Home » Modeling » TMF (Xtext) » need hint regarding 'parsability'
need hint regarding 'parsability' [message #610480] Tue, 21 September 2010 16:54 Go to next message
I have an issue in b3 regarding value conversion. When versions are
entered, they can be entered without escapes or quotes and they are
transformed into instances of Version and VersionRange (as used by p2).
Example: 1.0.0.v201008123456790
If the version contains 'odd characters' or 'keywords' the version is
entered as a String. Example "1.0.0.ouch_if".
When converting a Version value back, I would like to know if it will
require quoting or not. Is there a way to check if the grammar would
accept the unquoted string?
- henrik
Re: need hint regarding 'parsability' [message #619624 is a reply to message #610480] Tue, 21 September 2010 19:52 Go to previous messageGo to next message
Hi Henrik,
I'm afraid you have to implement this on your own. Have a look at the
default ID converter which queries the grammar for all keywords to
decide whether an id has to be quoted (prefixed with ^) or not. The same
should be possible for your versions as well.
Another alternative would be to inject the parser into the value
converter and invoke the respective entry rule for your data types.
Sebastian
Am 21.09.10 22:54, schrieb Henrik Lindberg:
> Regards
> - henrik
Re: need hint regarding 'parsability' [message #625379 is a reply to message #619624] Wed, 22 September 2010 04:30 Go to previous messageGo to next message
On 9/22/10 1:52 AM, Sebastian Zarnekow wrote:
> Hi Henrik,
ok, I have seen that.
Can you elaborate a bit on what "invoke the respective entry rule for
your data types" mean?
(This approach is what I think I want).
- henrik
Re: need hint regarding 'parsability' [message #625454 is a reply to message #625379] Wed, 22 September 2010 04:43 Go to previous messageGo to next message
Hi Henrik,
you could try something like this:
@Inject
IParser parser;
IParseResult result = parser.parse(grammarAccess.getVersion().getName(),
new StringReader("1.0.0.foo_if"));
The result should contain information about the syntax errors.
Sebastian
Am 22.09.10 10:30, schrieb Henrik Lindberg:
>> Hi Henrik,
> Regards
> - henrik
Re: need hint regarding 'parsability' [message #625672 is a reply to message #625454] Wed, 22 September 2010 05:44 Go to previous messageGo to next message
The method mentioned is protected in the generated parser, so I guess I
have to derive a new class that exposes this functionality - i.e.
protected IParseResult parse(String ruleName, CharStream in)
- henrik
On 9/22/10 10:43 AM, Sebastian Zarnekow wrote:
> Hi Henrik,
> @Inject
> IParser parser;
> Regards,
> Sebastian
Re: need hint regarding 'parsability' [message #625820 is a reply to message #625672] Wed, 22 September 2010 06:27 Go to previous messageGo to next message
Sorry about the noise - the method *is* public in the parser generated
for the grammar - only a cast was required.
Duh...
- henrik
> Regards
> - henrik
>> Hi Henrik,
>> @Inject
>> IParser parser;
>> Regards,
>> Sebastian
Re: need hint regarding 'parsability' [message #626239 is a reply to message #625820] Wed, 22 September 2010 09:05 Go to previous message
And - it works like a charm!!
Exactly what I wanted. Thanks for the hint Sebastian.
- henrik
> Duh...
> - henrik
>> Regards
>> - henrik
>>> Hi Henrik,
>>> @Inject
>>> IParser parser;
>>> Regards,
>>> Sebastian
Previous Topic:is there a batch validation hook in Xtext?
Next Topic:best practice - applying formatting?
Current Time: Sun Jul 20 02:31:23 EDT 2025
Powered by FUDForum. Page generated in 0.04717 seconds
