on how to install the prototype you
created? Is it correct to replace Class.java with your version,
re-generate the code and re-install the plugin?
Greetings,
Iris.
Ed Merks wrote:
> Iris,
> Iris Groher wrote:
>> Hi all,
Thank you so m
Re: How can I extend UML2? [message #477956 is a reply to message #477955] Mon, 10 November 2008 13:12 Go to previous messageGo to next message
--------------070506010108070009030806
Iris,
I think it will be quite hard to try out the prototype and I'm working
on a new one right now. This document describes how we set up the source:
<http://wiki.eclipse.org/EMF/Getting_Source>
You'd need UML set up this way too...
I wonder what you're trying to do?
> for. Could you please give me some hints on how to install the
> prototype you created? Is it correct to replace Class.java with your
> version, re-generate the code and re-install the plugin?
> Greetings,
> Iris.
> Ed Merks wrote:
>> Iris,
>> Iris Groher wrote:
>>> Hi all,
>>> I need to get notified of read accesses of UML elements (e.g.
>>> getName() of a Class is called). How is that best done? Should I add
>>> the code manually to the UML classes? Or is there any other way
>>> around this?
> Thank you so m
<html>
<head>
http-equiv="Content-Type">
</head>
Iris,<br>
<br>
Re: How can I extend UML2? [message #477957 is a reply to message #477956] Mon, 10 November 2008 14:00 Go to previous message
The goal is to observe model validation. If I am able to get notified of
read accesses in the context of validation, I know which elements (and
what feature of the element) the validator looked at.
My idea was to use your read/write access notifications for that.
Re: How can I extend UML2? [message #627166 is a reply to message #477953] Mon, 10 November 2008 10:06 Go to previous message
Iris,
Iris Groher wrote:
> Hi all,
Re: How can I extend UML2? [message #627167 is a reply to message #477954] Mon, 10 November 2008 12:45 Go to previous message
Greetings,
Iris.
Ed Merks wrote:
> Iris,
> Iris Groher wrote:
>> Hi all,
Thank you so m
Re: How can I extend UML2? [message #627168 is a reply to message #477955] Mon, 10 November 2008 13:12 Go to previous message
Iris,
> Greetings,
> Iris.
> Ed Merks wrote:
>> Iris,
>> Iris Groher wrote:
>>> Hi all,
>>> around this?
> Thank you so m
<html>
<head>
</head>
Iris,<br>
<br>
Re: How can I extend UML2? [message #627169 is a reply to message #477956] Mon, 10 November 2008 14:00 Go to previous message
Previous Topic:How can I extend UML2?
Next Topic:How to run the UML code generator?
Current Time: Sun Jul 20 08:28:25 EDT 2025
Powered by FUDForum. Page generated in 0.06571 seconds
