Home » Modeling » UML2 » set a stereotype property value
set a stereotype property value [message #476930] Wed, 13 February 2008 04:50 Go to next message
Hi all,
I've defined a profile with several sterotypes. I need to set a property
value of a stereotype manually in Java.
I know that it can be done with the followings lines:
namedElement.setValue(stereotype, property.getName(), value);
It's OK when I set a property with a primitive type like String.
Now I need to set a property which reference another Stereotype.
Example:
Profile myProfile
- Stereotype s1
- Stereotype s2
- Property name:String
- Property s1_reference: s1
I would like to set the "s1_reference" but I have problems with type.
Thanks for help,
Re: set a stereotype property value [message #476931 is a reply to message #476930] Wed, 13 February 2008 10:40 Go to previous messageGo to next message
Hi Emilien,
I'm not sure what you mean by "I have problems with type". Could you
elaborate? Do you mean that you are not sure what to set as the type of
the property? or do you have an issue with setValue() not working?
- James.
"Emilien Perico" <emilien.perico@atosorigin.com> wrote in message
news:91254c76c8c107bdcd2b1d78cba82c7c$1@www.eclipse.org...
> Hi all,
> Example:
> Profile myProfile
> - Stereotype s1
> - Stereotype s2
> Thanks for help,
Re: set a stereotype property value [message #476932 is a reply to message #476931] Wed, 13 February 2008 11:32 Go to previous messageGo to next message
Thanks for reply James,
I mean I don't succed to set the value for a referenced stereotype.
I don't know what to set as the type of the property when this one
references another stereotype.
When I get a same type, previously added from the modeller, I get a
DynamicEObjectImpl.
Do I have to build an object with the same type ? How ?
Re: set a stereotype property value [message #476934 is a reply to message #476932] Thu, 14 February 2008 08:57 Go to previous message
Here the good way,
Profile myProfile
- Stereotype s1
- Stereotype s2
To set the value "s1" to the property "s1_reference". You have to do this:
EObject s1Reference = classWithS1.getStereotypeApplication(s1);
Property s1RefProp = s2.getAttribute("s1_reference", null);
classWithS2.setValue(s2, s1RefProp.getName(), s1Reference);
Here the reference to help
http://dev.eclipse.org/newslists/news.eclipse.modeling.mdt.u ml2/msg01630.html
Emilien.
Re: set a stereotype property value [message #626030 is a reply to message #476930] Wed, 13 February 2008 10:40 Go to previous message
Hi Emilien,
- James.
> Hi all,
> Example:
> Profile myProfile
> - Stereotype s1
> - Stereotype s2
> Thanks for help,
Re: set a stereotype property value [message #626031 is a reply to message #476931] Wed, 13 February 2008 11:32 Go to previous message
DynamicEObjectImpl.
Re: set a stereotype property value [message #626033 is a reply to message #476932] Thu, 14 February 2008 08:57 Go to previous message
Here the good way,
Profile myProfile
- Stereotype s1
- Stereotype s2
Emilien.
Previous Topic:how to find out the type of element in a package
Next Topic:Re: unknown protocol: pathmap
Current Time: Sat Jul 19 23:17:08 EDT 2025
Powered by FUDForum. Page generated in 0.04022 seconds
