Home » Modeling » UML2 » Re: Impossible to load UML model via Java code
Re: Impossible to load UML model via Java code [message #477709] |
Mon, 08 September 2008 08:08  |
--------------040509020302060109050906
Laurent,
It's best to ask about UML things on the UML2 newsgroup (I've added it
to the "to" list of the reply) and ask about compare on the EMFT
newsgroup. Be sure to read the UML2 FAQ:
http://wiki.eclipse.org/MDT-UML2-FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
And use google to find related similar questions:
http://www.google.com/cse?cx=017941334893793413703%3Asqfrdtd 112s&q=UML+load+stand+alone&sa=Search
< http://www.google.com/cse?cx=017941334893793413703%3Asqfrdtd 112s&q=UML+load+stand+alone&sa=Search>
Laurent Roubele wrote:
> Hello,
> I'm trying to load a model via java (emf) in order to merge it with
> another one... My UML model (.uml) was exported from Magic Draw into
> "EMF UML (v2.x) XMI". Here is my code :
> import java.io.File;
> import java.io.IOException;
> import java.util.ArrayList;
> import java.util.Calendar;
> import java.util.Collections;
> import java.util.List;
> import org.eclipse.emf.compare.diff.merge.service.MergeService;
> import org.eclipse.emf.compare.diff.metamodel.DiffElement;
> import org.eclipse.emf.compare.diff.metamodel.DiffFactory;
> import org.eclipse.emf.compare.diff.metamodel.DiffModel;
> import org.eclipse.emf.compare.diff.metamodel.ModelInputSnapshot;
> import org.eclipse.emf.compare.diff.service.DiffService;
> import org.eclipse.emf.compare.match.metamodel.MatchModel;
> import org.eclipse.emf.compare.match.service.MatchService;
> import org.eclipse.emf.compare.util.ModelUtils;
> import org.eclipse.emf.ecore.EObject;
> import org.eclipse.emf.ecore.resource.Resource;
> import org.eclipse.emf.ecore.resource.ResourceSet;
> import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
> import org.eclipse.uml2.uml.UMLPackage;
> import org.eclipse.uml2.uml.resource.UMLResource;
> public final class ExampleLauncher {
> * This class doesn't need to be instantiated.
> private ExampleLauncher() {
> // prevents instantiation
> public static void main(String[] args) {
> // Creates the resourceSet where we'll load the models
> final ResourceSet resourceSet = new ResourceSetImpl();
> // Register additional packages here. For UML2:
> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(
> UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
> resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
> UMLPackage.eINSTANCE);
> try {
> System.out.println("Loading resources.\n"); //$NON-NLS-1$
> // Loads the model to modify
> final EObject model1 = ModelUtils.load(new
> File("D:/eclipse/workspace/EMFTEST/model/model.uml"),resourceSet);
> System.out.println("Loaded.");
> } catch (Exception e) { // shouldn't be thrown
> e.printStackTrace();
> When I launch this sample I got a exception:
> Loading resources.
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFe atureType(XMLHandler.java:2132)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:2010)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:131)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1789)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1013)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:991)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:711)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
> Source)
> at
> Source)
> at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
> Source)
> at javax.xml.parsers.SAXParser.parse(Unknown Source)
> at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1414)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2516)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2397)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1275)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1444)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1009)
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1210)
> at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :320)
> at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :218)
> at ExampleLauncher.main(ExampleLauncher.java:68)
> In fact, I CAN load .ecore models via this sample code... But
> apparently no .uml models.
> Any ideas ?
> Regards,
> Laurent
<html>
<head>
http-equiv="Content-Type">
</head>
Laurent,<br>
<br>
newsgroup.
Re: Impossible to load UML model via Java code [message #477710 is a reply to message #477709] |
Mon, 08 September 2008 09:31  |
------=_NextPart_000_0032_01C91195.A8ADC6D0
charset="ISO-8859-15"
Content-Transfer-Encoding: quoted-printable
Hi Ed, Laurent,
The thread entitled "Continuing saga of the standalone app" has a =
complete project attached that demonstrates how to load a model (from a =
post on 7/22/2008).
In addition, have a look at =
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_G=
uide/guide.html
in the section "Programmatic Migration".
.... some other points...
Magic Draw has some known compatibility issues when it comes to its =
serialized format. For example, lowerValue of MultiplicityElement's =
sometimes is initialzed out with type uml:Integer with a value of '*' =
and sometimes as uml:LiteralInteger. lowerValue should be a =
ValueSpecification and so uml:Integer would be incorrect and '*' should =
only apply to LiteralUnlimitedNatural.
If the migration guides still do not help you, perhaps you could post a =
snippet of the model that demonstrates the isssue.
- James.
"Ed Merks" <Ed.Merks@gmail.com> wrote in message =
news:ga34k3$n8a$1@build.eclipse.org...
Laurent,
It's best to ask about UML things on the UML2 newsgroup (I've added it =
to the "to" list of the reply) and ask about compare on the EMFT =
http://wiki.eclipse.org/MDT-UML2-FAQ#What.27s_required_to_lo ad_a_UML_.28.=
uml.29_resource_from_a_standalone_application.3F
http://www.google.com/cse?cx=3D017941334893793413703%3Asqfrd td112s&q=3DUM=
L+load+stand+alone&sa=3DSearch
Laurent Roubele wrote:=20
Hello,=20
I'm trying to load a model via java (emf) in order to merge it with =
another one... My UML model (.uml) was exported from Magic Draw into =
"EMF UML (v2.x) XMI". Here is my code :=20
=20
import java.io.File;=20
import java.io.IOException;=20
import java.util.ArrayList;=20
import java.util.Calendar;=20
import java.util.Collections;=20
import java.util.List;=20
import org.eclipse.emf.compare.diff.merge.service.MergeService;=20
import org.eclipse.emf.compare.diff.metamodel.DiffElement;=20
import org.eclipse.emf.compare.diff.metamodel.DiffFactory;=20
import org.eclipse.emf.compare.diff.metamodel.DiffModel;=20
import org.eclipse.emf.compare.diff.metamodel.ModelInputSnapshot;=20
import org.eclipse.emf.compare.diff.service.DiffService;=20
import org.eclipse.emf.compare.match.metamodel.MatchModel;=20
import org.eclipse.emf.compare.match.service.MatchService;=20
import org.eclipse.emf.compare.util.ModelUtils;=20
import org.eclipse.emf.ecore.EObject;=20
import org.eclipse.emf.ecore.resource.Resource;=20
import org.eclipse.emf.ecore.resource.ResourceSet;=20
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;=20
import org.eclipse.uml2.uml.UMLPackage;=20
import org.eclipse.uml2.uml.resource.UMLResource;=20
public final class ExampleLauncher {=20
/**=20
* This class doesn't need to be instantiated.=20
*/=20
private ExampleLauncher() {=20
// prevents instantiation=20
}=20
public static void main(String[] args) {=20
// Creates the resourceSet where we'll load the models=20
final ResourceSet resourceSet =3D new ResourceSetImpl();=20
// Register additional packages here. For UML2:=20
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put( =
UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);=20
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,=20
UMLPackage.eINSTANCE);=20
try {=20
System.out.println("Loading resources.\n"); //$NON-NLS-1$=20
// Loads the model to modify=20
final EObject model1 =3D ModelUtils.load(new =
File("D:/eclipse/workspace/EMFTEST/model/model.uml"),resourceSet);=20
System.out.println("Loaded.");=20
} catch (Exception e) { // shouldn't be thrown=20
e.printStackTrace();=20
}=20
}=20
}=20
=20
When I launch this sample I got a exception:=20
Loading resources.=20
java.lang.NullPointerException=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFe atureType(XML=
Handler.java:2132)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:20=
10)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:13=
1)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1=
789)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:=
1013)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:=
87)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:99=
1)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:71=
1)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:16=
7)=20
at =
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement=
(Unknown Source)=20
at =
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.empt=
yElement(Unknown Source)=20
at =
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.sc=
anStartElement(Unknown Source)=20
at =
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$Fr=
agmentContentDriver.next(Unknown Source)=20
at =
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unkno=
wn Source)=20
at =
anDocument(Unknown Source)=20
at =
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unkno=
wn Source)=20
at =
wn Source)=20
at =
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown =
Source)=20
at =
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknow=
n Source)=20
at =
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse=
(Unknown Source)=20
at javax.xml.parsers.SAXParser.parse(Unknown Source)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.jav=
a:180)=20
at =
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1=
414)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.jav=
a:2516)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.=
java:2397)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.j=
ava:1275)=20
at =
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java=
:1444)=20
at =
1009)=20
at =
87)=20
at =
1)=20
at =
1)=20
at =
7)=20
at =
(Unknown Source)=20
at =
at =
at =
at =
wn Source)=20
at =
at =
wn Source)=20
at =
wn Source)=20
at =
Source)=20
at =
n Source)=20
at =
(Unknown Source)=20
at =
at =
a:180)=20
at =
414)=20
at =
a:2516)=20
at =
java:2397)=20
at =
ava:1275)=20
at =
:1444)=20
at =
1009)=20
at =
87)=20
at =
1)=20
at =
1)=20
at =
7)=20
at =
(Unknown Source)=20
at =
at =
at =
at =
wn Source)=20
at =
at =
wn Source)=20
at =
wn Source)=20
at =
Source)=20
at =
n Source)=20
at =
(Unknown Source)=20
at =
at =
a:180)=20
at =
414)=20
at =
a:2516)=20
at =
java:2397)=20
at =
ava:1275)=20
at =
:1444)=20
at =
1009)=20
at =
87)=20
at =
1)=20
at =
1)=20
at =
7)=20
at =
(Unknown Source)=20
at =
at =
at =
at =
wn Source)=20
at =
at =
wn Source)=20
at =
wn Source)=20
at =
Source)=20
at =
n Source)=20
at =
(Unknown Source)=20
at =
at =
a:180)=20
at =
414)=20
at =
210)=20
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :320) =
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :218) =
at ExampleLauncher.main(ExampleLauncher.java:68)=20
In fact, I CAN load .ecore models via this sample code... But =
apparently no .uml models.=20
Any ideas ?=20
Regards,=20
Laurent=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-15>
<META content=3D"MSHTML 6.00.2900.3268" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi Ed, Laurent,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>The thread entitled "Continuing saga of =
the=20
standalone app" has a complete project attached that demonstrates how to =
load a=20
model (from a post on 7/22/2008).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>In addition, have a look at <A=20
href=3D" http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Mig=
ration_Guide/guide.html">http://www.eclipse.org/modeling/mdt/uml2/docs/gu=
ides/UML2_2.0_Migration_Guide/guide.html</A></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>in the section "Programmatic=20
Migration".</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>... some other points...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Magic Draw has some known compatibility =
issues when=20
it comes to its serialized format. For example, lowerValue =
of=20
MultiplicityElement's sometimes is initialzed out with type uml:Integer =
with a=20
value of '*' and sometimes as uml:LiteralInteger. lowerValue =
should=20
be a ValueSpecification and so uml:Integer would be incorrect and '*' =
should=20
only apply to LiteralUnlimitedNatural.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>If the migration guides still do not =
help you,=20
perhaps you could post a snippet of the model that demonstrates the=20
isssue.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Cheers,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- James.</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>> wrote in =
message=20
<A=20
href=3D"news:ga34k3$n8a$1@build.eclipse.org">news:ga34k3$n8a$1@build.ecli=
pse.org</A>...</DIV>Laurent,<BR><BR>It's=20
best to ask about UML things on the UML2 newsgroup (I've added it to =
the "to"=20
list of the reply) and ask about compare on the EMFT newsgroup. =
Be sure=20
to read the UML2 FAQ:<BR>
<BLOCKQUOTE><A=20
href=3D" http://wiki.eclipse.org/MDT-UML2-FAQ#What.27s_required_to_lo ad_a_=
UML_.28.uml.29_resource_from_a_standalone_application.3F">http://wiki.ecl=
ipse.org/MDT-UML2-FAQ#What.27s_required_to_load_a_UML_.28.um l.29_resource=
_from_a_standalone_application.3F</A><BR></BLOCKQUOTE>And=20
use google to find related similar questions:<BR>
<BLOCKQUOTE><A=20
href=3D" http://www.google.com/cse?cx=3D017941334893793413703%3Asqfrd td112=
s&q=3DUML+load+stand+alone&sa=3DSearch">http://www.google.com/cse=
?cx=3D017941334893793413703%3Asqfrdtd112s&q=3DUML+lo ad+stand+alone&am=
p;sa=3DSearch<BR></A></BLOCKQUOTE><BR><BR>Laurent=20
Roubele wrote:=20
<BLOCKQUOTE =
cite=3Dmid:7fc92e8294bf0def37c8cbc8d8ed4ac6$1@www.eclipse.org=20
type=3D"cite">Hello, <BR><BR>I'm trying to load a model via java (emf) =
in=20
order to merge it with another one... My UML model (.uml) was =
exported from=20
Magic Draw into "EMF UML (v2.x) XMI". Here is my code : =
<BR><BR>=20
<BR>import java.io.File; <BR>import java.io.IOException; <BR>import=20
java.util.ArrayList; <BR>import java.util.Calendar; <BR>import=20
java.util.Collections; <BR>import java.util.List; <BR><BR>import=20
org.eclipse.emf.compare.diff.merge.service.MergeService; <BR>import=20
org.eclipse.emf.compare.diff.metamodel.DiffElement; <BR>import=20
org.eclipse.emf.compare.diff.metamodel.DiffFactory; <BR>import=20
org.eclipse.emf.compare.diff.metamodel.DiffModel; <BR>import=20
org.eclipse.emf.compare.diff.metamodel.ModelInputSnapshot; =
<BR>import=20
org.eclipse.emf.compare.diff.service.DiffService; <BR>import=20
org.eclipse.emf.compare.match.metamodel.MatchModel; <BR>import=20
org.eclipse.emf.compare.match.service.MatchService; <BR>import=20
org.eclipse.emf.compare.util.ModelUtils; <BR>import=20
org.eclipse.emf.ecore.EObject; <BR>import=20
org.eclipse.emf.ecore.resource.Resource; <BR>import=20
org.eclipse.emf.ecore.resource.ResourceSet; <BR>import=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl; <BR>import=20
org.eclipse.uml2.uml.UMLPackage; <BR>import=20
org.eclipse.uml2.uml.resource.UMLResource; <BR><BR>public final =
class=20
ExampleLauncher { <BR> /** <BR> * This class doesn't =
need to be=20
instantiated. <BR> */ <BR> private ExampleLauncher() {=20
<BR> // prevents instantiation <BR>} <BR><BR>public static =
void=20
main(String[] args) { <BR> // Creates the resourceSet where =
we'll load=20
the models <BR> final ResourceSet resourceSet =3D new =
<BR><BR> // Register additional packages here. For UML2: =
<BR> =20
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(=20
<BR> UMLResource.FILE_EXTENSION, =
<BR> resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,=20
<BR> UMLPackage.eINSTANCE); <BR><BR> try {=20
<BR> System.out.println("Loading =
resources.\n");=20
//$NON-NLS-1$ <BR> // Loads the model to =
modify=20
<BR> final EObject model1 =3D =
ModelUtils.load(new=20
<BR><BR> System.out.println("Loaded."); =
<BR> }=20
catch (Exception e) { // shouldn't be thrown =
<BR> =20
e.printStackTrace(); <BR> } <BR> } <BR>} <BR> =20
<BR><BR>When I launch this sample I got a exception: <BR>Loading =
resources.=20
<BR><BR>java.lang.NullPointerException <BR>at=20
<BR>at=20
10)=20
<BR>at=20
1)=20
<BR>at=20
789)=20
<BR>at=20
1013)=20
<BR>at=20
87)=20
<BR>at=20
1)=20
<BR>at=20
1)=20
<BR>at=20
7)=20
<BR>at=20
(Unknown=20
Source) <BR>at=20
yElement(Unknown=20
Source) <BR>at=20
anStartElement(Unknown=20
Source) <BR>at=20
agmentContentDriver.next(Unknown=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
anDocument(Unknown=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source)=20
<BR>at=20
n=20
Source) <BR>at=20
(Unknown=20
Source) <BR>at javax.xml.parsers.SAXParser.parse(Unknown Source) =
<BR>at=20
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181) =
<BR>at=20
a:180)=20
<BR>at=20
414)=20
<BR>at=20
a:2516)=20
<BR>at=20
java:2397)=20
<BR>at=20
ava:1275)=20
<BR>at=20
:1444)=20
<BR>at=20
1009)=20
<BR>at=20
87)=20
<BR>at=20
1)=20
<BR>at=20
1)=20
<BR>at=20
7)=20
<BR>at=20
(Unknown=20
Source) <BR>at=20
yElement(Unknown=20
Source) <BR>at=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source)=20
<BR>at=20
n=20
Source) <BR>at=20
(Unknown=20
<BR>at=20
<BR>at=20
a:180)=20
<BR>at=20
414)=20
<BR>at=20
a:2516)=20
<BR>at=20
java:2397)=20
<BR>at=20
ava:1275)=20
<BR>at=20
:1444)=20
<BR>at=20
1009)=20
<BR>at=20
87)=20
<BR>at=20
1)=20
<BR>at=20
1)=20
<BR>at=20
7)=20
<BR>at=20
(Unknown=20
Source) <BR>at=20
yElement(Unknown=20
Source) <BR>at=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source)=20
<BR>at=20
n=20
Source) <BR>at=20
(Unknown=20
<BR>at=20
<BR>at=20
a:180)=20
<BR>at=20
414)=20
<BR>at=20
a:2516)=20
<BR>at=20
java:2397)=20
<BR>at=20
ava:1275)=20
<BR>at=20
:1444)=20
<BR>at=20
1009)=20
<BR>at=20
87)=20
<BR>at=20
1)=20
<BR>at=20
1)=20
<BR>at=20
7)=20
<BR>at=20
(Unknown=20
Source) <BR>at=20
yElement(Unknown=20
Source) <BR>at=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source)=20
<BR>at=20
n=20
Source) <BR>at=20
(Unknown=20
<BR>at=20
<BR>at=20
a:180)=20
<BR>at=20
414)=20
<BR>at=20
210)=20
<BR>at =
org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :320)=20
<BR>at =
org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :218)=20
<BR>at ExampleLauncher.main(ExampleLauncher.java:68) <BR><BR>In =
fact, I CAN=20
load .ecore models via this sample code... But apparently no .uml =
models.=20
<BR><BR>Any ideas ? <BR><BR>Regards, <BR><BR>Laurent=20
<BR><BR></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0032_01C91195.A8ADC6D0--
Re: Impossible to load UML model via Java code [message #626904 is a reply to message #477709] |
Hi Ed, Laurent,
post on 7/22/2008).
uide/guide.html
- James.
Laurent,
Hello,=20
=20
/**=20
*/=20
}=20
try {=20
}=20
}=20
}=20
=20
at =
at =
10)=20
at =
1)=20
at =
789)=20
at =
1013)=20
at =
87)=20
at =
1)=20
at =
1)=20
at =
7)=20
at =
(Unknown Source)=20
at =
at =
at =
at =
wn Source)=20
at =
at =
wn Source)=20
at =
wn Source)=20
at =
Source)=20
at =
n Source)=20
at =
(Unknown Source)=20
at =
at =
a:180)=20
at =
414)=20
at =
a:2516)=20
at =
java:2397)=20
at =
ava:1275)=20
at =
:1444)=20
at =
1009)=20
at =
87)=20
at =
1)=20
at =
1)=20
at =
7)=20
at =
(Unknown Source)=20
at =
at =
at =
at =
wn Source)=20
at =
at =
wn Source)=20
at =
wn Source)=20
at =
Source)=20
at =
n Source)=20
at =
(Unknown Source)=20
at =
at =
a:180)=20
at =
414)=20
at =
a:2516)=20
at =
java:2397)=20
at =
ava:1275)=20
at =
:1444)=20
at =
1009)=20
at =
87)=20
at =
1)=20
at =
1)=20
at =
7)=20
at =
(Unknown Source)=20
at =
at =
at =
at =
wn Source)=20
at =
at =
wn Source)=20
at =
wn Source)=20
at =
Source)=20
at =
n Source)=20
at =
(Unknown Source)=20
at =
at =
a:180)=20
at =
414)=20
at =
a:2516)=20
at =
java:2397)=20
at =
ava:1275)=20
at =
:1444)=20
at =
1009)=20
at =
87)=20
at =
1)=20
at =
1)=20
at =
7)=20
at =
(Unknown Source)=20
at =
at =
at =
at =
wn Source)=20
at =
at =
wn Source)=20
at =
wn Source)=20
at =
Source)=20
at =
n Source)=20
at =
(Unknown Source)=20
at =
at =
a:180)=20
at =
414)=20
at =
210)=20
Any ideas ?=20
Regards,=20
Laurent=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
the=20
load a=20
issues when=20
of=20
with a=20
should=20
should=20
help you,=20
message=20
<A=20
the "to"=20
Be sure=20
<BLOCKQUOTE><A=20
<BLOCKQUOTE><A=20
Roubele wrote:=20
<BLOCKQUOTE =
in=20
exported from=20
<BR><BR>=20
<BR>import=20
class=20
need to be=20
void=20
we'll load=20
<BR> =20
resources.\n");=20
modify=20
<BR> }=20
<BR> =20
resources.=20
<BR>at=20
10)=20
<BR>at=20
1)=20
<BR>at=20
789)=20
<BR>at=20
1013)=20
<BR>at=20
87)=20
<BR>at=20
1)=20
<BR>at=20
1)=20
<BR>at=20
7)=20
<BR>at=20
(Unknown=20
Source) <BR>at=20
yElement(Unknown=20
Source) <BR>at=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source)=20
<BR>at=20
n=20
Source) <BR>at=20
(Unknown=20
<BR>at=20
<BR>at=20
a:180)=20
<BR>at=20
414)=20
<BR>at=20
a:2516)=20
<BR>at=20
java:2397)=20
<BR>at=20
ava:1275)=20
<BR>at=20
:1444)=20
<BR>at=20
1009)=20
<BR>at=20
87)=20
<BR>at=20
1)=20
<BR>at=20
1)=20
<BR>at=20
7)=20
<BR>at=20
(Unknown=20
Source) <BR>at=20
yElement(Unknown=20
Source) <BR>at=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source)=20
<BR>at=20
n=20
Source) <BR>at=20
(Unknown=20
<BR>at=20
<BR>at=20
a:180)=20
<BR>at=20
414)=20
<BR>at=20
a:2516)=20
<BR>at=20
java:2397)=20
<BR>at=20
ava:1275)=20
<BR>at=20
:1444)=20
<BR>at=20
1009)=20
<BR>at=20
87)=20
<BR>at=20
1)=20
<BR>at=20
1)=20
<BR>at=20
7)=20
<BR>at=20
(Unknown=20
Source) <BR>at=20
yElement(Unknown=20
Source) <BR>at=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source)=20
<BR>at=20
n=20
Source) <BR>at=20
(Unknown=20
<BR>at=20
<BR>at=20
a:180)=20
<BR>at=20
414)=20
<BR>at=20
a:2516)=20
<BR>at=20
java:2397)=20
<BR>at=20
ava:1275)=20
<BR>at=20
:1444)=20
<BR>at=20
1009)=20
<BR>at=20
87)=20
<BR>at=20
1)=20
<BR>at=20
1)=20
<BR>at=20
7)=20
<BR>at=20
(Unknown=20
Source) <BR>at=20
yElement(Unknown=20
Source) <BR>at=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
wn=20
Source) <BR>at=20
Source)=20
<BR>at=20
n=20
Source) <BR>at=20
(Unknown=20
<BR>at=20
<BR>at=20
a:180)=20
<BR>at=20
414)=20
<BR>at=20
210)=20
<BR>at =
<BR>at =
fact, I CAN=20
models.=20
Current Time: Sun Jul 20 18:33:50 EDT 2025
Powered by FUDForum. Page generated in 0.44774 seconds
