Home » Modeling » UML2 » apply stereotype problem with static profile
Re: apply stereotype problem with static profile [message #477423 is a reply to message #477420] |
Wed, 21 May 2008 12:35   |
Hi James,
I've tried the more detailed tutorial. But with the same result as I mentioned
earlier...
So my guess is that there's something wrong!?
Andreas
Hello James,
> Hi Andreas,
> The instructions in that document was a very rough guideline. There
> are more detailed instructions in the following tutorial.
> http://archive.eclipse.org/modeling/mdt/updates/EclipseCon20 08-UML-Tut
> orial/
> (point your update manager to the above mentioned site and you will
> get a detailed step-by-step set of instructions on how that works).
> In the meantime, I will retrace those steps and see if there is some
> other bug that was introduced.
> Cheers,
> - James.
> "Andreas Werner" <andreas.werner@itso-berlin.de> wrote in message
> news:cae16bdf4e7038ca893e96fcf7f2@news.eclipse.org...
>> Hi,
>> yesterday I've played with the new static profile definition feature.
>> Thus I followed the instructions given in the tutorial document
>> mentioned here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=205480
>> The problem was that I couldn't apply the defined stereotype in the
>> last
>> step of the tutorial - so no tada :(! To be more precise, the
>> stereotype
>> can be chosen in the apply action, but after pressing the OK button,
>> the
>> editor doesn't reflect the application.
>> Here is what the uml file looks like after the application:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <xmi:XMI xmi:version="2.1"
>> xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
>> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
>> xmlns:myStaticProfile="http://myOrg/MyStaticProfile/1"
>> xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML">
>> <uml:Model xmi:id="_R0UCgCZaEd2E9PIG8J1dpA">
>> <packagedElement xmi:type="uml:Class"
>> xmi:id="_8WBfgCZaEd2ORuhidzgP6Q"
>> name="C1"/>
>> <profileApplication xmi:id="_2z9oUCZeEd2ORuhidzgP6Q">
>> <eAnnotations xmi:id="_2z9oUSZeEd2ORuhidzgP6Q"
>> source="http://www.eclipse.org/uml2/2.0.0/UML">
>> <references xmi:type="ecore:EPackage"
>> href="http://myOrg/MyStaticProfile/1#/"/>
>> </eAnnotations>
>> <appliedProfile
>> href="MyStaticProfile.profile.uml#_EFqWoCZZEd2kmddgvlfjBA"/ >
>> </profileApplication>
>> </uml:Model>
>> <myStaticProfile:MyVerySpecialClass
>> xmi:id="_TtEhoCZfEd2ORuhidzgP6Q"/>
>> </xmi:XMI>
>> Has anybody also problems with this?
>> Kind regards, Andreas
Re: apply stereotype problem with static profile [message #477430 is a reply to message #477423] |
Fri, 23 May 2008 14:01   |
Hi Andreas, James,
I was able to reproduce the problem with either instructions (.doc and
EclipseCon tutorial).
I found the problem in a new option of the UML-Ecore importer (as of
2.2.0RC1): "Camel Case Names", which changes the base_Class reference of
the stereotype to baseClass. Setting this option to "Ignore" resolves
the issue and everything works fine.
Marco
Andreas Werner schrieb:
> Hi James,
> mentioned earlier...
> Andreas
> Hello James,
>> Hi Andreas,
>> orial/
>> Cheers,
>> - James.
>>> Hi,
>>> last
>>> stereotype
>>> the
>>> name="C1"/>
>>> </eAnnotations>
>>> <appliedProfile
>>> </uml:Model>
>>> </xmi:XMI>
Re: apply stereotype problem with static profile [message #477441 is a reply to message #477430] |
Mon, 26 May 2008 05:09   |
Hello Marco,
changing the option did indeed work!
Thank you very much,
Andreas
> Hi Andreas, James,
> of
> Marco
>> Hi James,
>> Andreas
>> Hello James,
>>> Hi Andreas,
>>> ut orial/
>>> Cheers,
>>> - James.
>>>> Hi,
>>>> feature. Thus I followed the instructions given in the tutorial
>>>> document mentioned here:
>>>> last
>>>> stereotype
>>>> button,
>>>> the
>>>> name="C1"/>
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> </uml:Model>
>>>> </xmi:XMI>
Re: apply stereotype problem with static profile [message #477444 is a reply to message #477430] |
Mon, 26 May 2008 09:27   |
Thanks for that Marco,
I was using "ignore" and could not reproduce the issue myself. I will have
a look at fixing that.
- James.
"Marco Mosconi" <mosconi@cs.tu-berlin.de> wrote in message
news:g170q6$kce$1@build.eclipse.org...
> Hi Andreas, James,
> the stereotype to baseClass. Setting this option to "Ignore" resolves the
> Marco
>> Hi James,
>> Andreas
>> Hello James,
>>> Hi Andreas,
>>> orial/
>>> Cheers,
>>> - James.
>>>> Hi,
>>>> last
>>>> stereotype
>>>> the
>>>> name="C1"/>
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> </uml:Model>
>>>> </xmi:XMI>
Re: apply stereotype problem with static profile [message #477445 is a reply to message #477444] |
Mon, 26 May 2008 09:43  |
Hi James,
I don't know about the "magic" that computes the camelcase names (and
how needs this ;-) but perhaps the converter could/should just ignore
this feature for Profiles in general.
Marco
> Cheers,
> - James.
>> Hi Andreas, James,
>> Marco
>>> Hi James,
>>> Andreas
>>> Hello James,
>>>> Hi Andreas,
>>>> orial/
>>>> Cheers,
>>>> - James.
>>>>> Hi,
>>>>> last
>>>>> stereotype
>>>>> the
>>>>> name="C1"/>
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> </uml:Model>
>>>>> </xmi:XMI>
Re: apply stereotype problem with static profile [message #626605 is a reply to message #477420] |
Hi James,
earlier...
Andreas
Hello James,
> Hi Andreas,
> orial/
> Cheers,
> - James.
>> Hi,
>> last
>> stereotype
>> the
>> name="C1"/>
>> </eAnnotations>
>> <appliedProfile
>> </uml:Model>
>> </xmi:XMI>
Re: apply stereotype problem with static profile [message #626612 is a reply to message #477423] |
Hi Andreas, James,
Marco
> Hi James,
> Andreas
> Hello James,
>> Hi Andreas,
>> orial/
>> Cheers,
>> - James.
>>> Hi,
>>> last
>>> stereotype
>>> the
>>> name="C1"/>
>>> </eAnnotations>
>>> <appliedProfile
>>> </uml:Model>
>>> </xmi:XMI>
Re: apply stereotype problem with static profile [message #626623 is a reply to message #477430] |
Hello Marco,
Andreas
> Hi Andreas, James,
> of
> Marco
>> Hi James,
>> Andreas
>> Hello James,
>>> Hi Andreas,
>>> ut orial/
>>> Cheers,
>>> - James.
>>>> Hi,
>>>> last
>>>> stereotype
>>>> button,
>>>> the
>>>> name="C1"/>
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> </uml:Model>
>>>> </xmi:XMI>
Re: apply stereotype problem with static profile [message #626626 is a reply to message #477430] |
- James.
> Hi Andreas, James,
> Marco
>> Hi James,
>> Andreas
>> Hello James,
>>> Hi Andreas,
>>> orial/
>>> Cheers,
>>> - James.
>>>> Hi,
>>>> last
>>>> stereotype
>>>> the
>>>> name="C1"/>
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> </uml:Model>
>>>> </xmi:XMI>
Re: apply stereotype problem with static profile [message #626627 is a reply to message #477444] |
Hi James,
Marco
> Cheers,
> - James.
>> Hi Andreas, James,
>> Marco
>>> Hi James,
>>> Andreas
>>> Hello James,
>>>> Hi Andreas,
>>>> orial/
>>>> Cheers,
>>>> - James.
>>>>> Hi,
>>>>> last
>>>>> stereotype
>>>>> the
>>>>> name="C1"/>
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> </uml:Model>
>>>>> </xmi:XMI>
Current Time: Sat Jul 19 09:30:58 EDT 2025
Powered by FUDForum. Page generated in 0.05686 seconds
