Profiles eCore <-> UML [message #476016] |
Thu, 20 September 2007 11:02  |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
hi, I was wondering how profiles defined in UML and eCore are connected
or differ from each other.
I noticed 2 major differences when definining a profile:
the profile in UML imports UML.metamodel.uml.
the profile in eCore imports UML.ecore
what are the differences between both metamodels?
Why is an association class needed in the profile definition? When I
compare both serialization:
UML:
<packagedElement xmi:type="uml:Stereotype" xmi:id="(...)**2"
name="Element">
<ownedAttribute xmi:id="(...)**3" name="base_Class"
visibility="private" association="(...)**1">
<type xmi:type="uml:Class"
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Class"/>
</ownedAttribute>
</packagedElement>
And the association class:
<packagedElement xmi:type="uml:Extension" xmi:id="(...)**1" name=""
memberEnd="(...)**4 (...)**3">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="(...)**4"
name="extension_" visibility="private" type="(...)**2"
aggregation="composite" association="(...)**1">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="(...)"
name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="(...)" name=""/>
</ownedEnd>
</packagedElement>
Ecore seems much more readable, and I don't see a benefit of the UML
definition since there's no lose of information in eCore:
<eClassifiers xsi:type="ecore:EClass" name="Element">
<eStructuralFeatures xsi:type="ecore:EReference" name="base_Class"
ordered="false"
lowerBound="1" eType="ecore:EClass
platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Clas s "/>
</eClassifiers>
thanks
- -stefan
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFG8otuIYVWjMSpDwwRAmFIAKD1V6SkblABNo2wgabUl65w68JOrQCf djah
A+I6rFVCzIYZ3BC2CqudXj4=
=Ol5Q
-----END PGP SIGNATURE-----
Re: Profiles eCore <-> UML [message #476021 is a reply to message #476016] |
Fri, 21 September 2007 14:45  |
Some comments below...
"SKuhn" <kuhn@oio.de> wrote in message
news:fcu22g$kvo$1@build.eclipse.org...
> Hash: SHA1
Profile's defined using UML use metatypes from the UML metamodel. When
you "define" your profile, you create an ecore representation. In general,
UML is more expressive than Ecore however, the kind of information that
should be added to the UML representation in your profile should be fairly
simple and therefore the Ecore represnentation should roughly map 1-1 to the
Ecore representation.
UML.ecore is the ecore representation of the merged UML metamodel. The api
is ultimately controlled by this .ecore representation but a mapping is made
from the .uml version of the metamodel to the ecore version first.
> UML:
> name="Element">
> </ownedAttribute>
> </packagedElement>
> name="" value="1"/>
> </ownedEnd>
> </packagedElement>
I'm not sure what you mean by "association class" are you referring to the
extension? It is a way of indicating the metatype being extended.
> ordered="false"
> </eClassifiers>
Ecore is definitely more readable but it represents a subset of what UML can
represent. It basically focuses on the "class" part of UML, ie.
representing classes, properties etc. Ecore does not deal with
statemachines, activities, interactions etc.
> thanks
> - -stefan
> =Ol5Q
Re: Profiles eCore <-> UML [message #624932 is a reply to message #476016] |
> Hash: SHA1
> UML:
> name="Element">
> </ownedAttribute>
> </packagedElement>
> name="" value="1"/>
> </ownedEnd>
> </packagedElement>
> ordered="false"
> </eClassifiers>
> thanks
> - -stefan
> =Ol5Q
FUDForum. Page generated in 0.04201 seconds
