Home » Modeling » UML2 » Reapplying a profile after its has be re-defined
Reapplying a profile after its has be re-defined [message #476763] |
Sat, 15 December 2007 15:11  |
Im still trying to get the hang of how profiles work and Im in cycle of
changing a profile with many redefines.
How ever when I drop and replace the file "bsc.profile.uml" and opens an
existing '*.uml' file where i have applied the profile, the
connection /references to applied stereotypes seems lost
And at the top level in the my1.uml file there are now extra elements
outside the <uml:Model> element.
Such as:
<BusinessSemanticComponent:SemanticComponent
xmi:id="_pSRaEKs9Edypn7TO-27LDg" base_Classifier="_oZuiAKpMEdy6V5U3TuHlaQ"/>
More over in the ProfileApplication element in *.uml file the
UML::Reference is now = "null"
I always define the profile after changed and I keep the
annotation:nsURI to the same value between defines.
I also keep the latest annotation in profile file (i.e I remove the last
one since I make soo many changed/addition)
thanks for any hints
/anders
Re: Reapplying a profile after its has be re-defined [message #476775 is a reply to message #476774] |
Mon, 17 December 2007 13:10   |
Anders,
The UML specification doesn't dictate how tools are supposed to behave in
this area, so yes, it's conformant.
To update applied stereotypes to a new definition of a profile, simply
reapply the profile; tag values will be automatically be migrated on a
best-effort basis.
IDs shouldn't change every time the profie is saved; how are you saving the
profile: using the editor or from a Java program?
Kenn
"Anders W.Tell" <opensource@toolsmiths.se> wrote in message
news:fk6de6$6il$3@build.eclipse.org...
> Kenn,
> Ok, is this behavior conformant with OMG profiling? Does this work
> portable with profiles expressed in plain XMI?
> How to one automatically update an existing applied profile (in an *.uml)
> to a newer and improved one?
> One problem (for me) seems that the ID of stereotypes changes when one
> save the profile.uml. Is it possible to prevent the saving of new ID for
> stereotype?
> /anders
> Kenn Hussey wrote:
>> Anders,
>> If you're deleting annotations, you're deleting the metadata that is
>> needed in order to successfully recognize stereotype applications based
>> on older versions of the profile... So if you want to keep your
>> stereotype applications, don't delete the annotations.
>> Kenn
>> news:fk1cdf$40j$1@build.eclipse.org...
>>> Hi,
>>> existing '*.uml' file where i have applied the profile, the connection
>>> Such as:
>>> /anders
Re: Reapplying a profile after its has be re-defined [message #476784 is a reply to message #476773] |
Tue, 18 December 2007 09:17   |
--------------020808090907040606030806
Anders W.Tell schrieb:
> Interesting is it difficult?
> /anders
Not really, you can use this transformation as a base.
name="uml2copy_direct_with_Stereotypes.atl"
Content-Disposition: inline;
filename="uml2copy_direct_with_Stereotypes.atl"
-- @atlcompiler atl2006
module Transformation;
create OUT : UML2 from IN : UML2,PRO:UML2;
helper def : inElements : Set(UML2!"ecore::EObject") = UML2!"ecore::EObject"->allInstancesFrom('IN');
helper def : isIncluded(invar : OclAny) : Boolean =
true
helper def : CommentGuard(invar : UML2!"uml::Comment") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Comment") ;
helper def : PackageGuard(invar : UML2!"uml::Package") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Package") ;
helper def : DependencyGuard(invar : UML2!"uml::Dependency") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Dependency") ;
helper def : ElementImportGuard(invar : UML2!"uml::ElementImport") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ElementImport") ;
helper def : PackageImportGuard(invar : UML2!"uml::PackageImport") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::PackageImport") ;
helper def : ConstraintGuard(invar : UML2!"uml::Constraint") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Constraint") ;
helper def : AssociationGuard(invar : UML2!"uml::Association") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Association") ;
helper def : TemplateBindingGuard(invar : UML2!"uml::TemplateBinding") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TemplateBinding") ;
helper def : TemplateSignatureGuard(invar : UML2!"uml::TemplateSignature") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TemplateSignature") ;
helper def : TemplateParameterGuard(invar : UML2!"uml::TemplateParameter") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TemplateParameter") ;
helper def : TemplateParameterSubstitutionGuard(invar : UML2!"uml::TemplateParameterSubstitution") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TemplateParameterSubstitution") ;
helper def : GeneralizationGuard(invar : UML2!"uml::Generalization") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Generalization") ;
helper def : GeneralizationSetGuard(invar : UML2!"uml::GeneralizationSet") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::GeneralizationSet") ;
helper def : SubstitutionGuard(invar : UML2!"uml::Substitution") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Substitution") ;
helper def : RealizationGuard(invar : UML2!"uml::Realization") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Realization") ;
helper def : AbstractionGuard(invar : UML2!"uml::Abstraction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Abstraction") ;
helper def : OpaqueExpressionGuard(invar : UML2!"uml::OpaqueExpression") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::OpaqueExpression") ;
helper def : ParameterGuard(invar : UML2!"uml::Parameter") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Parameter") ;
helper def : ConnectableElementTemplateParameterGuard(invar : UML2!"uml::ConnectableElementTemplateParameter") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ConnectableElementTemplateParameter ") ;
helper def : ConnectorEndGuard(invar : UML2!"uml::ConnectorEnd") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ConnectorEnd") ;
helper def : PropertyGuard(invar : UML2!"uml::Property") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Property") ;
helper def : DeploymentGuard(invar : UML2!"uml::Deployment") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Deployment") ;
helper def : DeploymentSpecificationGuard(invar : UML2!"uml::DeploymentSpecification") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DeploymentSpecification") ;
helper def : ArtifactGuard(invar : UML2!"uml::Artifact") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Artifact") ;
helper def : ManifestationGuard(invar : UML2!"uml::Manifestation") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Manifestation") ;
helper def : OperationGuard(invar : UML2!"uml::Operation") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Operation") ;
helper def : ClassGuard(invar : UML2!"uml::Class") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Class") ;
helper def : InterfaceRealizationGuard(invar : UML2!"uml::InterfaceRealization") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InterfaceRealization") ;
helper def : InterfaceGuard(invar : UML2!"uml::Interface") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Interface") ;
helper def : ReceptionGuard(invar : UML2!"uml::Reception") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Reception") ;
helper def : SignalGuard(invar : UML2!"uml::Signal") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Signal") ;
helper def : ProtocolStateMachineGuard(invar : UML2!"uml::ProtocolStateMachine") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ProtocolStateMachine") ;
helper def : StateMachineGuard(invar : UML2!"uml::StateMachine") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::StateMachine") ;
helper def : RegionGuard(invar : UML2!"uml::Region") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Region") ;
helper def : TransitionGuard(invar : UML2!"uml::Transition") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Transition") ;
helper def : TriggerGuard(invar : UML2!"uml::Trigger") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Trigger") ;
helper def : PortGuard(invar : UML2!"uml::Port") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Port") ;
helper def : StateGuard(invar : UML2!"uml::State") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::State") ;
helper def : ConnectionPointReferenceGuard(invar : UML2!"uml::ConnectionPointReference") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ConnectionPointReference") ;
helper def : PseudostateGuard(invar : UML2!"uml::Pseudostate") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Pseudostate") ;
helper def : ProtocolConformanceGuard(invar : UML2!"uml::ProtocolConformance") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ProtocolConformance") ;
helper def : ConnectorGuard(invar : UML2!"uml::Connector") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Connector") ;
helper def : ExtensionGuard(invar : UML2!"uml::Extension") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Extension") ;
helper def : ExtensionEndGuard(invar : UML2!"uml::ExtensionEnd") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ExtensionEnd") ;
helper def : StereotypeGuard(invar : UML2!"uml::Stereotype") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Stereotype") ;
helper def : ImageGuard(invar : UML2!"uml::Image") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Image") ;
helper def : ProfileGuard(invar : UML2!"uml::Profile") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Profile") ;
helper def : ModelGuard(invar : UML2!"uml::Model") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Model") ;
helper def : ParameterSetGuard(invar : UML2!"uml::ParameterSet") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ParameterSet") ;
helper def : DataTypeGuard(invar : UML2!"uml::DataType") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DataType") ;
helper def : OperationTemplateParameterGuard(invar : UML2!"uml::OperationTemplateParameter") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::OperationTemplateParameter") ;
helper def : CollaborationUseGuard(invar : UML2!"uml::CollaborationUse") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CollaborationUse") ;
helper def : CollaborationGuard(invar : UML2!"uml::Collaboration") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Collaboration") ;
helper def : UseCaseGuard(invar : UML2!"uml::UseCase") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::UseCase") ;
helper def : IncludeGuard(invar : UML2!"uml::Include") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Include") ;
helper def : ExtendGuard(invar : UML2!"uml::Extend") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Extend") ;
helper def : ExtensionPointGuard(invar : UML2!"uml::ExtensionPoint") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ExtensionPoint") ;
helper def : RedefinableTemplateSignatureGuard(invar : UML2!"uml::RedefinableTemplateSignature") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::RedefinableTemplateSignature") ;
helper def : ClassifierTemplateParameterGuard(invar : UML2!"uml::ClassifierTemplateParameter") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ClassifierTemplateParameter") ;
helper def : StringExpressionGuard(invar : UML2!"uml::StringExpression") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::StringExpression") ;
helper def : ExpressionGuard(invar : UML2!"uml::Expression") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Expression") ;
helper def : UsageGuard(invar : UML2!"uml::Usage") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Usage") ;
helper def : PackageMergeGuard(invar : UML2!"uml::PackageMerge") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::PackageMerge") ;
helper def : ProfileApplicationGuard(invar : UML2!"uml::ProfileApplication") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ProfileApplication") ;
helper def : EnumerationGuard(invar : UML2!"uml::Enumeration") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Enumeration") ;
helper def : EnumerationLiteralGuard(invar : UML2!"uml::EnumerationLiteral") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::EnumerationLiteral") ;
helper def : InstanceSpecificationGuard(invar : UML2!"uml::InstanceSpecification") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InstanceSpecification") ;
helper def : SlotGuard(invar : UML2!"uml::Slot") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Slot") ;
helper def : PrimitiveTypeGuard(invar : UML2!"uml::PrimitiveType") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::PrimitiveType") ;
helper def : LiteralIntegerGuard(invar : UML2!"uml::LiteralInteger") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::LiteralInteger") ;
helper def : LiteralStringGuard(invar : UML2!"uml::LiteralString") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::LiteralString") ;
helper def : LiteralBooleanGuard(invar : UML2!"uml::LiteralBoolean") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::LiteralBoolean") ;
helper def : LiteralNullGuard(invar : UML2!"uml::LiteralNull") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::LiteralNull") ;
helper def : InstanceValueGuard(invar : UML2!"uml::InstanceValue") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InstanceValue") ;
helper def : LiteralUnlimitedNaturalGuard(invar : UML2!"uml::LiteralUnlimitedNatural") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::LiteralUnlimitedNatural") ;
helper def : OpaqueBehaviorGuard(invar : UML2!"uml::OpaqueBehavior") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::OpaqueBehavior") ;
helper def : FunctionBehaviorGuard(invar : UML2!"uml::FunctionBehavior") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::FunctionBehavior") ;
helper def : OpaqueActionGuard(invar : UML2!"uml::OpaqueAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::OpaqueAction") ;
helper def : StructuredActivityNodeGuard(invar : UML2!"uml::StructuredActivityNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::StructuredActivityNode") ;
helper def : ActivityGuard(invar : UML2!"uml::Activity") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Activity") ;
helper def : VariableGuard(invar : UML2!"uml::Variable") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Variable") ;
helper def : ActivityPartitionGuard(invar : UML2!"uml::ActivityPartition") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ActivityPartition") ;
helper def : InterruptibleActivityRegionGuard(invar : UML2!"uml::InterruptibleActivityRegion") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InterruptibleActivityRegion") ;
helper def : ExceptionHandlerGuard(invar : UML2!"uml::ExceptionHandler") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ExceptionHandler") ;
helper def : OutputPinGuard(invar : UML2!"uml::OutputPin") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::OutputPin") ;
helper def : PinGuard(invar : UML2!"uml::Pin") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Pin") ;
helper def : InputPinGuard(invar : UML2!"uml::InputPin") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InputPin") ;
helper def : SendSignalActionGuard(invar : UML2!"uml::SendSignalAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::SendSignalAction") ;
helper def : CallOperationActionGuard(invar : UML2!"uml::CallOperationAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CallOperationAction") ;
helper def : CallBehaviorActionGuard(invar : UML2!"uml::CallBehaviorAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CallBehaviorAction") ;
helper def : SequenceNodeGuard(invar : UML2!"uml::SequenceNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::SequenceNode") ;
helper def : ControlFlowGuard(invar : UML2!"uml::ControlFlow") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ControlFlow") ;
helper def : InitialNodeGuard(invar : UML2!"uml::InitialNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InitialNode") ;
helper def : ActivityParameterNodeGuard(invar : UML2!"uml::ActivityParameterNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ActivityParameterNode") ;
helper def : ValuePinGuard(invar : UML2!"uml::ValuePin") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ValuePin") ;
helper def : MessageGuard(invar : UML2!"uml::Message") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Message") ;
helper def : InteractionGuard(invar : UML2!"uml::Interaction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Interaction") ;
helper def : LifelineGuard(invar : UML2!"uml::Lifeline") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Lifeline") ;
helper def : PartDecompositionGuard(invar : UML2!"uml::PartDecomposition") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::PartDecomposition") ;
helper def : InteractionUseGuard(invar : UML2!"uml::InteractionUse") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InteractionUse") ;
helper def : GateGuard(invar : UML2!"uml::Gate") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Gate") ;
helper def : GeneralOrderingGuard(invar : UML2!"uml::GeneralOrdering") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::GeneralOrdering") ;
helper def : OccurrenceSpecificationGuard(invar : UML2!"uml::OccurrenceSpecification") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::OccurrenceSpecification") ;
helper def : InteractionOperandGuard(invar : UML2!"uml::InteractionOperand") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InteractionOperand") ;
helper def : InteractionConstraintGuard(invar : UML2!"uml::InteractionConstraint") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InteractionConstraint") ;
helper def : StateInvariantGuard(invar : UML2!"uml::StateInvariant") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::StateInvariant") ;
helper def : ActionExecutionSpecificationGuard(invar : UML2!"uml::ActionExecutionSpecification") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ActionExecutionSpecification") ;
helper def : BehaviorExecutionSpecificationGuard(invar : UML2!"uml::BehaviorExecutionSpecification") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::BehaviorExecutionSpecification ") ;
helper def : ExecutionEventGuard(invar : UML2!"uml::ExecutionEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ExecutionEvent") ;
helper def : CreationEventGuard(invar : UML2!"uml::CreationEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CreationEvent") ;
helper def : DestructionEventGuard(invar : UML2!"uml::DestructionEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DestructionEvent") ;
helper def : SendOperationEventGuard(invar : UML2!"uml::SendOperationEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::SendOperationEvent") ;
helper def : SendSignalEventGuard(invar : UML2!"uml::SendSignalEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::SendSignalEvent") ;
helper def : MessageOccurrenceSpecificationGuard(invar : UML2!"uml::MessageOccurrenceSpecification") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::MessageOccurrenceSpecification ") ;
helper def : ExecutionOccurrenceSpecificationGuard(invar : UML2!"uml::ExecutionOccurrenceSpecification") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ExecutionOccurrenceSpecification ") ;
helper def : ReceiveOperationEventGuard(invar : UML2!"uml::ReceiveOperationEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReceiveOperationEvent") ;
helper def : ReceiveSignalEventGuard(invar : UML2!"uml::ReceiveSignalEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReceiveSignalEvent") ;
helper def : ActorGuard(invar : UML2!"uml::Actor") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Actor") ;
helper def : CallEventGuard(invar : UML2!"uml::CallEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CallEvent") ;
helper def : ChangeEventGuard(invar : UML2!"uml::ChangeEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ChangeEvent") ;
helper def : SignalEventGuard(invar : UML2!"uml::SignalEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::SignalEvent") ;
helper def : AnyReceiveEventGuard(invar : UML2!"uml::AnyReceiveEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::AnyReceiveEvent") ;
helper def : ForkNodeGuard(invar : UML2!"uml::ForkNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ForkNode") ;
helper def : FlowFinalNodeGuard(invar : UML2!"uml::FlowFinalNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::FlowFinalNode") ;
helper def : CentralBufferNodeGuard(invar : UML2!"uml::CentralBufferNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CentralBufferNode") ;
helper def : MergeNodeGuard(invar : UML2!"uml::MergeNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::MergeNode") ;
helper def : DecisionNodeGuard(invar : UML2!"uml::DecisionNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DecisionNode") ;
helper def : ActivityFinalNodeGuard(invar : UML2!"uml::ActivityFinalNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ActivityFinalNode") ;
helper def : ComponentRealizationGuard(invar : UML2!"uml::ComponentRealization") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ComponentRealization") ;
helper def : ComponentGuard(invar : UML2!"uml::Component") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Component") ;
helper def : NodeGuard(invar : UML2!"uml::Node") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Node") ;
helper def : DeviceGuard(invar : UML2!"uml::Device") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Device") ;
helper def : ExecutionEnvironmentGuard(invar : UML2!"uml::ExecutionEnvironment") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ExecutionEnvironment") ;
helper def : CommunicationPathGuard(invar : UML2!"uml::CommunicationPath") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CommunicationPath") ;
helper def : CombinedFragmentGuard(invar : UML2!"uml::CombinedFragment") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CombinedFragment") ;
helper def : ContinuationGuard(invar : UML2!"uml::Continuation") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Continuation") ;
helper def : ConsiderIgnoreFragmentGuard(invar : UML2!"uml::ConsiderIgnoreFragment") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ConsiderIgnoreFragment") ;
helper def : CreateObjectActionGuard(invar : UML2!"uml::CreateObjectAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CreateObjectAction") ;
helper def : DestroyObjectActionGuard(invar : UML2!"uml::DestroyObjectAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DestroyObjectAction") ;
helper def : TestIdentityActionGuard(invar : UML2!"uml::TestIdentityAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TestIdentityAction") ;
helper def : ReadSelfActionGuard(invar : UML2!"uml::ReadSelfAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReadSelfAction") ;
helper def : ReadStructuralFeatureActionGuard(invar : UML2!"uml::ReadStructuralFeatureAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReadStructuralFeatureAction") ;
helper def : ClearStructuralFeatureActionGuard(invar : UML2!"uml::ClearStructuralFeatureAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ClearStructuralFeatureAction") ;
helper def : RemoveStructuralFeatureValueActionGuard(invar : UML2!"uml::RemoveStructuralFeatureValueAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::RemoveStructuralFeatureValueAction ") ;
helper def : AddStructuralFeatureValueActionGuard(invar : UML2!"uml::AddStructuralFeatureValueAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::AddStructuralFeatureValueAction ") ;
helper def : LinkEndDataGuard(invar : UML2!"uml::LinkEndData") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::LinkEndData") ;
helper def : QualifierValueGuard(invar : UML2!"uml::QualifierValue") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::QualifierValue") ;
helper def : ReadLinkActionGuard(invar : UML2!"uml::ReadLinkAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReadLinkAction") ;
helper def : LinkEndCreationDataGuard(invar : UML2!"uml::LinkEndCreationData") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::LinkEndCreationData") ;
helper def : CreateLinkActionGuard(invar : UML2!"uml::CreateLinkAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CreateLinkAction") ;
helper def : DestroyLinkActionGuard(invar : UML2!"uml::DestroyLinkAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DestroyLinkAction") ;
helper def : LinkEndDestructionDataGuard(invar : UML2!"uml::LinkEndDestructionData") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::LinkEndDestructionData") ;
helper def : ClearAssociationActionGuard(invar : UML2!"uml::ClearAssociationAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ClearAssociationAction") ;
helper def : BroadcastSignalActionGuard(invar : UML2!"uml::BroadcastSignalAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::BroadcastSignalAction") ;
helper def : SendObjectActionGuard(invar : UML2!"uml::SendObjectAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::SendObjectAction") ;
helper def : ValueSpecificationActionGuard(invar : UML2!"uml::ValueSpecificationAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ValueSpecificationAction") ;
helper def : TimeExpressionGuard(invar : UML2!"uml::TimeExpression") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TimeExpression") ;
helper def : DurationGuard(invar : UML2!"uml::Duration") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Duration") ;
helper def : DurationIntervalGuard(invar : UML2!"uml::DurationInterval") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DurationInterval") ;
helper def : IntervalGuard(invar : UML2!"uml::Interval") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Interval") ;
helper def : TimeConstraintGuard(invar : UML2!"uml::TimeConstraint") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TimeConstraint") ;
helper def : IntervalConstraintGuard(invar : UML2!"uml::IntervalConstraint") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::IntervalConstraint") ;
helper def : TimeIntervalGuard(invar : UML2!"uml::TimeInterval") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TimeInterval") ;
helper def : DurationConstraintGuard(invar : UML2!"uml::DurationConstraint") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DurationConstraint") ;
helper def : TimeObservationGuard(invar : UML2!"uml::TimeObservation") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TimeObservation") ;
helper def : DurationObservationGuard(invar : UML2!"uml::DurationObservation") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DurationObservation") ;
helper def : FinalStateGuard(invar : UML2!"uml::FinalState") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::FinalState") ;
helper def : TimeEventGuard(invar : UML2!"uml::TimeEvent") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::TimeEvent") ;
helper def : ReadVariableActionGuard(invar : UML2!"uml::ReadVariableAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReadVariableAction") ;
helper def : ClearVariableActionGuard(invar : UML2!"uml::ClearVariableAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ClearVariableAction") ;
helper def : AddVariableValueActionGuard(invar : UML2!"uml::AddVariableValueAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::AddVariableValueAction") ;
helper def : RemoveVariableValueActionGuard(invar : UML2!"uml::RemoveVariableValueAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::RemoveVariableValueAction") ;
helper def : RaiseExceptionActionGuard(invar : UML2!"uml::RaiseExceptionAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::RaiseExceptionAction") ;
helper def : ActionInputPinGuard(invar : UML2!"uml::ActionInputPin") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ActionInputPin") ;
helper def : InformationItemGuard(invar : UML2!"uml::InformationItem") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InformationItem") ;
helper def : InformationFlowGuard(invar : UML2!"uml::InformationFlow") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::InformationFlow") ;
helper def : ReadExtentActionGuard(invar : UML2!"uml::ReadExtentAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReadExtentAction") ;
helper def : ReclassifyObjectActionGuard(invar : UML2!"uml::ReclassifyObjectAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReclassifyObjectAction") ;
helper def : ReadIsClassifiedObjectActionGuard(invar : UML2!"uml::ReadIsClassifiedObjectAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReadIsClassifiedObjectAction") ;
helper def : StartClassifierBehaviorActionGuard(invar : UML2!"uml::StartClassifierBehaviorAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::StartClassifierBehaviorAction") ;
helper def : ReadLinkObjectEndActionGuard(invar : UML2!"uml::ReadLinkObjectEndAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReadLinkObjectEndAction") ;
helper def : ReadLinkObjectEndQualifierActionGuard(invar : UML2!"uml::ReadLinkObjectEndQualifierAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReadLinkObjectEndQualifierAction ") ;
helper def : CreateLinkObjectActionGuard(invar : UML2!"uml::CreateLinkObjectAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::CreateLinkObjectAction") ;
helper def : AcceptEventActionGuard(invar : UML2!"uml::AcceptEventAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::AcceptEventAction") ;
helper def : AcceptCallActionGuard(invar : UML2!"uml::AcceptCallAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::AcceptCallAction") ;
helper def : ReplyActionGuard(invar : UML2!"uml::ReplyAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReplyAction") ;
helper def : UnmarshallActionGuard(invar : UML2!"uml::UnmarshallAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::UnmarshallAction") ;
helper def : ReduceActionGuard(invar : UML2!"uml::ReduceAction") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ReduceAction") ;
helper def : JoinNodeGuard(invar : UML2!"uml::JoinNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::JoinNode") ;
helper def : DataStoreNodeGuard(invar : UML2!"uml::DataStoreNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::DataStoreNode") ;
helper def : ObjectFlowGuard(invar : UML2!"uml::ObjectFlow") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ObjectFlow") ;
helper def : ConditionalNodeGuard(invar : UML2!"uml::ConditionalNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ConditionalNode") ;
helper def : ClauseGuard(invar : UML2!"uml::Clause") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::Clause") ;
helper def : LoopNodeGuard(invar : UML2!"uml::LoopNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::LoopNode") ;
helper def : ExpansionNodeGuard(invar : UML2!"uml::ExpansionNode") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ExpansionNode") ;
helper def : ExpansionRegionGuard(invar : UML2!"uml::ExpansionRegion") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ExpansionRegion") ;
helper def : ProtocolTransitionGuard(invar : UML2!"uml::ProtocolTransition") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::ProtocolTransition") ;
helper def : AssociationClassGuard(invar : UML2!"uml::AssociationClass") : Boolean = thisModule.isIncluded(invar) and
invar.oclIsTypeOf(UML2!"uml::AssociationClass") ;
rule copyStereoType(invar : UML2!"uml::Element",outvar : UML2!"uml::Element"){
do{
--invar.getAppliedStereotypes().debug('applied stereotypes');
for(st in invar.getAppliedStereotypes()){
-- st.getName().debug('stereotype working on');
outvar.applyStereotype(st);
for (a in st.getAllAttributes()){
-- a.debug('attribute :');
-- invar.getValue(st,a.name).debug('value for '+a.name);
if(not invar.getValue(st,a.name).oclIsUndefined()){
if ( not a.name.startsWith('base_') ){
outvar.setValue(st,a.name, invar.getValue(st,a.name) );
}else{
if(a.name='tableName'){
outvar.setValue(st,a.name, invar.name.toLower() );
}--do
endpoint rule endpointRule() {
do {
entrypoint rule entrypointRule() {
do {
rule CommentRule {
from invar : UML2!"uml::Comment" (thisModule.CommentGuard(invar))
to Commentvar : UML2!Comment (
body <- invar.body,
eAnnotations <- invar.eAnnotations,
ownedComment <- invar.ownedComment,
annotatedElement <- invar.annotatedElement
do {
--invar.debug('CommentRule');
rule PackageRule {
from invar : UML2!"uml::Package" (thisModule.PackageGuard(invar))
to Packagevar : UML2!Package (
name <- invar.name,
visibility <- invar.visibility,
clientDependency <- invar.clientDependency,
nameExpression <- invar.nameExpression,
elementImport <- invar.elementImport,
packageImport <- invar.packageImport,
ownedRule <- invar.ownedRule,
owningTemplateParameter <- invar.owningTemplateParameter,
templateParameter <- invar.templateParameter,
templateBinding <- invar.templateBinding,
ownedTemplateSignature <- invar.ownedTemplateSignature,
ownedType <- invar.ownedType,
packageMerge <- invar.packageMerge,
packagedElement <- invar.packagedElement,
-- nestedPackage <- invar.nestedPackage,
nestingPackage <- invar.nestingPackage,
profileApplication <- invar.profileApplication
do {
invar.debug('PackageRule');
rule DependencyRule {
from invar : UML2!"uml::Dependency" (thisModule.DependencyGuard(invar))
to Dependencyvar : UML2!Dependency (
name <- invar.name,
supplier <- invar.supplier,
client <- invar.client
do {
thisModule.copyStereoType(invar,Dependencyvar);
invar.debug('DependencyRule');
rule ElementImportRule {
from invar : UML2!"uml::ElementImport" (thisModule.ElementImportGuard(invar))
to ElementImportvar : UML2!ElementImport (
alias <- invar.alias,
importedElement <- invar.importedElement,
importingNamespace <- invar.importingNamespace
do {
thisModule.copyStereoType(invar,ElementImportvar);
invar.debug('ElementImportRule');
rule PackageImportRule {
from invar : UML2!"uml::PackageImport" (thisModule.PackageImportGuard(invar))
to PackageImportvar : UML2!PackageImport (
importedPackage <- invar.importedPackage,
do {
thisModule.copyStereoType(invar,PackageImportvar);
invar.debug('PackageImportRule');
rule ConstraintRule {
from invar : UML2!"uml::Constraint" (thisModule.ConstraintGuard(invar))
to Constraintvar : UML2!Constraint (
name <- invar.name,
constrainedElement <- invar.constrainedElement,
specification <- invar.specification,
"context" <- invar."context"
do {
thisModule.copyStereoType(invar,Constraintvar);
invar.debug('ConstraintRule');
rule AssociationRule {
from invar : UML2!"uml::Association" (thisModule.AssociationGuard(invar))
to Associationvar : UML2!Association (
name <- invar.name,
isLeaf <- invar.isLeaf,
isAbstract <- invar.isAbstract,
isDerived <- invar.isDerived,
package <- invar.package,
generalization <- invar.generalization,
powertypeExtent <- invar.powertypeExtent,
redefinedClassifier <- invar.redefinedClassifier,
general <- invar.general,
substitution <- invar.substitution,
representation <- invar.representation,
collaborationUse <- invar.collaborationUse,
ownedUseCase <- invar.ownedUseCase,
useCase <- invar.useCase,
ownedEnd <- invar.ownedEnd,
memberEnd <- invar.memberEnd,
navigableOwnedEnd <- invar.navigableOwnedEnd
do {
thisModule.copyStereoType(invar,Associationvar);
invar.debug('AssociationRule');
rule TemplateBindingRule {
from invar : UML2!"uml::TemplateBinding" (thisModule.TemplateBindingGuard(invar))
to TemplateBindingvar : UML2!TemplateBinding (
signature <- invar.signature,
parameterSubstitution <- invar.parameterSubstitution,
boundElement <- invar.boundElement
do {
thisModule.copyStereoType(invar,TemplateBindingvar);
invar.debug('TemplateBindingRule');
rule TemplateSignatureRule {
from invar : UML2!"uml::TemplateSignature" (thisModule.TemplateSignatureGuard(invar))
to TemplateSignaturevar : UML2!TemplateSignature (
parameter <- invar.parameter,
ownedParameter <- invar.ownedParameter,
template <- invar.template
do {
thisModule.copyStereoType(invar,TemplateSignaturevar);
invar.debug('TemplateSignatureRule');
rule TemplateParameterRule {
from invar : UML2!"uml::TemplateParameter" (thisModule.TemplateParameterGuard(invar))
to TemplateParametervar : UML2!TemplateParameter (
parameteredElement <- invar.parameteredElement,
ownedParameteredElement <- invar.ownedParameteredElement,
default <- invar.default,
ownedDefault <- invar.ownedDefault
do {
thisModule.copyStereoType(invar,TemplateParametervar);
invar.debug('TemplateParameterRule');
rule TemplateParameterSubstitutionRule {
from invar : UML2!"uml::TemplateParameterSubstitution" (thisModule.TemplateParameterSubstitutionGuard(invar))
to TemplateParameterSubstitutionvar : UML2!TemplateParameterSubstitution (
formal <- invar.formal,
actual <- invar.actual,
ownedActual <- invar.ownedActual,
do {
thisModule.copyStereoType(invar,TemplateParameterSubstitutio nvar);
invar.debug('TemplateParameterSubstitutionRule');
rule GeneralizationRule {
from invar : UML2!"uml::Generalization" (thisModule.GeneralizationGuard(invar))
to Generalizationvar : UML2!Generalization (
isSubstitutable <- invar.isSubstitutable,
generalizationSet <- invar.generalizationSet,
specific <- invar.specific
do {
thisModule.copyStereoType(invar,Generalizationvar);
invar.debug('GeneralizationRule');
rule GeneralizationSetRule {
from invar : UML2!"uml::GeneralizationSet" (thisModule.GeneralizationSetGuard(invar))
to GeneralizationSetvar : UML2!GeneralizationSet (
name <- invar.name,
isCovering <- invar.isCovering,
isDisjoint <- invar.isDisjoint,
powertype <- invar.powertype,
do {
thisModule.copyStereoType(invar,GeneralizationSetvar);
invar.debug('GeneralizationSetRule');
rule SubstitutionRule {
from invar : UML2!"uml::Substitution" (thisModule.SubstitutionGuard(invar))
to Substitutionvar : UML2!Substitution (
name <- invar.name,
client <- invar.client,
mapping <- invar.mapping,
contract <- invar.contract,
substitutingClassifier <- invar.substitutingClassifier
do {
thisModule.copyStereoType(invar,Substitutionvar);
invar.debug('SubstitutionRule');
rule RealizationRule {
from invar : UML2!"uml::Realization" (thisModule.RealizationGuard(invar))
to Realizationvar : UML2!Realization (
name <- invar.name,
do {
thisModule.copyStereoType(invar,Realizationvar);
invar.debug('RealizationRule');
rule AbstractionRule {
from invar : UML2!"uml::Abstraction" (thisModule.AbstractionGuard(invar))
to Abstractionvar : UML2!Abstraction (
name <- invar.name,
do {
thisModule.copyStereoType(invar,Abstractionvar);
invar.debug('AbstractionRule');
rule OpaqueExpressionRule {
from invar : UML2!"uml::OpaqueExpression" (thisModule.OpaqueExpressionGuard(invar))
to OpaqueExpressionvar : UML2!OpaqueExpression (
name <- invar.name,
body <- invar.body,
language <- invar.language,
type <- invar.type,
behavior <- invar.behavior
do {
thisModule.copyStereoType(invar,OpaqueExpressionvar);
invar.debug('OpaqueExpressionRule');
rule ParameterRule {
from invar : UML2!"uml::Parameter" (thisModule.ParameterGuard(invar))
to Parametervar : UML2!Parameter (
name <- invar.name,
isOrdered <- invar.isOrdered,
isUnique <- invar.isUnique,
upper <- invar.upper,
lower <- invar.lower,
direction <- invar.direction,
isException <- invar.isException,
isStream <- invar.isStream,
effect <- invar.effect,
type <- invar.type,
end <- invar.end,
upperValue <- invar.upperValue,
lowerValue <- invar.lowerValue,
parameterSet <- invar.parameterSet,
defaultValue <- invar.defaultValue
do {
thisModule.copyStereoType(invar,Parametervar);
invar.debug('ParameterRule');
rule ConnectableElementTemplateParameterRule {
from invar : UML2!"uml::ConnectableElementTemplateParameter" (thisModule.ConnectableElementTemplateParameterGuard(invar))
to ConnectableElementTemplateParametervar : UML2!ConnectableElementTemplateParameter (
do {
thisModule.copyStereoType(invar,ConnectableElementTemplatePa rametervar);
invar.debug('ConnectableElementTemplateParameterRule');
rule ConnectorEndRule {
from invar : UML2!"uml::ConnectorEnd" (thisModule.ConnectorEndGuard(invar))
to ConnectorEndvar : UML2!ConnectorEnd (
partWithPort <- invar.partWithPort,
role <- invar.role
do {
thisModule.copyStereoType(invar,ConnectorEndvar);
invar.debug('ConnectorEndRule');
rule PropertyRule {
from invar : UML2!"uml::Property" (thisModule.PropertyGuard(invar))
to Propertyvar : UML2!Property (
name <- invar.name,
isStatic <- invar.isStatic,
isReadOnly <- invar.isReadOnly,
isDerivedUnion <- invar.isDerivedUnion,
aggregation <- invar.aggregation,
isComposite <- invar.isComposite,
type <- invar.type,
end <- invar.end,
deployment <- invar.deployment,
datatype <-invar.datatype,
redefinedProperty <- invar.redefinedProperty,
owningAssociation <- invar.owningAssociation,
defaultValue <- invar.defaultValue,
--opposite <- invar.opposite,
subsettedProperty <- invar.subsettedProperty,
association <- invar.association,
qualifier <- invar.qualifier,
associationEnd <- invar.associationEnd
do {
thisModule.copyStereoType(invar,Propertyvar);
invar.debug('PropertyRule');
rule DeploymentRule {
from invar : UML2!"uml::Deployment" (thisModule.DeploymentGuard(invar))
to Deploymentvar : UML2!Deployment (
name <- invar.name,
deployedArtifact <- invar.deployedArtifact,
configuration <- invar.configuration,
location <- invar.location
do {
thisModule.copyStereoType(invar,Deploymentvar);
invar.debug('DeploymentRule');
rule DeploymentSpecificationRule {
from invar : UML2!"uml::DeploymentSpecification" (thisModule.DeploymentSpecificationGuard(invar))
to DeploymentSpecificationvar : UML2!DeploymentSpecification (
name <- invar.name,
fileName <- invar.fileName,
deploymentLocation <- invar.deploymentLocation,
executionLocation <- invar.executionLocation,
nestedArtifact <- invar.nestedArtifact,
manifestation <- invar.manifestation,
ownedOperation <- invar.ownedOperation,
ownedAttribute <- invar.ownedAttribute,
do {
thisModule.copyStereoType(invar,DeploymentSpecificationvar);
invar.debug('DeploymentSpecificationRule');
rul
Re: Reapplying a profile after its has be re-defined [message #476849 is a reply to message #476847] |
Mon, 14 January 2008 09:52  |
Anders,
Just apply it again using the same menu item you used when you first applied
it...
Kenn
news:fmaj6q$r6b$1@build.eclipse.org...
> Kenn,
>> best-effort basis.
> Ok, how does one "Re-apply" the profile? (I cant see any menu item for
> reapply, only unapply an apply) Do I have to make my own menu?
> thanks for any help.
> /anders
Re: Reapplying a profile after its has be re-defined [message #625738 is a reply to message #476763] |
Mon, 17 December 2007 09:02  |
> Such as:
> /anders
I have achieved this with a transformation in ATL.
Re: Reapplying a profile after its has be re-defined [message #625739 is a reply to message #476763] |
Mon, 17 December 2007 10:03  |
Anders,
If you're deleting annotations, you're deleting the metadata that is needed
in order to successfully recognize stereotype applications based on older
versions of the profile... So if you want to keep your stereotype
Kenn
> Such as:
> I always define the profile after changed and I keep the annotation:nsURI
> /anders
Re: Reapplying a profile after its has be re-defined [message #625745 is a reply to message #476765] |
Mon, 17 December 2007 12:54  |
/anders
>> Hi,
>> of changing a profile with many redefines.
>> an existing '*.uml' file where i have applied the profile, the
>> Such as:
>> last one since I make soo many changed/addition)
>> /anders
Re: Reapplying a profile after its has be re-defined [message #625746 is a reply to message #476765] |
Mon, 17 December 2007 12:56  |
/anders
>> Hi,
>> Such as:
>> /anders
Re: Reapplying a profile after its has be re-defined [message #625747 is a reply to message #476766] |
Mon, 17 December 2007 12:59  |
Kenn,
*.uml) to a newer and improved one?
stereotype?
/anders
Kenn Hussey wrote:
> Anders,
> Kenn
>> Hi,
>> Such as:
>> /anders
Re: Reapplying a profile after its has be re-defined [message #625748 is a reply to message #476774] |
Anders,
best-effort basis.
Kenn
> Kenn,
> stereotype?
> /anders
> Kenn Hussey wrote:
>> Anders,
>> Kenn
>>> Hi,
>>> Such as:
>>> /anders
Re: Reapplying a profile after its has be re-defined [message #625759 is a reply to message #476773] |
> /anders
true
do{
}else{
}--do
do {
do {
rule CommentRule {
body <- invar.body,
do {
rule PackageRule {
name <- invar.name,
do {
name <- invar.name,
do {
do {
do {
name <- invar.name,
do {
name <- invar.name,
do {
do {
do {
do {
do {
do {
name <- invar.name,
do {
name <- invar.name,
do {
name <- invar.name,
do {
name <- invar.name,
do {
name <- invar.name,
body <- invar.body,
type <- invar.type,
do {
name <- invar.name,
type <- invar.type,
end <- invar.end,
do {
do {
role <- invar.role
do {
rule PropertyRule {
name <- invar.name,
type <- invar.type,
end <- invar.end,
do {
name <- invar.name,
do {
name <- invar.name,
do {
rul
Re: Reapplying a profile after its has be re-defined [message #625895 is a reply to message #476775] |
Sat, 12 January 2008 09:35  |
Kenn,
> best-effort basis.
/anders
Re: Reapplying a profile after its has be re-defined [message #625897 is a reply to message #476847] |
Anders,
it...
Kenn
> Kenn,
>> best-effort basis.
> /anders
Current Time: Sun Jul 20 16:04:40 EDT 2025
Powered by FUDForum. Page generated in 0.06568 seconds
