Home » Modeling » UML2 » Java uml model or profile
Java uml model or profile [message #477717] Fri, 12 September 2008 09:11 Go to next message
I looking for a Java uml model or profile with eclipse's uml2 format. Does
it exist? Does it includes generics types like Collections<E> ?
Found this article very interesting :
http://www.eclipse.org/articles/article.php?file=Article-Def ining-Generics-with-UML-Templates/index.html
But an UML model with all java constructs may help a lot.
Re: Java uml model or profile [message #477718 is a reply to message #477717] Fri, 12 September 2008 11:39 Go to previous messageGo to next message
Alexandre Torres schrieb:
> Hi, I looking for a Java uml model or profile with eclipse's uml2
> format. Does it exist? Does it includes generics types like
> Collections<E> ? Found this article very interesting :
> Thanks
Why not make your self one ?
I have just added generic support in the topcased uml importer(topcased
2.1). So you could just import the java sources.
greetings, urs.
Re: Java uml model or profile [message #477719 is a reply to message #477718] Fri, 12 September 2008 13:29 Go to previous messageGo to next message
Thx, I did a try in the topcased old importer. Going to look at the new
one.
Hand-made ? all the classes of java platform? :)
Or do you mean using a reverse eng. tool ?
Re: Java uml model or profile [message #477720 is a reply to message #477719] Sat, 13 September 2008 05:52 Go to previous messageGo to next message
> one.
> Hand-made ? all the classes of java platform? :) Or do you mean using a
> reverse eng. tool ?
I mean using the reverse tool in topcased, you can just import the rt
library and other as you like, I have also added the possibility of
importing other uml models to resolve the types. So you could start with
the rt library and work your self forward to all library's you will need.
see
http://gforge.enseeiht.fr/tracker/?func=detail&atid=109& amp;aid=1826&group_id=52
greetings, urs.
Re: Java uml model or profile [message #477736 is a reply to message #477717] Thu, 18 September 2008 18:25 Go to previous message
You can try EclipseUML 2008 Studio Edition and get full support of
generics (e.g. live code and model generic types synchronization &
defining generics). See our documentation at:
http://www.forum-omondo.com/documentation_eclipseuml_2008/jd k15/index.html
The EclpseUML 2008 Studio Edition 30 days trial license download is
available at: http://www.ejb3.org/download_studio_eclipse_3.4.html
Vlad,
Re: Java uml model or profile [message #626914 is a reply to message #477717] Fri, 12 September 2008 11:39 Go to previous message
> Thanks
greetings, urs.
Re: Java uml model or profile [message #626915 is a reply to message #477718] Fri, 12 September 2008 13:29 Go to previous message
one.
Re: Java uml model or profile [message #626916 is a reply to message #477719] Sat, 13 September 2008 05:52 Go to previous message
> one.
> reverse eng. tool ?
see
greetings, urs.
Re: Java uml model or profile [message #626935 is a reply to message #477717] Thu, 18 September 2008 18:25 Go to previous message
Vlad,
Previous Topic:file extensions clarification
Next Topic:Re: Anyone still use UML 1.4? Anyone have a UML 1.4 to UML 2.1 XMI file converter?
Current Time: Sat Jul 19 19:15:10 EDT 2025
Powered by FUDForum. Page generated in 0.05089 seconds
