Home » Modeling » UML2 Tools » Newbie - generated class is extending interface not implementing
Newbie - generated class is extending interface not implementing [message #491739] Thu, 15 October 2009 11:55 Go to next message
Total, total newbie with UML/EMF.
Usign UML2 Tools I've created a simple interface with a single method "hello". A simple class has an interfaceRealization link to the interface.
I have created an EMF .gencode file from the .uml file, which shows "HelloClass -> Hello" (I presume this means HelloClass implements Hello).
When I generate the Java model I instead find that "HelloClass" is now an interface extending "Hello", rather than a class implementing "Hello".
Where am I going wrong?
Re: Newbie - generated class is extending interface not implementing [message #491766 is a reply to message #491739] Thu, 15 October 2009 13:27 Go to previous messageGo to next message
Tony,
Comments below.
> interface.
*.genmodel?
It's showing EClasses I guess?
Every EClass X will always map to an interface X; that interface
typically has an implementation class XImpl. There's no such concept of
classes verses interfaces in Ecore, so don't expect it.
Probably isn't an issue of expectations verses how it actually works.
Re: Newbie - generated class is extending interface not implementing [message #491845 is a reply to message #491766] Fri, 16 October 2009 03:31 Go to previous message
Hi Ed,
Sorry - wrote my post in a total hurry. Yes, I meant .genmodel - realised that when I got home!
Yes, the .genmodel and .ecore structures both show EClasses:
- 'Hello' interface is an EClass, and has a single EOperation 'hello'
- 'HelloClass' in also an EClass.
Right - clearly I need to do more reading up... I did look at a few tutorials but have found it hard going. I'll read up some more - get my expectations sorted out.
Thanks Ed,
Tony
Re: Newbie - generated class is extending interface not implementing [message #624908 is a reply to message #491766] Fri, 16 October 2009 03:31 Go to previous message
Hi Ed,
Thanks Ed,
Tony
Previous Topic:How to remove "src" and "dst", and other questions
Next Topic:Create associations in profile definiton
Current Time: Sun Jul 20 09:10:32 EDT 2025
Powered by FUDForum. Page generated in 0.04543 seconds
