Home » Modeling » UML2 » Enumeration Default Value
Enumeration Default Value [message #477808] Fri, 10 October 2008 13:39 Go to next message
Hi.
I created a profile where one of the stereotype properties points to an
enumeraton. The property is set as [0..1] with default value null literal.
But it's just impossible to set a null value to this property. When the
profile is defined (define menu) it chooses one of the literals as an
arbitrary default value.
How can I create a property that accept nulls with Enumerations ?
Re: Enumeration Default Value [message #477811 is a reply to message #477808] Fri, 10 October 2008 16:52 Go to previous messageGo to next message
Alexandre,
This is a side-effect of the fact that Ecore (from EMF) is used to represent
the metadata for (defined) profiles - in Ecore, an enumeration, like
primitive (data) types, must have an implicit default. Unfortunately, I
don't think there's much that can be done to change this. :(
Kenn
"Alexandre Torres" <alexandre.torres@gmail.com> wrote in message
news:c083e22b68ab5c671880a8c4bffc028b$1@www.eclipse.org...
> Hi.
> Thanks
Re: Enumeration Default Value [message #477813 is a reply to message #477811] Fri, 10 October 2008 18:00 Go to previous messageGo to next message
--------------070507020107030505020804
Kenn,
You can define an EDataType whose instance class in the enum's class and
that data type will allow nulls.
Kenn Hussey wrote:
> Alexandre,
> Kenn
>> Hi.
>> Thanks
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Kenn,<br>
<br>
and that data type will allow nulls.<br>
<br>
<br>
Kenn Hussey wrote:
<blockquote cite="mid:gcofbg$mft$1@build.eclipse.org" type="cite">
<pre wrap="">Alexandre,
Kenn
"Alexandre Torres" <a class="moz-txt-link-rfc2396E" href="mailto:alexandre.torres@gmail.com">&lt;alexandre.torres@gmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:c083e22b68ab5c671880a8c4bffc028b$1@www.eclipse.org">news:c083e22b68ab5c671880a8c4bffc028b$1@www.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------070507020107030505020804--
Re: Enumeration Default Value [message #477825 is a reply to message #477813] Tue, 14 October 2008 16:24 Go to previous messageGo to next message
------=_NextPart_000_00AC_01C92E19.49F54280
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
OK, but the literals of the enumeration won't be supported in the same =
way as they are for enumerations... and I assume serialization support =
for such a data type would need to be implemented?
Kenn
"Ed Merks" <Ed.Merks@gmail.com> wrote in message =
news:gcojar$3th$1@build.eclipse.org...
Kenn,
You can define an EDataType whose instance class in the enum's class =
Kenn Hussey wrote:=20
Alexandre,
This is a side-effect of the fact that Ecore (from EMF) is used to =
represent=20
the metadata for (defined) profiles - in Ecore, an enumeration, like=20
primitive (data) types, must have an implicit default. Unfortunately, I=20
Kenn
"Alexandre Torres" <alexandre.torres@gmail.com> wrote in message=20
Hi.
I created a profile where one of the stereotype properties points to an=20
enumeraton. The property is set as [0..1] with default value null =
literal.
But it's just impossible to set a null value to this property. When the=20
profile is defined (define menu) it chooses one of the literals as an=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.6000.16705" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>OK, but the literals of the enumeration =
won't be=20
supported in the same way as they are for enumerations... and I assume=20
serialization support for such a data type would need to be=20
implemented?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Kenn</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>&gt; wrote in =
message=20
<A=20
href=3D"news:gcojar$3th$1@build.eclipse.org">news:gcojar$3th$1@build.ecli=
pse.org</A>...</DIV>Kenn,<BR><BR>You=20
can define an EDataType whose instance class in the enum's class and =
that data=20
type will allow nulls.<BR><BR><BR>Kenn Hussey wrote:=20
<BLOCKQUOTE cite=3Dmid:gcofbg$mft$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Alexandre,
represent=20
Kenn
"Alexandre Torres" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:alexandre.torres@gmail.com">&lt;alexandre.torres@gmail.com=
&gt;</A> wrote in message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:c083e22b68ab5c671880a8c4bffc028b$1@www.eclipse.org">news:c08=
3e22b68ab5c671880a8c4bffc028b$1@www.eclipse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi.
literal.
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_00AC_01C92E19.49F54280--
Re: Enumeration Default Value [message #477847 is a reply to message #477825] Mon, 20 October 2008 07:17 Go to previous messageGo to next message
--------------060901000201090302030601
Kenn,
If do it in just the right magical way, it will work. :-P I.e., when
generating an EEnum from an enumeration facet in XML Schema (or any
EDataType who's type is primitive), we always need to generate a second
data type that allows null in case the type is ever used for a nillable
element. Serialization an validation is properly supported for this
automatically. You might be right that the combo box won't be correct,
but hey, no one has complained about that; if they did, it would be
fixed by now...
> Kenn
> "Ed Merks" <Ed.Merks@gmail.com <mailto:Ed.Merks@gmail.com>> wrote
> in message news:gcojar$3th$1@build.eclipse.org...
> Kenn,
> class and that data type will allow nulls.
> Kenn Hussey wrote:
>> Alexandre,
>> Kenn
>>> Hi.
>>> Thanks
<html>
<head>
</head>
Kenn,<br>
<br>
If do it in just the right magical way, it will work. :-P&nbsp; I.e., when
generating an EEnum from an enumeration facet in&nbsp; XML Schema (or any
element.&nbsp; Serialization an validation is properly supported for this
automatically.&nbsp; You might be right that the combo box won't be correct,
fixed by now...<br>
<br>
<br>
Kenn Hussey wrote:
<blockquote cite="mid:gd2v5b$sml$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.6000.16705" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">OK, but the literals of the
enumeration won't be supported in the same way as they are for
enumerations... and I assume serialization support for such a data type
would need to be implemented?</font></div>
<div>&nbsp;</div>
<div><font face="Arial" size="2">Kenn</font></div>
<blockquote dir="ltr"
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" &lt;<a moz-do-not-send="true"
href="mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</a>&gt; wrote in
message <a moz-do-not-send="true"
href="news:gcojar$3th$1@build.eclipse.org">news:gcojar$3th$1@build.eclipse.org</a>...</div>
Kenn,<br>
<br>
<br>
<br>
Kenn
"Alexandre Torres" <a moz-do-not-send="true"
<a moz-do-not-send="true" class="moz-txt-link-freetext"
</pre>
<pre wrap="">Hi.
</pre>
</blockquote>
</pre>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------060901000201090302030601--
Re: Enumeration Default Value [message #477949 is a reply to message #477847] Sat, 08 November 2008 09:23 Go to previous messageGo to next message
Lets revive this thread.
This is too another real problem, not being able to set primitive types as
null, like Boolean. If you read the UML spec you going to see that several
ocl rules are based upon nullable integer values like MultiplicityElement
lower bound:
From UML specification:
lowerBound = if lowerValue->isEmpty() then 1 else
lowerValue.integerValue() endif
so, lowerbound will never be empty when using uml2. Divergences like that
may seem small now, but in the long term make hard or impossible
interoperate models between tools.
And as pointed before, the lack of hability to say that some thing accept
nulls, leaving the decision about the value assumed to default values or
later check is important.
For instance, I can use default values to simulate the "unset" state, but,
if the default value changes, it's impossible to tell what situation the
user choose the value and what the situation where the user left it unset.
To make it worse, the unset state works very well for String and not
primitive types.
But if I add an wrapper as Ed proposed, this will make my model "strange".
Someone looking at my model will say "why you did it?" and I will have to
answer "becouse my uml toolkit has this limitation". All ocl rules will
had to be written to use wrappers, and will look alien to uml purists, and
bigger too.
Well i'm disappointed with this limitation. Someone that works with uml
should not be bound with those EMF problems (UML-MOF problems are already
a lot).
In the end I can't find any OMG uml tool that really implements the
specification with a good support for profile creation like eclipse's
implementation - what is only possible becouse of EMF's maturity. But EMF
will not evolve ?
Re: Enumeration Default Value [message #477950 is a reply to message #477949] Sat, 08 November 2008 09:59 Go to previous messageGo to next message
Alexandre,
Comments below.
I thought the horse was dead.
> types as null, like Boolean. If you read the UML spec you going to see
> that several ocl rules are based upon nullable integer values like
> MultiplicityElement lower bound:
I suppose you could pick some meaningless value as representing empty...
> Divergences like that may seem small now, but in the long term make
> hard or impossible interoperate models between tools.
So really UML should have not used int but rather Integer? Or perhaps
BigInteger, because I'd expect there is no limit on the theoretical
range of all integers...
> accept nulls, leaving the decision about the value assumed to default
> values or later check is important. For instance, I can use default
> values to simulate the "unset" state, but, if the default value
> changes, it's impossible to tell what situation the user choose the
EMF supports unsettable features to model the additional state.
> primitive types.
No, not if you consider that you might want being set to null to be
different from null being the default. E.g., <x xsi:nil="true"/> verses
x being absent is often interpreted as two different states.
> "strange".
Unfortunately things like UML and XML Schema have things that are kind
of strange from a Java point of view.
> to answer "becouse my uml toolkit has this limitation".
Or because Java has primitive types that are different from their
wrapper types...
> All ocl rules will had to be written to use wrappers, and will look
> alien to uml purists, and bigger too.
Not sure how it will look different in OCL. Do boolean and Boolean
look different for OCL?
I'm not sure the limitation?
> Someone that works with uml should not be bound with those EMF
> problems (UML-MOF problems are already a lot).
It seems to me that UML as no notion of primitive types verses their
correspond boxed types the way Java does, so I imagine there will always
been some mismatch.
> EMF will not evolve ?
While the UML specification might change in binary incompatible ways
every few years, that's not a choice I would make lightly with Ecore.
To support nillable elements in XML Schema, we already have very
reasonable support for enumeration values that can be assigned
null---it's just an EDataType wrapper and the generated API will look
identical---so if that's important to support, it's within easy reach
already.
> Thanks
Re: Enumeration Default Value [message #477975 is a reply to message #477949] Mon, 17 November 2008 03:28 Go to previous message
Alexandre,
To be fair, there is a difference between MultiplicityElement::lowerValue
and MultiplicityElement::lower; former is effectively typed by a "wrapper"
type and so is nullable, whereas the latter is typed by a primitive. So,
while MultiplicityElement::lowerBound() won't return null (since it too is
typed by a primitive), MultiplicityElement::getLowerValue() will - that's
why the OCL expression you mentioned references
MultiplicityElement::lowerValue instead of MultiplicityElement::lower.
These "limitations" you mention, at least in the case of profiles, arise
from the mapping of UML concepts to EMOF/Ecore concepts and from the fact
that some things which are expressable in Ecore (like whether a feature's
value has been set) aren't expressable in UML. To support an "unset" state
for stereotype properties, simply apply the Ecore profile and set the
EAttribute::isUnsettable tag to 'true'...
Kenn
news:a5c037f8b73afdc4d389f096a9566494$1@www.eclipse.org...
> lower bound:
> interoperate models between tools. And as pointed before, the lack of
> hability to say that some thing accept nulls, leaving the decision about
> the value assumed to default values or later check is important. For
> instance, I can use default values to simulate the "unset" state, but, if
> the default value changes, it's impossible to tell what situation the user
> choose the value and what the situation where the user left it unset. To
> primitive types.
> bigger too.
> a lot).
> will not evolve ?
> Thanks
Re: Enumeration Default Value [message #627008 is a reply to message #477808] Fri, 10 October 2008 16:52 Go to previous message
Alexandre,
Kenn
> Hi.
> Thanks
Re: Enumeration Default Value [message #627010 is a reply to message #477811] Fri, 10 October 2008 18:00 Go to previous message
Kenn,
Kenn Hussey wrote:
> Alexandre,
> Kenn
>> Hi.
>> Thanks
<html>
<head>
</head>
Kenn,<br>
<br>
<br>
<br>
Kenn
</pre>
<pre wrap="">Hi.
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Re: Enumeration Default Value [message #627030 is a reply to message #477813] Tue, 14 October 2008 16:24 Go to previous message
Kenn
Kenn,
Alexandre,
represent=20
Kenn
Hi.
literal.
=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
won't be=20
message=20
<A=20
that data=20
represent=20
Kenn
</PRE>
literal.
Re: Enumeration Default Value [message #627050 is a reply to message #477825] Mon, 20 October 2008 07:17 Go to previous message
Kenn,
fixed by now...
> Kenn
> Kenn,
> Kenn Hussey wrote:
>> Alexandre,
>> Kenn
>>> Hi.
>>> Thanks
<html>
<head>
</head>
Kenn,<br>
<br>
fixed by now...<br>
<br>
<br>
<style></style>
<div>&nbsp;</div>
Kenn,<br>
<br>
<br>
<br>
Kenn
</pre>
<pre wrap="">Hi.
</pre>
</blockquote>
</pre>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
Re: Enumeration Default Value [message #627161 is a reply to message #477847] Sat, 08 November 2008 09:23 Go to previous message
lower bound:
primitive types.
bigger too.
a lot).
will not evolve ?
Re: Enumeration Default Value [message #627162 is a reply to message #477949] Sat, 08 November 2008 09:59 Go to previous message
Alexandre,
Comments below.
> primitive types.
> "strange".
wrapper types...
been some mismatch.
already.
> Thanks
Re: Enumeration Default Value [message #627192 is a reply to message #477949] Mon, 17 November 2008 03:28 Go to previous message
Alexandre,
Kenn
> lower bound:
> primitive types.
> bigger too.
> a lot).
> will not evolve ?
> Thanks
Previous Topic:Stereotypes parameters
Next Topic:Enumeration and null values
Current Time: Sat Jul 19 08:42:50 EDT 2025
Powered by FUDForum. Page generated in 0.10120 seconds
